2008vistablue Posted May 18, 2010 Report Share Posted May 18, 2010 I got under the car today to install a mid pipe and noticed that there is an oil leak. There is a black tube on the drivers side right above the oil filter. The was a drop on the bottom of the tube. Those guys who had the galley plugs loose on the drivers head.....is this a similar oil collection point? Anyone else experience this and know the root cause? Thanks! Quote Link to comment Share on other sites More sharing options...
2008vistablue Posted May 18, 2010 Author Report Share Posted May 18, 2010 I got under the car today to install a mid pipe and noticed that there is an oil leak. There is a black tube on the drivers side right above the oil filter. The was a drop on the bottom of the tube. Those guys who had the galley plugs loose on the drivers head.....is this a similar oil collection point? Anyone else experience this and know the root cause? Thanks! Here's a pic.....I guess its right above the passenger exhaust where it bolts on to the manifold. http://i953.photobucket.com/albums/ae17/2008vistablue/DSCN2111.jpg Quote Link to comment Share on other sites More sharing options...
SicShelby Posted May 18, 2010 Report Share Posted May 18, 2010 (edited) Where does that hose come to/from to? Check the fittings or the connections... might be something simple like a loose hose clamp. Edited May 18, 2010 by SicShelby Quote Link to comment Share on other sites More sharing options...
OCD Posted May 18, 2010 Report Share Posted May 18, 2010 I got under the car today to install a mid pipe and noticed that there is an oil leak. There is a black tube on the drivers side right above the oil filter. The was a drop on the bottom of the tube. Those guys who had the galley plugs loose on the drivers head.....is this a similar oil collection point? Anyone else experience this and know the root cause? Thanks! Had 2 galley plugs loose and yes it dripped down that black tube... Quote Link to comment Share on other sites More sharing options...
jdscooby Posted May 18, 2010 Report Share Posted May 18, 2010 What I did? Quote Link to comment Share on other sites More sharing options...
2008vistablue Posted May 18, 2010 Author Report Share Posted May 18, 2010 Had 2 galley plugs loose and yes it dripped down that black tube... So whats all involved with tightening the galley plugs? Does the exhaust need to come off......the xmsn out or what? Quote Link to comment Share on other sites More sharing options...
OCD Posted May 18, 2010 Report Share Posted May 18, 2010 So whats all involved with tightening the galley plugs? Does the exhaust need to come off......the xmsn out or what? I had it fixed under warranty so not sure of the details, but I do know they took the exaust off for access... Quote Link to comment Share on other sites More sharing options...
SVTSnake Posted May 21, 2010 Report Share Posted May 21, 2010 Did mine under warranty also. They took off exhaust and dropped trans for access. Quote Link to comment Share on other sites More sharing options...
6-Speed Posted May 21, 2010 Report Share Posted May 21, 2010 Is this one of the oil plugs being discussed in this thread (circled)? There is one on each side under the rear most water plug. Quote Link to comment Share on other sites More sharing options...
SVTSnake Posted May 22, 2010 Report Share Posted May 22, 2010 Not sure...when my dealer did mine they said it was on back of head or block. Don't remember which. Was between firewall and engine, not much working room. Quote Link to comment Share on other sites More sharing options...
OCD Posted May 22, 2010 Report Share Posted May 22, 2010 Oil galley plugs on the back of the heads... Quote Link to comment Share on other sites More sharing options...
twobjshelbys Posted May 22, 2010 Report Share Posted May 22, 2010 Oil galley plugs on the back of the heads... The difference between "then and now" used to wuz you know you were in trouble if it didn't leak oil. It meant you were out... Especially 427FE. Quote Link to comment Share on other sites More sharing options...
ShelbyCobra826 Posted May 23, 2010 Report Share Posted May 23, 2010 Not really helpful, but I thought that I had this issue. When I took it into the dealership, the admitted to having not tightened the oil filter on the 15K mile oil change. No more leak... Quote Link to comment Share on other sites More sharing options...
2008vistablue Posted June 11, 2010 Author Report Share Posted June 11, 2010 We'll after 4 days at the shop, the oil leak is fixed. I told them to put die in and check the oil galley plugs based on other members experiences. I don't understand why is took so frickin long but its sorted now. Appreicate everyones input! Quote Link to comment Share on other sites More sharing options...
6-Speed Posted June 11, 2010 Report Share Posted June 11, 2010 We'll after 4 days at the shop, the oil leak is fixed. I told them to put die in and check the oil galley plugs based on other members experiences. I don't understand why is took so frickin long but its sorted now. Appreicate everyones input! So was it an oil galley plug? Quote Link to comment Share on other sites More sharing options...
2008vistablue Posted June 11, 2010 Author Report Share Posted June 11, 2010 So was it an oil galley plug? Yep the oil galley plug! Quote Link to comment Share on other sites More sharing options...
