TX STIG Posted May 10, 2010 Author Report Share Posted May 10, 2010 So then if that was the offset, 53mm = 2.08 inches + 5.5 inches (centerline), then the backspace would be 7.586 inches, right? Sorry just trying to understand why he had to cut the bumpstop brackets with 11" wheels and 315 tires. I guess it has something to do with the 2010 model. I think once the car was removed from the jack stands and the suspension loaded up, the wheels may have fit since the bracket would no longer be right next to the side of the tire. My concern is what happens when hitting bumps? Also, the left wheel could bolt up (barely) when the car was on jack stands, but the right wheel could not. Keep in mind that while these are 11" wheels they are 12" from edge to edge and then the tire sidewall is even slightly larger. Link to comment Share on other sites More sharing options...
breoland Posted May 11, 2010 Report Share Posted May 11, 2010 main question here is how well do those tires hook up? 315 is a great size and was wondering how well they work on the street Link to comment Share on other sites More sharing options...
TX STIG Posted May 11, 2010 Author Report Share Posted May 11, 2010 main question here is how well do those tires hook up? 315 is a great size and was wondering how well they work on the street Not as good as you'd think. Better than stock, but I can still break them loose at 50 mph in 3rd. Link to comment Share on other sites More sharing options...
Colleton Posted May 11, 2010 Report Share Posted May 11, 2010 Not enough sidewall on the 20s to get a grip? Link to comment Share on other sites More sharing options...
TX STIG Posted May 11, 2010 Author Report Share Posted May 11, 2010 Not enough sidewall on the 20s to get a grip? There's more sidewall than the OEM tires, but I think it's more an issue of 560 rwhp and 4.10 gears. Link to comment Share on other sites More sharing options...
2sharpie Posted May 31, 2010 Report Share Posted May 31, 2010 What an absolutely gorgeous set of wheels. I was originally going to powdercoat my stock wheels black.....but seeing these makes me have 2nd thoughts - especially when you can get them in 10"-plus widths. Link to comment Share on other sites More sharing options...
428cj Posted May 31, 2010 Report Share Posted May 31, 2010 do you think these will work with ford racing springs all the way around and are these the dr radial or street tires and how is traction with this set up 428cj Link to comment Share on other sites More sharing options...
TX STIG Posted May 31, 2010 Author Report Share Posted May 31, 2010 What an absolutely gorgeous set of wheels. I was originally going to powdercoat my stock wheels black.....but seeing these makes me have 2nd thoughts - especially when you can get them in 10"-plus widths. I thought about going the powder coat route with the stock wheels, but it was the tire packages available in 20" vs 19" that ultimately persuaded me. Link to comment Share on other sites More sharing options...
TX STIG Posted May 31, 2010 Author Report Share Posted May 31, 2010 do you think these will work with ford racing springs all the way around and are these the dr radial or street tires and how is traction with this set up 428cj I think the wheels will look great with or without stripes. I was going for that sinister look, and that's why the stripes had to go. However, some other color combos may look better with the rocker stripes. Link to comment Share on other sites More sharing options...
rsb5772 Posted October 12, 2010 Report Share Posted October 12, 2010 Your car does look awesome!! Did you order them Forgestar, or a dealer? Also, do you know the off-set and back spacing of the front wheels? Thanks! Link to comment Share on other sites More sharing options...
TX STIG Posted October 12, 2010 Author Report Share Posted October 12, 2010 Your car does look awesome!! Did you order them Forgestar, or a dealer? Also, do you know the off-set and back spacing of the front wheels? Thanks! Ordered straight from Forgestar. The offset is +40 front, +53 rear. I'll add this to my signature since I get this question a lot. Link to comment Share on other sites More sharing options...
rsb5772 Posted October 12, 2010 Report Share Posted October 12, 2010 Ordered straight from Forgestar. The offset is +40 front, +53 rear. I'll add this to my signature since I get this question a lot. Thanks. I figured you did, but I haven't noticed it anywhere. Link to comment Share on other sites More sharing options...
96slowbra Posted October 12, 2010 Report Share Posted October 12, 2010 those wheels look great!! and i want nt-05s too Link to comment Share on other sites More sharing options...
breoland Posted October 16, 2010 Report Share Posted October 16, 2010 Just a few things to keep in mind here, Anyone with a lowered car and is looking to install the nt05 315/35/20 tires may have some clearance issues. the tire is a very tall tire for a 20in. stock tires are 27in tall and the nitto is 28.5 its an inch talling and also almost 2in wider . it may rub in the upper part if the fender well and also the bumpstop bracket if anyone else here has them installed on there car and its lowered, please let us know how they work and if there is any issues Link to comment Share on other sites More sharing options...
TX STIG Posted October 17, 2010 Author Report Share Posted October 17, 2010 Just a few things to keep in mind here, Anyone with a lowered car and is looking to install the nt05 315/35/20 tires may have some clearance issues. the tire is a very tall tire for a 20in. stock tires are 27in tall and the nitto is 28.5 its an inch talling and also almost 2in wider . it may rub in the upper part if the fender well and also the bumpstop bracket if anyone else here has them installed on there car and its lowered, please let us know how they work and if there is any issues My car was not lowered and I would not recommend them for any car that is. In my case I had an additional inch of ground clearance and also an additional inch of fender well was consumed. If anyone has seen my car featured on the changing picture show banner on Forgestar's website it is not lowered, they used Photoshop to make it look like it was. Link to comment Share on other sites More sharing options...
breoland Posted October 18, 2010 Report Share Posted October 18, 2010 I knew your car was not lowered, i was just refering to the people that were planning these in the future that they may be too tall of a tire for a lowered car Link to comment Share on other sites More sharing options...
rsb5772 Posted October 18, 2010 Report Share Posted October 18, 2010 Were you able to use you stock lug nuts? If not, which ones did you need? Link to comment Share on other sites More sharing options...
TX STIG Posted October 19, 2010 Author Report Share Posted October 19, 2010 Were you able to use you stock lug nuts? If not, which ones did you need? Got new lugs from Discount Tire when they mounted tires. They were much smaller in diameter and a lot lighter. Link to comment Share on other sites More sharing options...
rsb5772 Posted October 19, 2010 Report Share Posted October 19, 2010 Thanks Link to comment Share on other sites More sharing options...
stjulien Posted October 28, 2010 Report Share Posted October 28, 2010 I have a 2007 GT500 and love the body style. I have never really liked the 2010--until now--WoWWWWWWWWWW!!!! Outstanding, unbelievable Link to comment Share on other sites More sharing options...
TX STIG Posted October 29, 2010 Author Report Share Posted October 29, 2010 I have a 2007 GT500 and love the body style. I have never really liked the 2010--until now--WoWWWWWWWWWW!!!! Outstanding, unbelievable Thanks for making me regret selling it. Link to comment Share on other sites More sharing options...
blueovalkid Posted November 6, 2010 Report Share Posted November 6, 2010 Just a few things to keep in mind here, Anyone with a lowered car and is looking to install the nt05 315/35/20 tires may have some clearance issues. the tire is a very tall tire for a 20in. stock tires are 27in tall and the nitto is 28.5 its an inch talling and also almost 2in wider . it may rub in the upper part if the fender well and also the bumpstop bracket if anyone else here has them installed on there car and its lowered, please let us know how they work and if there is any issues I had the 315/35/20 NT05R on my car, and I have the FRPP springs and had no clearance issues at all Link to comment Share on other sites More sharing options...
rsb5772 Posted November 6, 2010 Report Share Posted November 6, 2010 I had the 315/35/20 NT05R on my car, and I have the FRPP springs and had no clearance issues at all Good to know! Do you have any pictures you could send me? My tires will be here in the next few days. I love the way it looks at stock height, but would like to see one a little lower. Link to comment Share on other sites More sharing options...
blueovalkid Posted November 6, 2010 Report Share Posted November 6, 2010 Good to know! Do you have any pictures you could send me? My tires will be here in the next few days. I love the way it looks at stock height, but would like to see one a little lower. Yea I have some I will have to download them and post some. The pic in my sig is with the 305/35/20 555R with the FRPP springs Link to comment Share on other sites More sharing options...
rsb5772 Posted November 6, 2010 Report Share Posted November 6, 2010 Yea I have some I will have to download them and post some. The pic in my sig is with the 305/35/20 555R with the FRPP springs Thanks. Link to comment Share on other sites More sharing options...
6-Speed Posted November 7, 2010 Report Share Posted November 7, 2010 These are the best looking wheels I've seen since noticing the HRE P40 Monoblocks on the Steeda's new Street Fighter Mustang. The F14s are similar in appearance to the P40s as well as the RTR wheels, but come they come in the brushed Ti finish which I really like. Link to comment Share on other sites More sharing options...
rsb5772 Posted November 7, 2010 Report Share Posted November 7, 2010 These are the best looking wheels I've seen since noticing the HRE P40 Monoblocks on the Steeda's new Street Fighter Mustang. The F14s are similar in appearance to the P40s as well as the RTR wheels, but come they come in the brushed Ti finish which I really like. I like them! Much cheaper than the HRE, and more size/offset options than the RTR. Link to comment Share on other sites More sharing options...
2010 Grabber Blue Shelby Posted November 7, 2010 Report Share Posted November 7, 2010 What offsets did you use and: 1.) Did they fit without any cutting? 2.) Did they stick out past the wheel well? Thanks Link to comment Share on other sites More sharing options...
rsb5772 Posted November 7, 2010 Report Share Posted November 7, 2010 What offsets did you use and: 1.) Did they fit without any cutting? 2.) Did they stick out past the wheel well? Thanks I have the wheels, waiting for the tires to come in, and have the same specs as TX Stig. I believe they were +40 front and +53 rear, and it doesn't look like they will be sticking out of the wells. Only downside is that rear tires are expensive for the correct size for an 11" wheel. Link to comment Share on other sites More sharing options...
6-Speed Posted November 8, 2010 Report Share Posted November 8, 2010 I have the wheels, waiting for the tires to come in, and have the same specs as TX Stig. I believe they were +40 front and +53 rear, and it doesn't look like they will be sticking out of the wells. Only downside is that rear tires are expensive for the correct size for an 11" wheel. A few questions: 1. What tire brand and tires are you going to use? 2. Does the stock SVT center cap fit the F14 wheels? Thanks! Link to comment Share on other sites More sharing options...
