2010KonaBlueGT Posted April 16, 2010 Report Share Posted April 16, 2010 I need a little help with a 2010 GT500. Can anyone with a 2010 look at their left (drivers) side, upper radiator shroud bolt to see if there is a nut on the *outside* of the cold air feed tube that runs up to your air filter housing? I noticed yesterday that there is a nut holding the shroud on and then the cold air tube grommet is just sitting on the bolt with no nut holding it on. I want to know if they are all like that and Ford just uses the bolt as a pilot pin or if a nut is missing. The cold air feed tube was loosely sitting on the housing and had a slight rattle. I was able to push it onto the air filter shroud/housing but if a nut is supposed to be there, my dealer will be getting a call. Thanks in advance, Phill Quote Link to comment Share on other sites More sharing options...
DaFreak Posted April 16, 2010 Report Share Posted April 16, 2010 I am in process of adding the IW 10% OD Pulley so I just removed the radiator shroud yesterday. Mine was the same way. DaFreak Quote Link to comment Share on other sites More sharing options...
GAFSoldier Posted April 16, 2010 Report Share Posted April 16, 2010 (edited) Yes looks the same way at my car. Edited April 16, 2010 by GAFSoldier Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted April 16, 2010 Author Report Share Posted April 16, 2010 Thanks for the help/replies. You answerd my question. Phill Quote Link to comment Share on other sites More sharing options...
