breoland Posted May 5, 2010 Report Share Posted May 5, 2010 I dont want to have to do any mods with the 11.75...if 11.5 is good enough i am fine with that. a 315 drag radial should be more than enough Link to comment Share on other sites More sharing options...
Lee N. Posted May 5, 2010 Report Share Posted May 5, 2010 I dont want to have to do any mods with the 11.75...if 11.5 is good enough i am fine with that. a 315 drag radial should be more than enough I do not think you can run a 315 without trimming the bumpstop bracket. Especially since the 315 Nitto DR's are a 35 ratio which is 28.5" tall. A better 315 would be the Toyo 888's. They are a 315/30 which is only 27.6 tall. 28" is about max height unless they are skinny. If you do not want to trim the bracket you had better go 11" and run a 305. Link to comment Share on other sites More sharing options...
BoneDoc Posted May 6, 2010 Report Share Posted May 6, 2010 I do not think you can run a 315 without trimming the bumpstop bracket. Especially since the 315 Nitto DR's are a 35 ratio which is 28.5" tall. A better 315 would be the Toyo 888's. They are a 315/30 which is only 27.6 tall. 28" is about max height unless they are skinny. If you do not want to trim the bracket you had better go 11" and run a 305. agree with Lee. I have 11.75" rim and toyo 315/30. is nearly exact stock height and looks stock from side. I did have to trim bumpstop bracket and remove the dust boot from the shock. Toyos have an aggressive tread and look daunting from the back. Have pretty good bite. Ron Link to comment Share on other sites More sharing options...
Robert M Posted May 6, 2010 Report Share Posted May 6, 2010 agree with Lee. I have 11.75" rim and toyo 315/30. is nearly exact stock height and looks stock from side. I did have to trim bumpstop bracket and remove the dust boot from the shock. Toyos have an aggressive tread and look daunting from the back. Have pretty good bite. Ron Ron - Could you please add some pictures when you have the time? Thanks, Robert Link to comment Share on other sites More sharing options...
BoneDoc Posted May 7, 2010 Report Share Posted May 7, 2010 Link to comment Share on other sites More sharing options...
Lee N. Posted May 7, 2010 Report Share Posted May 7, 2010 [ Ron, Are those the 888's? How do they stick? They look great! Link to comment Share on other sites More sharing options...
marsh2o Posted May 9, 2010 Report Share Posted May 9, 2010 I asked this same question about a year ago, the 10" move to the front........and no one had done this at that time. The 255's (at least in a P zero) seem a little small for the 9" front rims, so I'm sure they would be way small on a 10" front. I am not sure what tire size would work best........if the 10's did in fact fit the front. My choice is to have the front 9's widened to 9.5 while widening the rears to 11.75/11 3/4". I still have a personal issue with cuting the only pair or set of Super Snake logo'ed Alcoa wheels that I will ever have for my car. I would almost prefer to buy the generic SPP Alcoa replacements and have them cut and widened, but then we are quickly heading toward the $4500+ wheel widening project that I mentioned in an above post. The extra set of wheels alone will be $2K plus shipping, and then $1600 + or - for the tires, plus shipping and then the $1000+ for widening front and rear, plus shipping. LOTS of $$$. All of this to preserve the "one time only" Super Snake Alcoa's. R I had some CS40 9" wheels widened to 9.875" and mounted PS2 285/20-20 on the front and they fit fine -- easily with enough room that I could have had the wheels widened to 10". I think the 10" Alcoas w/285/30-20 should also fit without any problem. Link to comment Share on other sites More sharing options...
BoneDoc Posted May 10, 2010 Report Share Posted May 10, 2010 Ron, Are those the 888's? How do they stick? They look great! Thanks Lee. Yes they are R888.... seem to stick very well. Ron Link to comment Share on other sites More sharing options...
gt67 Posted May 10, 2010 Report Share Posted May 10, 2010 I do not think you can run a 315 without trimming the bumpstop bracket. Especially since the 315 Nitto DR's are a 35 ratio which is 28.5" tall. A better 315 would be the Toyo 888's. They are a 315/30 which is only 27.6 tall. 28" is about max height unless they are skinny. If you do not want to trim the bracket you had better go 11" and run a 305. 11'' wheel and 305/30, worked fine for me with room to spare. No trimming and did not have to remove the dust boot from shock. Lee called it right, thanks. Link to comment Share on other sites More sharing options...
Robert M Posted May 10, 2010 Report Share Posted May 10, 2010 11'' wheel and 305/30, worked fine for me with room to spare. No trimming and did not have to remove the dust boot from shock. Lee called it right, thanks. When you installed the 305/30, did your overall diameter get smaller by 1/2"? I researched the 305's a while back and found that while the 305/30 was the same diameter as the front 255/35's they (the 305/30's) were shorter than the original rear 275/35 by approx. 1/2", 27.2" vs. 27.7" overall diameter. R Link to comment Share on other sites More sharing options...
Lee N. Posted May 11, 2010 Report Share Posted May 11, 2010 When you installed the 305/30, did your overall diameter get smaller by 1/2"? I researched the 305's a while back and found that while the 305/30 was the same diameter as the front 255/35's they (the 305/30's) were shorter than the original rear 275/35 by approx. 1/2", 27.2" vs. 27.7" overall diameter. R You are correct. The height is the hard part with a wider tire on these cars. The only two avalable sizes I have found that are wider and the right height is a 315/30/20 (same as stock height) and the 335/30/20 (1/4 taller than stock). Persoanlly I think the 28" tall 335 looks best from the side profile. Both of these will require widening wheels and trimming the bumstop bracket. Link to comment Share on other sites More sharing options...
dbackg Posted June 6, 2010 Report Share Posted June 6, 2010 Ok. You guys win. So I am really close to pulling the trigger. I want to widen my SS wheels too. 11.25 to 11.75" wide? Stock rim/tire setup = 27.7" tall = the stock SS rear is a 275/35/20. on 20" x 10" Alcoas Considering the following rear tire setup. 1. Michelin 335/30/20 PS2. = 28" tall = Lee's setup Cost $491 ea 2. Toyo Proxes R888 315/30/ZR20 = 27.6" tall = BonDoc & Miamimtg setup - Cost $ 385 ea Toyo's website states rim width = 10.5 - 11.5 http://toyotires.com...ern/proxes-r888 3. Dunlop SP Sport Maxx GT 325/30/20 = 27.7" tall - cost $806 ea rim width 11"-12" 4. Pirelli PZero 305/30/ZR20 = 27.2" tall - max rim width 11.5 - cost $ 333 ea rim width 10.5 - 11.5 thanks to the tire calculator: http://ejelta.com/ti...dex.html?ws20=1 Also, what is the drawback from trimming/removing the bumpstop bracket? If I opt to widen to 11.5 and go with the PZero 305's, do you guys think the bumpstop still need trimming? gt67 said: 11'' wheel and 305/30, worked fine with room to spare. No trimming and did not have to remove the dust boot from shock. http://www.teamshelb...es/page__st__37 Thanks for your input.. This should match up great with the project Alex is working on. http://www.teamshelb...des/page__st__0 Thanks Lee. Link to comment Share on other sites More sharing options...
SVTpower Posted June 6, 2010 Report Share Posted June 6, 2010 You are correct. The height is the hard part with a wider tire on these cars. The only two avalable sizes I have found that are wider and the right height is a 315/30/20 (same as stock height) and the 335/30/20 (1/4 taller than stock). Persoanlly I think the 28" tall 335 looks best from the side profile. Both of these will require widening wheels and trimming the bumstop bracket. Hope you don't find me jumping in for some corrections here stock tire is 27.0 305/30 is 27.2 tall 315/30 is 27.6 tall (R888) 335/30 is 28.0 inch tall,( not sure why you say 1/4) and there is a 3rd avail tire, 325/30 which is 27.7 tall. Hope this helps. Link to comment Share on other sites More sharing options...
dbackg Posted June 6, 2010 Report Share Posted June 6, 2010 Hope you don't find me jumping in for some corrections here stock tire is 27.7 - Pirelli PZero - 275/35/20 305/30 is 27.2 tall - Pirelli PZero 315/30 is 27.6 tall (R888) - Toyo 335/30 is 28.0 inch tall - Michelin and there is a 3rd avail tire, 325/30 which is 27.7 tall. Hope this helps. Who makes the 325/30/20 ? Link to comment Share on other sites More sharing options...
BoneDoc Posted June 6, 2010 Report Share Posted June 6, 2010 Who makes the 325/30/20 ? Dunlop.... about $800/tire. i would have bought this one but thats too much for a tire in my opinion. Ron Link to comment Share on other sites More sharing options...
dbackg Posted June 6, 2010 Report Share Posted June 6, 2010 Thanks Ron. duh. I posted that earlier ... already wiped it out of my mind. ha. lol. Agreed. Yes $800 each is way to expensive. Link to comment Share on other sites More sharing options...
SVTpower Posted June 6, 2010 Report Share Posted June 6, 2010 Dunlop.... about $800/tire. i would have bought this one but thats too much for a tire in my opinion. Ron True.....for some, but to me the perfect width and height......... Link to comment Share on other sites More sharing options...
knownukes Posted June 7, 2010 Report Share Posted June 7, 2010 Ok. You guys win. So I am really close to pulling the trigger. I want to widen my SS wheels too. 11.25 to 11.75" wide? Stock rim/tire setup = 27.7" tall = the stock SS rear is a 275/35/20. on 20" x 10" Alcoas Considering the following rear tire setup. 1. Michelin 335/30/20 PS2. = 28" tall = Lee's setup Cost $491 ea 2. Toyo Proxes R888 315/30/ZR20 = 27.6" tall = BonDoc & Miamimtg setup - Cost $ 385 ea Toyo's website states rim width = 10.5 - 11.5 http://toyotires.com...ern/proxes-r888 3. Dunlop SP Sport Maxx GT 325/30/20 = 27.7" tall - cost $806 ea rim width 11"-12" 4. Pirelli PZero 305/30/ZR20 = 27.2" tall - max rim width 11.5 - cost $ 333 ea rim width 10.5 - 11.5 thanks to the tire calculator: http://ejelta.com/ti...dex.html?ws20=1 Also, what is the drawback from trimming/removing the bumpstop bracket? If I opt to widen to 11.5 and go with the PZero 305's, do you guys think the bumpstop still need trimming? gt67 said: 11'' wheel and 305/30, worked fine with room to spare. No trimming and did not have to remove the dust boot from shock. http://www.teamshelb...es/page__st__37 Thanks for your input.. This should match up great with the project Alex is working on. http://www.teamshelb...des/page__st__0 Thanks Lee. I went 11.75 at Lee's advice. This way you have the option to go 305 to 335 if you want. I am currently running 305 P2's because I got a good deal on them. When these are done, I will need a full set and will change to 275 fronts and 335 rears. The 305's did not cause me to trim the dust boot. I did have to adjust the panhard bar as my car was not perfectly centered and it rubbed alittle to the offset side. Once centered I've had no rubbing issues. The 305's are a HUGE improvement over the 275's, but you still can melt the rubber in 1st and 2nd if you are aggressive. I think the extra tire at 335 will help even more. BJ Link to comment Share on other sites More sharing options...
dbackg Posted June 9, 2010 Report Share Posted June 9, 2010 I went 11.75 at Lee's advice. This way you have the option to go 305 to 335 if you want. I am currently running 305 P2's because I got a good deal on them. When these are done, I will need a full set and will change to 275 fronts and 335 rears. The 305's did not cause me to trim the dust boot. I did have to adjust the panhard bar as my car was not perfectly centered and it rubbed alittle to the offset side. Once centered I've had no rubbing issues. The 305's are a HUGE improvement over the 275's, but you still can melt the rubber in 1st and 2nd if you are aggressive. I think the extra tire at 335 will help even more. BJ Michelin Pilot Sport PS2 - 335/30/ZR20 Rim width: 11.5 to 12.5 Specs: http://www.michelinman.com/tire-selector/size/emetric/335/30/20/(Y)/pilot-sport-ps2/tire-details Link to comment Share on other sites More sharing options...
Robert M Posted June 10, 2010 Report Share Posted June 10, 2010 Michelin Pilot Sport PS2 - 335/30/ZR20 Rim width: 11.5 to 12.5 Specs: http://www.michelinman.com/tire-selector/size/emetric/335/30/20/(Y)/pilot-sport-ps2/tire-details I'm surprised that the michelinman.com site does not show complete information for their tire specs. I see the recommended rim with for this 335/30ZR20 is 11.5" - 12.5" and they show a section width (sidewall bulge) of 13.5" "On measuring rim width", but I do not see a mention of what with that "measuring rim width" is, in the 11.5-12.5 range. Tire Rack gives a more complete spec. They list the same info. as Michelin, but they also show that the measuring rim is 12" which means on a 12" rim, the sidewall bulge (section width) will be approx. .75" on each side for the 13.5" total. They also show that the actual tread width of this 335 is 12.5", so the tread itself (not including the sidewall bulge) is approx. 1/4" wider than the 12" measuring rim on each side. Of course if the rim is narrower, like 11.5 or 11.75, the bulge will be a little more and the tread will overlap the rim more, but moving from a 12" to an 11.75" will basically be an additional 1/8" tire bulge on each side, an 11.50" will add 1/8" more to each side. R Link to comment Share on other sites More sharing options...
lcombs Posted June 10, 2010 Author Report Share Posted June 10, 2010 I'm surprised that the michelinman.com site does not show complete information for their tire specs. I see the recommended rim with for this 335/30ZR20 is 11.5" - 12.5" and they show a section width (sidewall bulge) of 13.5" "On measuring rim width", but I do not see a mention of what with that "measuring rim width" is, in the 11.5-12.5 range. Tire Rack gives a more complete spec. They list the same info. as Michelin, but they also show that the measuring rim is 12" which means on a 12" rim, the sidewall bulge (section width) will be approx. .75" on each side for the 13.5" total. They also show that the actual tread width of this 335 is 12.5", so the tread itself (not including the sidewall bulge) is approx. 1/4" wider than the 12" measuring rim on each side. Of course if the rim is narrower, like 11.5 or 11.75, the bulge will be a little more and the tread will overlap the rim more, but moving from a 12" to an 11.75" will basically be an additional 1/8" tire bulge on each side, an 11.50" will add 1/8" more to each side. R just bought new alcoas widened them to 11.750 PUT NITTO NT05R 315/35/R20 on starten to play with tire psi put ps 2 on stock SSrims 295/35/ZR20 didnt have to do anything else to get them to work air ducts had to come off Link to comment Share on other sites More sharing options...
BoneDoc Posted June 10, 2010 Report Share Posted June 10, 2010 just bought new alcoas widened them to 11.750 PUT NITTO NT05R 315/35/R20 on starten to play with tire psi put ps 2 on stock SSrims 295/35/ZR20 didnt have to do anything else to get them to work air ducts had to come off please post pictures when you can. Ron Link to comment Share on other sites More sharing options...
knownukes Posted June 10, 2010 Report Share Posted June 10, 2010 I'm surprised that the michelinman.com site does not show complete information for their tire specs. I see the recommended rim with for this 335/30ZR20 is 11.5" - 12.5" and they show a section width (sidewall bulge) of 13.5" "On measuring rim width", but I do not see a mention of what with that "measuring rim width" is, in the 11.5-12.5 range. Tire Rack gives a more complete spec. They list the same info. as Michelin, but they also show that the measuring rim is 12" which means on a 12" rim, the sidewall bulge (section width) will be approx. .75" on each side for the 13.5" total. They also show that the actual tread width of this 335 is 12.5", so the tread itself (not including the sidewall bulge) is approx. 1/4" wider than the 12" measuring rim on each side. Of course if the rim is narrower, like 11.5 or 11.75, the bulge will be a little more and the tread will overlap the rim more, but moving from a 12" to an 11.75" will basically be an additional 1/8" tire bulge on each side, an 11.50" will add 1/8" more to each side. R [/quo Thnx for the info. I am running the R compound version of this tire on the track and love them. So I will probably try these for the street when the time comes. Good to know that they make a suitable size. BJ Link to comment Share on other sites More sharing options...
Robert M Posted June 10, 2010 Report Share Posted June 10, 2010 I'm surprised that the michelinman.com site does not show complete information for their tire specs. I see the recommended rim with for this 335/30ZR20 is 11.5" - 12.5" and they show a section width (sidewall bulge) of 13.5" "On measuring rim width", but I do not see a mention of what with that "measuring rim width" is, in the 11.5-12.5 range. Tire Rack gives a more complete spec. They list the same info. as Michelin, but they also show that the measuring rim is 12" which means on a 12" rim, the sidewall bulge (section width) will be approx. .75" on each side for the 13.5" total. They also show that the actual tread width of this 335 is 12.5", so the tread itself (not including the sidewall bulge) is approx. 1/4" wider than the 12" measuring rim on each side. Of course if the rim is narrower, like 11.5 or 11.75, the bulge will be a little more and the tread will overlap the rim more, but moving from a 12" to an 11.75" will basically be an additional 1/8" tire bulge on each side, an 11.50" will add 1/8" more to each side. R [/quo Thnx for the info. I am running the R compound version of this tire on the track and love them. So I will probably try these for the street when the time comes. Good to know that they make a suitable size. BJ ------------------------------------------------------------------------------------ I am interested in the fact that a specific tire fits a rim, or rim width range, but I am also interested in how it fits................ a fat/bulgy look?, or flat sidewall?, etc., and then will the overall tire diameter change the way I use my car? Will I be able to use my four passenger Super Snake as a four passenger car? or have I installed a taller tire on the rear (which serves the traction purpose), but because the tire now rubs the fender under certain conditions, I am limited on who or what I can haul in my car? I want more rubber, but it has been identified that a tire of the 28.7 or so overall diameter will contact the rear fender and will require the car to be adjusted higher. This defeats the purpose/look of a lowered four passenger Super Snake. R Link to comment Share on other sites More sharing options...
Robert M Posted June 10, 2010 Report Share Posted June 10, 2010 just bought new alcoas widened them to 11.750 PUT NITTO NT05R 315/35/R20 on starten to play with tire psi put ps 2 on stock SSrims 295/35/ZR20 didnt have to do anything else to get them to work air ducts had to come off Do you have any pictures of the 295/35's on the original 10" SS rims? I have seen 295/35 Nitto Invo's on the 10" Alcoa's, but I am interested in the PS2 fit in that same size. I noticed that the Michelin PS2's are listed as a overall/section width of 11.9" and the Nitto Invo's are listed as 11.6", both are the same size "295/35ZR20", but the PS2's are wider. Thanks, Robert Link to comment Share on other sites More sharing options...
dbackg Posted June 11, 2010 Report Share Posted June 11, 2010 I'm surprised that the michelinman.com site does not show complete information for their tire specs. I see the recommended rim with for this 335/30ZR20 is 11.5" - 12.5" and they show a section width (sidewall bulge) of 13.5" "On measuring rim width", but I do not see a mention of what with that "measuring rim width" is, in the 11.5-12.5 range. Tire Rack gives a more complete spec. They list the same info. as Michelin, but they also show that the measuring rim is 12" which means on a 12" rim, the sidewall bulge (section width) will be approx. .75" on each side for the 13.5" total. They also show that the actual tread width of this 335 is 12.5", so the tread itself (not including the sidewall bulge) is approx. 1/4" wider than the 12" measuring rim on each side. Of course if the rim is narrower, like 11.5 or 11.75, the bulge will be a little more and the tread will overlap the rim more, but moving from a 12" to an 11.75" will basically be an additional 1/8" tire bulge on each side, an 11.50" will add 1/8" more to each side. R Robert. The complete specs are there for Michelin: Michelin 335/30/20 PS2. = 28" tallRim width: 11.5" - 12.5"Info on Michelin Pilot Sport PS2: http://www.michelinm...s2/tire-details You have to scroll down. Click on the "Specs" tab, then click on the "yellow more arrow" to the right. Link to comment Share on other sites More sharing options...
lcombs Posted June 11, 2010 Author Report Share Posted June 11, 2010 Do you have any pictures of the 295/35's on the original 10" SS rims? I have seen 295/35 Nitto Invo's on the 10" Alcoa's, but I am interested in the PS2 fit in that same size. I noticed that the Michelin PS2's are listed as a overall/section width of 11.9" and the Nitto Invo's are listed as 11.6", both are the same size "295/35ZR20", but the PS2's are wider. Thanks, Robert will post them they r off of the car if thats ok or i can put them back on 4 you Link to comment Share on other sites More sharing options...
breoland Posted July 24, 2010 Report Share Posted July 24, 2010 can anyone find the hieght of the nitto 555r (drag radial) in a 305 30 20 Link to comment Share on other sites More sharing options...
bchorney Posted July 24, 2010 Report Share Posted July 24, 2010 can anyone find the hieght of the nitto 555r (drag radial) in a 305 30 20 I don't see that size listed on their website. I can only find the 305/35R20 for the NT555R. It is 28.58". http://www.nittotire.com/ Cheers Brett Link to comment Share on other sites More sharing options...
shelbypt Posted August 13, 2010 Report Share Posted August 13, 2010 Ok. You guys win. So I am really close to pulling the trigger. I want to widen my SS wheels too. 11.25 to 11.75" wide? Stock rim/tire setup = 27.7" tall = the stock SS rear is a 275/35/20. on 20" x 10" Alcoas Considering the following rear tire setup. 1. Michelin 335/30/20 PS2. = 28" tall = Lee's setup Cost $491 ea 2. Toyo Proxes R888 315/30/ZR20 = 27.6" tall = BonDoc & Miamimtg setup - Cost $ 385 ea Toyo's website states rim width = 10.5 - 11.5 http://toyotires.com...ern/proxes-r888 3. Dunlop SP Sport Maxx GT 325/30/20 = 27.7" tall - cost $806 ea rim width 11"-12" 4. Pirelli PZero 305/30/ZR20 = 27.2" tall - max rim width 11.5 - cost $ 333 ea rim width 10.5 - 11.5 thanks to the tire calculator: http://ejelta.com/ti...dex.html?ws20=1 Also, what is the drawback from trimming/removing the bumpstop bracket? If I opt to widen to 11.5 and go with the PZero 305's, do you guys think the bumpstop still need trimming? gt67 said: 11'' wheel and 305/30, worked fine with room to spare. No trimming and did not have to remove the dust boot from shock. http://www.teamshelb...es/page__st__37 Thanks for your input.. This should match up great with the project Alex is working on. http://www.teamshelb...des/page__st__0 Thanks Lee. OK, this is the question I have, which Lee wrote but was not answered. If we go with 11.5" wide Alocoa and a 305/30/20 tire, will we need to trim the bump stop or shock boot? Or is 11" the widest? I don't want to cut anything up on my KR or effect the ride with a passenger. Thanks, Gary Link to comment Share on other sites More sharing options...
