HISS OFF Posted April 13, 2010 Report Share Posted April 13, 2010 Everytime I wash "IMOAN" especially at a touch free car wash, to knock off road grim. Water will continously leak out from under the rear spoiler (driver side) corner. I washed her a week and a half ago and each time I open the trunk which has been often, her it comes again leaving water spots. 2010 model GT500. Anyone else seen this? Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted April 13, 2010 Report Share Posted April 13, 2010 Everytime I wash "IMOAN" especially at a touch free car wash, to knock off road grim. Water will continously leak out from under the rear spoiler (driver side) corner. I washed her a week and a half ago and each time I open the trunk which has been often, her it comes again leaving water spots. 2010 model GT500. Anyone else seen this? I have a 2010 and use a touchless car wash too. I get a 'initial' drain when I first open the trunk but that's it. And not much, a line that runs down/up the trunk and drips a few drips. Nothing like what you are reporting... Phill Link to comment Share on other sites More sharing options...
HISS OFF Posted April 14, 2010 Author Report Share Posted April 14, 2010 I have a 2010 and use a touchless car wash too. I get a 'initial' drain when I first open the trunk but that's it. And not much, a line that runs down/up the trunk and drips a few drips. Nothing like what you are reporting... Phill Thanks Phil, I bet I have pulled a quarter to a half of cup of water. Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted April 14, 2010 Report Share Posted April 14, 2010 Thanks Phil, I bet I have pulled a quarter to a half of cup of water. That sounds like a lot. Mine might be as much as 1/2 ounce. Maybe. Phill Link to comment Share on other sites More sharing options...
HISS OFF Posted September 28, 2010 Author Report Share Posted September 28, 2010 Man, it is still doing it, I can leave on travel for 10-18 days come back, open the trunk and here it comes again. Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted September 28, 2010 Report Share Posted September 28, 2010 Man, it is still doing it, I can leave on travel for 10-18 days come back, open the trunk and here it comes again. I used a touchless pressure type wash the last two times I washed my car. BOTH times I had water INSIDE the trunk, on the back panel. Last time seemed like more than the time before. But I also said maybe a half ounce to a ounce comes out of the wing. Not anymore. Not nearly as much as yours but I keep my towels in the trunk so I'd open and close it with a change of towels. That sucker leaked every time I opened it and then when I thought it was empty, it leaked more while the car was sitting in the garage and now I have two drip lines running down the rear panel at each corner of the spoiler wing. I'm thinking about pulling it off and trying to seal it but I suppose you need a air vent somewhere for heat expansion. It's a pisser, and getting worse (in my case). It MUST have something to do with the wash we use. When I garden hose wash it, I don't get any drips. Well, except the front nose where the two "down tubes" are on either side of the grill. THAT drives me goofy too! Phill Link to comment Share on other sites More sharing options...
