92fxdc Posted April 3, 2010 Report Share Posted April 3, 2010 Looking for stainless steel or chromed Door Prop Rods to hold the doors open at car shows. Has anyone found a set that works for the 07-09 GT500? Link to comment Share on other sites More sharing options...
Ford Fest Posted September 20, 2014 Report Share Posted September 20, 2014 Looking for stainless steel or chromed Door Prop Rods to hold the doors open at car shows. Has anyone found a set that works for the 07-09 GT500? Bump Link to comment Share on other sites More sharing options...
Shelby73 Posted September 24, 2014 Report Share Posted September 24, 2014 Looking for some as well Link to comment Share on other sites More sharing options...
KCMO-GT500 Posted September 25, 2014 Report Share Posted September 25, 2014 I used a set of these...... http://www.summitracing.com/parts/hfm-bcprop?seid=srese1&gclid=CKLi8Pnp_MACFYMF7Aod1DoA-A don't use any of the spacers and use a dremel tool to cut about 1 inch off the side of each loop so it will slide into the car door retainer loop......... Link to comment Share on other sites More sharing options...
Ford Fest Posted September 27, 2014 Report Share Posted September 27, 2014 I used a set of these...... http://www.summitracing.com/parts/hfm-bcprop?seid=srese1&gclid=CKLi8Pnp_MACFYMF7Aod1DoA-A don't use any of the spacers and use a dremel tool to cut about 1 inch off the side of each loop so it will slide into the car door retainer loop......... Thank you sir Link to comment Share on other sites More sharing options...
