MikeCMM Posted March 25, 2010 Report Share Posted March 25, 2010 Gentlemen - I have a C6AE-B top oiler 427 block. Most books I've looked at claim that this block is suppose to be a side oiler. Mine does not have the two gallery plugs in the back of the block machined. My question to you guys is: did Ford make this casting both ways or do I have some kind of machining error? Here is a picture. Any help would be appreciated. Thanks Link to comment Share on other sites More sharing options...
BlueDjinn Posted June 25, 2010 Report Share Posted June 25, 2010 C6AE-B is the correct serial number for a block destined to be a 427 side oiler; 1965-1966. Top oiler blocks and side oiler blocks were two separate productions. Occasionally a side oiler block with production issues was drilled by the factory as a top oiler to rescue the block; so, no your block is not a mistake in machining. It was quite deliberate by the factory. It doesn't happen a lot, but that's what you've got there. That the block retains the side oiler serial number puts a little mystery into it. Now it's a factory amended top oiler 427. Link to comment Share on other sites More sharing options...
