CSX4350 Posted March 20, 2010 Report Share Posted March 20, 2010 CSX4350 is about 2 years old and I've been complaining of weak brakes since day 1. Today I put the car on the lift to adjust the parking brake, and gave the car a good once over while it was in the air. What I saw scared the crap out of me. The front rotors are deeply grooved on the inside, like the brakes have been metal to metal for a long time. I spun the tires and they spin with only normal disc brake drag, but the brakes make a sickening grinding noise. I pulled the wheels and was really surprised to see the outside of the rotors are absolutely brand new, the crosshatching is still perfectly visible. I assume that the calipers aren't floating properly, they were possibly assembled wrong at SAI. That doesn't really explain the gouged rotors though. I will have to take it all apart and see what is actually going on. My questions are: What are these brakes originally from? What pads fit the calipers, an even bigger question is what are the best pads? I don't know if the rotors are salvagable, I think so but I'm not sure. If I need new rotors what is the original fitment for those? An even better question, is there an upgraded rotor available, and an upgraded caliper? They would have to fit the original wheels, I don't want to change wheels. TIA Link to comment Share on other sites More sharing options...
GT500-07 Posted March 20, 2010 Report Share Posted March 20, 2010 CSX4350 is about 2 years old and I've been complaining of weak brakes since day 1. Today I put the car on the lift to adjust the parking brake, and gave the car a good once over while it was in the air. What I saw scared the crap out of me. The front rotors are deeply grooved on the inside, like the brakes have been metal to metal for a long time. I spun the tires and they spin with only normal disc brake drag, but the brakes make a sickening grinding noise. I pulled the wheels and was really surprised to see the outside of the rotors are absolutely brand new, the crosshatching is still perfectly visible. I assume that the calipers aren't floating properly, they were possibly assembled wrong at SAI. That doesn't really explain the gouged rotors though. I will have to take it all apart and see what is actually going on. My questions are: What are these brakes originally from? What pads fit the calipers, an even bigger question is what are the best pads? I don't know if the rotors are salvagable, I think so but I'm not sure. If I need new rotors what is the original fitment for those? An even better question, is there an upgraded rotor available, and an upgraded caliper? They would have to fit the original wheels, I don't want to change wheels. TIA give Bill a call, he can answer all your questions. he fixed my brakes with better pads HRE Motorcars 516-378-5461 Link to comment Share on other sites More sharing options...
CSX4350 Posted March 20, 2010 Author Report Share Posted March 20, 2010 The plot thickens, I understand that several cars, even glass cars, have had similar problems. A preliminary inspection of the brakes revealed: The bearings were loose, I was able to remove the nut by hand. Luckily, the bearings themselves look good. When I started to tighten the nut the rotor was pressed into the inner brake pad and locked the rotor up. There is something seriously wrong with the relationship between the caliper, bracket and rotor. The caliper is not moving on the bracket at all, it is locked up tight. It is obvious that the outside of the rotor has never seen any pressure from the brakes, it has definitely been this way from day one. The caliper bracket is actually hitting the back of the rotor, that's what caused the scoring. Both fronts are exactly the same, the rears appear to be functioning normally. Even though the car is two years old, I hope SAI stands behind this. Link to comment Share on other sites More sharing options...
csx4910 Posted March 21, 2010 Report Share Posted March 21, 2010 The plot thickens, I understand that several cars, even glass cars, have had similar problems. A preliminary inspection of the brakes revealed: The bearings were loose, I was able to remove the nut by hand. Luckily, the bearings themselves look good. When I started to tighten the nut the rotor was pressed into the inner brake pad and locked the rotor up. There is something seriously wrong with the relationship between the caliper and bracket. The caliper is not moving on the bracket at all, it is locked up tight. It is obvious that the outside of the rotor has never seen any pressure from the brakes, it has definitely been this way from day one. The caliper bracket is actually hitting the back of the rotor, that's what caused the scoring. Both fronts are exactly the same, the rears appear to be functioning normally. Even though the car is two years old, I hope SAI stands behind this. I have never heard of any warranty with the csx cars from shelby. I would like to know if there is one. My emergancy brake broke today. i pulled it up and it would hold and also wouldnt go back down to the normal position. I also have a faulty gas guage and fuel pickup, it is high and to the left instead of the center so when I go around a sharp corner and give it gas it hesitates. Unfortunatly, there isnt a shelby dealer anywhere in the Phoenix/Tucson area. Ron Link to comment Share on other sites More sharing options...
GT500-07 Posted March 21, 2010 Report Share Posted March 21, 2010 The plot thickens, I understand that several cars, even glass cars, have had similar problems. A preliminary inspection of the brakes revealed: The bearings were loose, I was able to remove the nut by hand. Luckily, the bearings themselves look good. When I started to tighten the nut the rotor was pressed into the inner brake pad and locked the rotor up. There is something seriously wrong with the relationship between the caliper, bracket and rotor. The caliper is not moving on the bracket at all, it is locked up tight. It is obvious that the outside of the rotor has never seen any pressure from the brakes, it has definitely been this way from day one. The caliper bracket is actually hitting the back of the rotor, that's what caused the scoring. Both fronts are exactly the same, the rears appear to be functioning normally. Even though the car is two years old, I hope SAI stands behind this. stand in line Link to comment Share on other sites More sharing options...
GT500-07 Posted March 21, 2010 Report Share Posted March 21, 2010 I have never heard of any warranty with the csx cars from shelby. I would like to know if there is one. My emergancy brake broke today. i pulled it up and it would hold and also wouldnt go back down to the normal position. I also have a faulty gas guage and fuel pickup, it is high and to the left instead of the center so when I go around a sharp corner and give it gas it hesitates. Unfortunatly, there isnt a shelby dealer anywhere in the Phoenix/Tucson area. Ron same here, faulty gas guage and fuel pick up among other major issues. still waiting to here from the dealer or SA Link to comment Share on other sites More sharing options...
csx4910 Posted March 21, 2010 Report Share Posted March 21, 2010 same here, faulty gas guage and fuel pick up among other major issues. still waiting to here from the dealer or SA My dealer went out of business but I have searched through everything I have and nothing about a warranty or even a manual (I gave up on that one) Link to comment Share on other sites More sharing options...
GT500-07 Posted March 22, 2010 Report Share Posted March 22, 2010 My dealer went out of business but I have searched through everything I have and nothing about a warranty or even a manual (I gave up on that one) interesting, so did the dealer I delt with. contact SA Shelby American, Inc. Attn: Gary Patterson 6755 Speedway Boulevard Las Vegas, Nevada 89115 Tel: (702) 942-REAL Fax: (702) 93-COBRA Email: garyp@shelbyamerican.com Link to comment Share on other sites More sharing options...
dcdoug Posted March 30, 2010 Report Share Posted March 30, 2010 My dealer went out of business but I have searched through everything I have and nothing about a warranty or even a manual (I gave up on that one) All Shelby Cobras have a 6 month warranty on them I believe. Sounds like you would be well past that date anyway, but that was the warranty period. Link to comment Share on other sites More sharing options...
twobjshelbys Posted March 30, 2010 Report Share Posted March 30, 2010 It appears that the warranty is on the roller. It seems universal. On the Cobra site there is a fellow with a Superformance with basic roller issues. In some and maybe most cases, by the time the roller is sent to the power train installer and the car finished the roller warranty will be over. I don't know what can be done except to budget some amount of money to cover it afterwards. I think I've seen most are willing to cover the parts but labor is on you. My fuel tank gauge doesn't work either. When I get it back from Roush that will be the next project. I think the calibration is off. When it finally comes off full it flutters around alot and by reckoning it's about 1/4. Reminds me that I need to check with Bud/Gary about it. Link to comment Share on other sites More sharing options...
dcdoug Posted March 30, 2010 Report Share Posted March 30, 2010 My fuel tank gauge doesn't work either. When I get it back from Roush that will be the next project. I think the calibration is off. When it finally comes off full it flutters around alot and by reckoning it's about 1/4. Reminds me that I need to check with Bud/Gary about it. The calibration is pretty easy to do, but it still won't be very accurate. Mine is perfectly calibrated now (I did it twice to be sure), but because the tube with the sensor is mounted 1/2 way down the bladder and points down, the gauge doesn't read anything for the first 3/4 of a tank or so. The first reading you get is a fluctuation of the gauge when you accelerate as the gas sloshes around. It is probably like the fluttering you are talking about. That happens for a while and then the gauge starts to move off of full. At that point, head to a gas station as you are probably at about 1/8 of a tank or so.....It's not a great set-up, but it is a reminder that you need to get gas.... Link to comment Share on other sites More sharing options...
CSX4350 Posted March 30, 2010 Author Report Share Posted March 30, 2010 ^^^^^^^^^^^^^^ What he said, I was warned right off the bat by my builder that the fuel gauge was useless. I have never seen it move off of full, consider it that when it does move off full you need to start thinking about fuel. On an up note, SAI is working with me on my brake problems. It seems that my spindles were improperly shimmed onto my uprights, causing the rotor to be too far inward. It has happened a few times before, my understanding is that SAI buys this already assembled by an outside supplier. They are taking care of repairing or replacing the parts, I had to take them off & send them back. Link to comment Share on other sites More sharing options...
