Cali_KR Posted March 25, 2010 Report Share Posted March 25, 2010 16k miles, have the typical mods, CAI, pulley, tune, axle backs etc. and not a hitch. A little stiff in the morning (allright wicked, no saucy comments here), but once she warms up....purrrr Link to comment Share on other sites More sharing options...
shelbypt Posted March 26, 2010 Report Share Posted March 26, 2010 I only have 1300 miles on my 08KR, and my clutch is great! Link to comment Share on other sites More sharing options...
GAGT500 Posted March 26, 2010 Report Share Posted March 26, 2010 08 Mustang, not a bad looking ride; but not nearly as pretty as my 08 SGT500'vert! LOL Have registered on here and waiting for mailing address to send check and remittance ticket? Only 1000mi on my 08 since Aug 09, so probably way too soon according to most posts here! CL it's your bud JB here! Link to comment Share on other sites More sharing options...
slbgtsc Posted March 27, 2010 Report Share Posted March 27, 2010 I'm at 2500 miles and same rwhp [700]. Stock clutch works perfectly. I'm currently pulling the trans and installing the shelby shifter and un-sure on the Spec P trim, or McLeod clutch. I won't have the funds until next month [ 1500.00 ] so for now just gaining knowledge. FWIW the guys over at Lethal are the best. while you have the tranny out replace the cheap plastic hose that runs from the master cylinder to the slave unit with the upgraded braided hose, and put sythetic fluid in the system. I have an 07 SGT that is SC'd and I am on my 3rd clutch. If you track your car at all this is a must do mod. CJ's has it for $179, blue collar has it for $225 Link to comment Share on other sites More sharing options...
GAGT500 Posted March 27, 2010 Report Share Posted March 27, 2010 SLB, sounds like a good idea: but would like to know where you've learned of this? Admittedly a newbie here; but good friend has been on this board for some time, we've talked at length about clutch issues; but not mentioned yet? How hard to do this a "preventative" measure without dropping tranny? Does fluid suggested deviate from Ford spec with potential warranty concerns? Thanks for post! Link to comment Share on other sites More sharing options...
slbgtsc Posted March 28, 2010 Report Share Posted March 28, 2010 SLB, sounds like a good idea: but would like to know where you've learned of this? Admittedly a newbie here; but good friend has been on this board for some time, we've talked at length about clutch issues; but not mentioned yet? How hard to do this a "preventative" measure without dropping tranny? Does fluid suggested deviate from Ford spec with potential warranty concerns? Thanks for post! Between myself and another buddy we have gone through about 6-8 clutches. He ran his at the drag strip and tried several different brands of clutches. He has his own performance company called Bluecollar Performance and he has a very nice write up about the clutches in our cars based on his experience at the track. He now spends most of his time on the road course. He also knows someone at Ford Racing who told him about the braided line. Evidently the FR500 was also having clutch issues due to heat boiling the fluid in the line from the master cylinder to the slave unit this causes the clutch to stay engaged end result a dead clutch. My stock clutch did not hold up well once I supercharged my car. It would hold 1st okay but the shift to 2nd would result in it driving through the clutch. I went with a spec 2+ it lasted all of 500 miles. Removed it and replaced it with a zoom dual disc and a ram slave unit. After another 500 miles the zoom went too. Found out that the mechanic who installed the Ram slave unit did so incorrectly which caused the zoom clutch to fail. Went back to the spec 2+ (warranty replacement) and now with high temp fluid, a good break in it is holding up well. Found out about the braided line too late to have it installed. It will be in the next time the tranny comes out. I don't think the line can be done without dropping the tranny. The fluid to my knowledge does not void the warranty, in fact if memory serves it is now recomended. hope this helps. Link to comment Share on other sites More sharing options...
GAGT500 Posted March 28, 2010 Report Share Posted March 28, 2010 Slb, thanks for posting such a helpful, detailed reply! Will be keeping for future reference should I need a replacement! Link to comment Share on other sites More sharing options...
Alexandros Posted March 29, 2010 Report Share Posted March 29, 2010 Between myself and another buddy we have gone through about 6-8 clutches. He ran his at the drag strip and tried several different brands of clutches. He has his own performance company called Bluecollar Performance and he has a very nice write up about the clutches in our cars based on his experience at the track. He now spends most of his time on the road course. He also knows someone at Ford Racing who told him about the braided line. Evidently the FR500 was also having clutch issues due to heat boiling the fluid in the line from the master cylinder to the slave unit this causes the clutch to stay engaged end result a dead clutch. My stock clutch did not hold up well once I supercharged my car. It would hold 1st okay but the shift to 2nd would result in it driving through the clutch. I went with a spec 2+ it lasted all of 500 miles. Removed it and replaced it with a zoom dual disc and a ram slave unit. After another 500 miles the zoom went too. Found out that the mechanic who installed the Ram slave unit did so incorrectly which caused the zoom clutch to fail. Went back to the spec 2+ (warranty replacement) and now with high temp fluid, a good break in it is holding up well. Found out about the braided line too late to have it installed. It will be in the next time the tranny comes out. I don't think the line can be done without dropping the tranny. The fluid to my knowledge does not void the warranty, in fact if memory serves it is now recomended. hope this helps. Thanks for the info.... Link to comment Share on other sites More sharing options...
bimrock Posted April 1, 2010 Report Share Posted April 1, 2010 you all need to drive your babies more. They are not meant to be in the garage except for perfect days. I have 23000 on mine and the clutch is fine. Everyone drives differently and that has a huge determination as to how long the clutch will last/. If you ride the clutch and slowly disengage it will have half the life of someone who quickly releases it and just goes./ Link to comment Share on other sites More sharing options...
SnakeGoat Posted August 18, 2012 Report Share Posted August 18, 2012 2011, gt500 svt white with stripe delete and had clutch replaced with only 4,000 miles. Ford not helping- stating "normal were and tear" - I am dissapointed but plan to take action. Link to comment Share on other sites More sharing options...
awakeinAZ Posted August 18, 2012 Report Share Posted August 18, 2012 8 k miles on an 07 and none yet! Link to comment Share on other sites More sharing options...
Grabber Posted August 18, 2012 Report Share Posted August 18, 2012 2011, gt500 svt white with stripe delete and had clutch replaced with only 4,000 miles. Ford not helping- stating "normal were and tear" - I am dissapointed but plan to take action. What mods do you have ? Link to comment Share on other sites More sharing options...
Aerowrench Posted August 18, 2012 Report Share Posted August 18, 2012 I swapped over here from the "Ford GT500 Discussions Forum". I get the impression there's not many techs over there, lots of polishers and posers though. To answer your question I have 66,771 miles on my 2007 Shelby GT 500. Yup, you read that right. I've had no problems so far with my clutch. It's a daily driver, I bought it used from a dealer with 44K miles and the original owner was an adult woman. I've been to the drags twice with it, once at the 2011 Shelby meet in Tulsa and another on Test & Tune night. Both times I couldn't hook up on street tires, the Shelby meet was 103 degrees so that was a blow out too. At this point I'm looking for a clutch as mine is fading and engages at the last point of pedal travel. Haven't decided to go aftermarket or 2010 Ford. ps- I'm an Airline Mechanic with 32 yrs experience and do almost all my own maintenance. Our local GT500 guru here in NE Oklahoma - Mike Mayopolis of Pinnacle Perf. www.pinnaclerepairs.com seems to think I hold some kind of record for a 2007 clutch. I'll most likely have him swap it out. Bench pressing a Tremec sucks, T5's I can handle. Link to comment Share on other sites More sharing options...
Secondo Posted August 18, 2012 Report Share Posted August 18, 2012 '07 GT500 built 12/06, 32K miles, 556whp, original clutch, NO issues. Drag racing and tracked recreationally. Link to comment Share on other sites More sharing options...
bpodner Posted August 19, 2012 Report Share Posted August 19, 2012 21000 miles on my 2009 GT500 when I traded it in. 11000 miles on my 2011 GT500 and not a problem with either one. Link to comment Share on other sites More sharing options...
ironmedn Posted August 19, 2012 Report Share Posted August 19, 2012 '08 stock w/ 16K miles...no problems with slipping. I have noticed a tough 1-2 shift when cold...smooth as silk when it warms up. Also, I do have a noticeable vibration on the shifter in 5th but both symptoms were present when I bought it new in 08. I just assumed it was normal for this make/model. Link to comment Share on other sites More sharing options...
Kevin Patten Posted August 19, 2012 Report Share Posted August 19, 2012 07 - 9,000 miles (mostly road course track days) and doing fine. Link to comment Share on other sites More sharing options...
gearhead09 Posted August 19, 2012 Report Share Posted August 19, 2012 19,500 2009 gt500 with the pulley, intake and tune with the afco h/e when its nice out I give her hell... original clutch only thing is you get the chatter if your not use too how it engages. Took me a little bit to learn the clutch but runs well now. I am highly impressed with the mileage im getting out of mine because peoples fail so much earlier i hear. Link to comment Share on other sites More sharing options...
tradde Posted August 19, 2012 Report Share Posted August 19, 2012 20000 miles 2007 fairly stock all still good. Link to comment Share on other sites More sharing options...
sweenstang Posted August 20, 2012 Report Share Posted August 20, 2012 2012 bone stock with 7K miles. No problems except after it sits for a week or more, I experience mild chatter for the first ~10 engages, but then it smoothes out and dissapears. Anybody know what's causing that? Link to comment Share on other sites More sharing options...
dlangvardt Posted August 26, 2012 Report Share Posted August 26, 2012 Update, 2007 purchased new September 2006. It still has the original clutch with 36,000 miles. Link to comment Share on other sites More sharing options...
05mustangman Posted August 26, 2012 Report Share Posted August 26, 2012 15k miles on my 2010 and no problems here. Link to comment Share on other sites More sharing options...
Airrage Posted October 30, 2016 Report Share Posted October 30, 2016 My 2014gt500 clutch is starting to slip between 3rd & 4th gears on acceleration, only 13,000mi Link to comment Share on other sites More sharing options...
NorthSnake Posted November 23, 2016 Report Share Posted November 23, 2016 2009 Convertible 654rwhp 19k miles and no issues yet. I have an RXT sitting in the garage waiting for the day the stock clutch will die and give my sore knee a break .... Link to comment Share on other sites More sharing options...
