Cali_KR Posted March 10, 2010 Report Share Posted March 10, 2010 Posting this for a friend. A little about Kevin, he runs a high end motorsports shop, so the man knows his way around with a wrench. This is his personal car, and it is built right. Contact Kevin directly for specifics. Check out the extensive list of mods... There are more than a few TS members here that can vouch for Kevin and the work he does... I am selling the 2008 Bullitt Mustang #663 of 7700 made for the 2008-2009 model year . The car currently has 6,400+ miles on it. The following is a list of add-on parts ; BODY Agent 47 Lower Grille SHR Lower Grille Inserts 8 Black Shorty Antenna 68 Style Rear Upper Side Louvers Aluminum Trimmed Rear Medallion SR Black Taillight Trim TIRES AND WHEELS 18x9 Shelby Torque Thrust M in Black (FRONT) with 255/45-18 Yokohama Advan Sport Radial Tires 18x10 Shelby Torque Thrust M in Black (REAR) with 285/40-18 Yokohama Advan Sport Radial Tires Custom Made BULLITT Center Caps and Valve Stem Caps SUSPENSION AND BRAKES H&R Street Performance Coilover Conversion Maximum Motorsports Adjustable Caster/Camber Plates BMR Fabrication Rear Lower Boxed Control Arms and Relocation Brackets BMR Fabrication Rear Upper Adjustable 3rd Link and HD Mount Bracket BMR Fabrication Panard Bar Relocation Bracket and HD Boxed Panard Bar Support Arm Hotchkis Adjustable Panard Bar Hotchkis 1.5 Adjustable Front Sway Bar Hotchkis 1.0 Adjustable Rear Sway Bar Power Slot Front and Rear Gas Slotted Rotors HAWK HPS Performance Front and Rear Brake Pads Agent 47 Front Brake Ducting Kit DRIVELINE BBK Aluminum/SFI-Rated Power Pulley Set STEEDA Carbon Fiber CAI Elbow Inlet Prothane Aluminum/Polyurethane Motor Mounts Fidanza Aluminum Flywheel Coast Driveline 3.5 One-Piece Aluminum Driveshaft HURST Competition Plus Shifter Moser Low Profile Aluminum Differential Girdle/Cover ENGINE COMPARTMENT Midwest Auto Gear Radiator Support Cover Extensions DRAKE Aluminum Windshield Washer Tank Cap MOROSO Aluminum Coolant Expansion Tank CPC Ribbed Fuse Box Cover FRPP Ribbed Intake Manifold Plenum Cover FRPP Chrome Valve Covers Kirban Performance Engine Oil Cap Chrome Trim Ring UPR Billet Aluminum Brake Master Cylinder Cap DRAKE Aluminum Battery Hold Down Bracket Kit SHR Hood Support Struts INTERIOR DRAKE Satin Door Lock Pin Set BULLITT Power Plug Cover BULLITT Engraved Center Console Billet Aluminum Cup Holder Trim Panel The color of the car is Dark Highland Green with a Dark Charcoal Interior and is registered in the International Mustang Bullitt Owners Club Registry. Chassis Dyno results showed 335RWHP and 354LBS RWT . Selling Price is $35,900 USD. Kevin Patten Performance Art/ General Manager (408) 848-6325 (408) 848-6349 fax www.performanceartonline.com 5755-B Rossi Lane Gilroy, CA 95020 Link to comment Share on other sites More sharing options...
Cali_KR Posted March 29, 2010 Author Report Share Posted March 29, 2010 Posting this for a friend. A little about Kevin, he runs a high end motorsports shop, so the man knows his way around with a wrench. This is his personal car, and it is built right. Contact Kevin directly for specifics. Check out the extensive list of mods... There are more than a few TS members here that can vouch for Kevin and the work he does... I am selling the 2008 Bullitt Mustang #663 of 7700 made for the 2008-2009 model year . The car currently has 6,400+ miles on it. The following is a list of add-on parts ; BODY Agent 47 Lower Grille SHR Lower Grille Inserts 8” Black Shorty Antenna 68 Style Rear Upper Side Louvers Aluminum Trimmed Rear Medallion SR Black Taillight Trim TIRES AND WHEELS 18”x9” Shelby Torque Thrust M in Black (FRONT) with 255/45-18 Yokohama Advan Sport Radial Tires 18”x10” Shelby Torque Thrust M in Black (REAR) with 285/40-18 Yokohama Advan Sport Radial Tires Custom Made “BULLITT” Center Caps and Valve Stem Caps SUSPENSION AND BRAKES H&R Street Performance Coilover Conversion Maximum Motorsports Adjustable Caster/Camber Plates BMR Fabrication Rear Lower Boxed Control Arms and Relocation Brackets BMR Fabrication Rear Upper Adjustable 3rd Link and HD Mount Bracket BMR Fabrication Panard Bar Relocation Bracket and HD Boxed Panard Bar Support Arm Hotchkis Adjustable Panard Bar Hotchkis 1.5” Adjustable Front Sway Bar Hotchkis 1.0” Adjustable Rear Sway Bar Power Slot Front and Rear Gas Slotted Rotors HAWK HPS Performance Front and Rear Brake Pads Agent 47 Front Brake Ducting Kit DRIVELINE BBK Aluminum/SFI-Rated Power Pulley Set STEEDA Carbon Fiber CAI Elbow Inlet Prothane Aluminum/Polyurethane Motor Mounts Fidanza Aluminum Flywheel Coast Driveline 3.5” One-Piece Aluminum Driveshaft HURST Competition Plus Shifter Moser Low Profile Aluminum Differential Girdle/Cover ENGINE COMPARTMENT Midwest Auto Gear Radiator Support Cover Extensions DRAKE Aluminum Windshield Washer Tank Cap MOROSO Aluminum Coolant Expansion Tank CPC Ribbed Fuse Box Cover FRPP Ribbed Intake Manifold Plenum Cover FRPP Chrome Valve Covers Kirban Performance Engine Oil Cap Chrome Trim Ring UPR Billet Aluminum Brake Master Cylinder Cap DRAKE Aluminum Battery Hold Down Bracket Kit SHR Hood Support Struts INTERIOR DRAKE Satin Door Lock Pin Set “BULLITT” Power Plug Cover “BULLITT” Engraved Center Console Billet Aluminum Cup Holder Trim Panel The color of the car is Dark Highland Green with a Dark Charcoal Interior and is registered in the International Mustang Bullitt Owners Club Registry. Chassis Dyno results showed 335RWHP and 354LBS RWT . Selling Price is $35,900 USD. Kevin Patten Performance Art/ General Manager (408) 848-6325 (408) 848-6349 fax www.performanceartonline.com 5755-B Rossi Lane Gilroy, CA 95020 Bump Link to comment Share on other sites More sharing options...
sportscars Posted March 30, 2010 Report Share Posted March 30, 2010 I love the Bullitt look! Wish I had the cash for that. Link to comment Share on other sites More sharing options...
Cali_KR Posted May 1, 2010 Author Report Share Posted May 1, 2010 Posting this for a friend. A little about Kevin, he runs a high end motorsports shop, so the man knows his way around with a wrench. This is his personal car, and it is built right. Contact Kevin directly for specifics. Check out the extensive list of mods... There are more than a few TS members here that can vouch for Kevin and the work he does... I am selling the 2008 Bullitt Mustang #663 of 7700 made for the 2008-2009 model year . The car currently has 6,400+ miles on it. The following is a list of add-on parts ; BODY Agent 47 Lower Grille SHR Lower Grille Inserts 8” Black Shorty Antenna 68 Style Rear Upper Side Louvers Aluminum Trimmed Rear Medallion SR Black Taillight Trim TIRES AND WHEELS 18”x9” Shelby Torque Thrust M in Black (FRONT) with 255/45-18 Yokohama Advan Sport Radial Tires 18”x10” Shelby Torque Thrust M in Black (REAR) with 285/40-18 Yokohama Advan Sport Radial Tires Custom Made “BULLITT” Center Caps and Valve Stem Caps SUSPENSION AND BRAKES H&R Street Performance Coilover Conversion Maximum Motorsports Adjustable Caster/Camber Plates BMR Fabrication Rear Lower Boxed Control Arms and Relocation Brackets BMR Fabrication Rear Upper Adjustable 3rd Link and HD Mount Bracket BMR Fabrication Panard Bar Relocation Bracket and HD Boxed Panard Bar Support Arm Hotchkis Adjustable Panard Bar Hotchkis 1.5” Adjustable Front Sway Bar Hotchkis 1.0” Adjustable Rear Sway Bar Power Slot Front and Rear Gas Slotted Rotors HAWK HPS Performance Front and Rear Brake Pads Agent 47 Front Brake Ducting Kit DRIVELINE BBK Aluminum/SFI-Rated Power Pulley Set STEEDA Carbon Fiber CAI Elbow Inlet Prothane Aluminum/Polyurethane Motor Mounts Fidanza Aluminum Flywheel Coast Driveline 3.5” One-Piece Aluminum Driveshaft HURST Competition Plus Shifter Moser Low Profile Aluminum Differential Girdle/Cover ENGINE COMPARTMENT Midwest Auto Gear Radiator Support Cover Extensions DRAKE Aluminum Windshield Washer Tank Cap MOROSO Aluminum Coolant Expansion Tank CPC Ribbed Fuse Box Cover FRPP Ribbed Intake Manifold Plenum Cover FRPP Chrome Valve Covers Kirban Performance Engine Oil Cap Chrome Trim Ring UPR Billet Aluminum Brake Master Cylinder Cap DRAKE Aluminum Battery Hold Down Bracket Kit SHR Hood Support Struts INTERIOR DRAKE Satin Door Lock Pin Set “BULLITT” Power Plug Cover “BULLITT” Engraved Center Console Billet Aluminum Cup Holder Trim Panel The color of the car is Dark Highland Green with a Dark Charcoal Interior and is registered in the International Mustang Bullitt Owners Club Registry. Chassis Dyno results showed 335RWHP and 354LBS RWT . Selling Price is $35,900 USD. Kevin Patten Performance Art/ General Manager (408) 848-6325 (408) 848-6349 fax www.performanceartonline.com 5755-B Rossi Lane Gilroy, CA 95020 BUMP Link to comment Share on other sites More sharing options...
Cali_KR Posted June 22, 2010 Author Report Share Posted June 22, 2010 Bump time Link to comment Share on other sites More sharing options...
Cali_KR Posted October 2, 2010 Author Report Share Posted October 2, 2010 SOLD, (traded in actually) Link to comment Share on other sites More sharing options...
Kevin Patten Posted June 25, 2012 Report Share Posted June 25, 2012 The new owner of this car (my old Bullitt ) just won 1st place in the 64 -1/2 to 2011 Modified Class at the MCA National ( judged ) Car Show in Concord this past weekend. I knew I should of kept that car - oh well . I sure do miss it - it was a fun car to drive ! Link to comment Share on other sites More sharing options...
