formervettowner Posted February 28, 2010 Report Share Posted February 28, 2010 Went out this morning and found 4 drops of blue oil on the ground around the inside of where the right rear wheel sits. Just had springs and panhard bar installed. Any relationship? Do shocks have blue oil? The color is about the same as my car Vista blue.It does have and oil feel and smell to it. Any help. Thanks Link to comment Share on other sites More sharing options...
oldlugs Posted March 1, 2010 Report Share Posted March 1, 2010 Sounds like you need to do some further investigation... Link to comment Share on other sites More sharing options...
Slabo Posted March 1, 2010 Report Share Posted March 1, 2010 Bearing grease is often blue. Sounds like grease from the panhard bushing or something else that was installed. Link to comment Share on other sites More sharing options...
moabman Posted March 1, 2010 Report Share Posted March 1, 2010 +1 on slabo's comment. Grease is really wax and oil emulsified and it is common for them to separate and the oil might drip out or off. Look at all the suspension bushings and see if you can see some blue grease or zerk fittings with some blue residual grease on them. Of course, it might also be something else. Link to comment Share on other sites More sharing options...
mullens Posted March 1, 2010 Report Share Posted March 1, 2010 Had the same problem with my Harley. Triple clamp grease would separate and drip blue oil on my tank. That's got to be it. Link to comment Share on other sites More sharing options...
6-Speed Posted March 3, 2010 Report Share Posted March 3, 2010 Perhaps it is blue thread locker. I applied some under the panhard bar jam nuts when I installed mine ... helps to keep the nuts from backing off. If the tech applied an excessive amount, might potentially drip before it dries. Link to comment Share on other sites More sharing options...
