GT500 JONY Posted February 18, 2010 Report Share Posted February 18, 2010 HI, DONT KNOW IF THIS HAS BEEN A TOPIC ALREADY BUT I GOT A BIG BANG NOISE SPEED SHIFTING FROM FIRST INTO SECOND UNDER HEAVY LOAD BURN OUT FROM FIRST TO SECOND SHIFTING INTO SECOND A BIG POP OR BANG NOISE NOTHING SEEMS TO DAMAGED IN TRANS OR ANYTHING STRANGE AFTER THE NOISE, ONLY THING I CAN THINK OF THE IS THE CAR IS SQUATTING AND IS HITTING SOMETHING ON THE BODY? FROM THE BUMP STOPS ON TOP OF THE AXLE I ONLY HAVE ABOUT A INCH TRAVEL FROM BUMP STOP TO FRAME 2007 SHELBY GT500 BMR PANHARD ROD AND BRACE BMR ALUMINUM TRAILING ARMS BMR UPPER DIFF BRACE H&R ADJUSTABLE SUSPENSION Quote Link to comment Share on other sites More sharing options...
LuckySnake Posted February 18, 2010 Report Share Posted February 18, 2010 (edited) HI, DONT KNOW IF THIS HAS BEEN A TOPIC ALREADY BUT I GOT A BIG BANG NOISE SPEED SHIFTING FROM FIRST INTO SECOND UNDER HEAVY LOAD BURN OUT FROM FIRST TO SECOND SHIFTING INTO SECOND A BIG POP OR BANG NOISE NOTHING SEEMS TO DAMAGED IN TRANS OR ANYTHING STRANGE AFTER THE NOISE, ONLY THING I CAN THINK OF THE IS THE CAR IS SQUATTING AND IS HITTING SOMETHING ON THE BODY? FROM THE BUMP STOPS ON TOP OF THE AXLE I ONLY HAVE ABOUT A INCH TRAVEL FROM BUMP STOP TO FRAME 2007 SHELBY GT500 BMR PANHARD ROD AND BRACE BMR ALUMINUM TRAILING ARMS BMR UPPER DIFF BRACE H&R ADJUSTABLE SUSPENSION Your not alone, this happens to alot of GT500's. Mine did it one time. I'm pretty sure mine was caused by the panhard rod aft body mount hole being to big in diameter. I know that I have not heard it since I had a steel washer welded to the mount, some people seem to only have the noise happen one time without doing anything and all is good. Here is a pix of the welded washer, keep in mind there are many other things that could cause this but this could be it. If I recall correctly, the BMR panhard rod uses a different bushing sleeve than the factory rod and isn't held in compression as well, this added washer helps keep things centered. I painted it so it looks factory. Edit: I'm also using a Fays2 Watts Link now. Edited February 18, 2010 by LuckySnake Quote Link to comment Share on other sites More sharing options...
1badshelby Posted February 18, 2010 Report Share Posted February 18, 2010 Mine was banging from underneath, it was the upper control arm bushing ripped. Quote Link to comment Share on other sites More sharing options...
RACERX009 Posted February 19, 2010 Report Share Posted February 19, 2010 had the same noise but it turned out to be a vette that, I just crushed !!!! Quote Link to comment Share on other sites More sharing options...
FiaCobra Posted February 19, 2010 Report Share Posted February 19, 2010 http://www.teamshelby.com/forums/index.php?/topic/49703-wheel-hop/page__p__831847__fromsearch__1entry831847 Quote Link to comment Share on other sites More sharing options...
