08SGT1591 Posted February 16, 2010 Report Share Posted February 16, 2010 I can never hear any bass coming from my trunk speakers. When I open the trunk they are working but not enough so I can hear up front. All I hear are the front door bass speakers. I have tried several settings. Today I removed the trunk bass unit to run a wire and found out how much it weighs. Why carry that weight around if you get no benefit. No, I don't need better speakers or sysytem. This one is just fine for me. No, I don't want to sell it. Question: can I remove the trunk bass unit without doing harm to the system? Should I disconnect the amps too? Thanks in advance, Greg Link to comment Share on other sites More sharing options...
SteelTownStang Posted February 16, 2010 Report Share Posted February 16, 2010 ... not personally done, but I've read on fordgt500.com where others have done the same without any issues... I believe that VNMOUS1 was one of them... room for his golf clubs. I believe that he is a member on here as well... Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted February 16, 2010 Report Share Posted February 16, 2010 Just to verify: You pushed the button to turn on the radio. Then pushed the menu button once and you verified the shaker on/off was "on"? Just asking! Link to comment Share on other sites More sharing options...
Shelby Nick Posted February 16, 2010 Report Share Posted February 16, 2010 Greg, I took mine out a while back with no issues. Just four bolts and disconnect wire harness. There is no carpet behind it though. The stereo still sounds good. Nick Link to comment Share on other sites More sharing options...
tpow96 Posted February 16, 2010 Report Share Posted February 16, 2010 Isn't there some advantage to keep weight over that right rear tire? (Yes, I know... it would be better to relocate the battery there.) -Tom Link to comment Share on other sites More sharing options...
08SGT1591 Posted February 16, 2010 Author Report Share Posted February 16, 2010 Thanks for responses. Yes the menu says "on". Have adjusted it many times. I just wanted to make sure if I disconnected it that I wouldn't burnout anything in the tuner. Greg Link to comment Share on other sites More sharing options...
08SGT1591 Posted February 16, 2010 Author Report Share Posted February 16, 2010 I was also thinking of the battery move in the future. It helped my last vehicle. Greg Link to comment Share on other sites More sharing options...
johnrehder Posted February 20, 2010 Report Share Posted February 20, 2010 Mine will rattle the windows out! I removed it one time for the track and it did not hurt a thing, radio still sounded great. Weighs about 45 pounds so I'm leaving it in for the next track day. quote name='08SGT1591' date='16 February 2010 - 05:34 PM' timestamp='1266359664' post='910645'] Thanks for responses. Yes the menu says "on". Have adjusted it many times. I just wanted to make sure if I disconnected it that I wouldn't burnout anything in the tuner. Greg Link to comment Share on other sites More sharing options...
