GOTVENOMGT500 Posted February 2, 2010 Report Share Posted February 2, 2010 I have these pair of Craftsman 3 Ton Jack Stand, picked up them up on sale and so far have worked well. I'm looking for some pads usually made of rubber/plastic that slip over the stand arms to help from damaging the jacking point. The pads would look something like these I picked the pads pictured above at harbor freight but they were too large to work with my Craftsman stands. Any ideas? Also do you guys use had kind of pad or cushion on your jack also? Link to comment Share on other sites More sharing options...
J-Train Posted February 2, 2010 Report Share Posted February 2, 2010 Harbor Freight has them, I was there the other day, they have the Jack pads too, I want to say they were like 6 or 8 dollars Link to comment Share on other sites More sharing options...
J-Train Posted February 2, 2010 Report Share Posted February 2, 2010 Whoops, i saw now that you said you had the Harbor Freight ones already Link to comment Share on other sites More sharing options...
ItalianStallion Posted February 3, 2010 Report Share Posted February 3, 2010 I've had this link set aside for making a purchase like this too. Perhaps this is what you're after http://www.protechproducts.net/jackstandpads.htm ItalianStallion Link to comment Share on other sites More sharing options...
SVTpower Posted February 3, 2010 Report Share Posted February 3, 2010 Summit Racing and JEgs have them on-line. Link to comment Share on other sites More sharing options...
GOTVENOMGT500 Posted February 3, 2010 Author Report Share Posted February 3, 2010 No problem J-train I still appreicate the reply, my past was a bit busy with all the pictures and text broken up. Thanks for the link ItalianStallion, I like how indepth that site is with all the different sizes of stand sizes. Thanks SVTPower I'll check them both out, right now I'm leaning towards the site Stallion posted as it seems they are pretty specfic and should fit first try. Link to comment Share on other sites More sharing options...
GOTVENOMGT500 Posted February 3, 2010 Author Report Share Posted February 3, 2010 I'm looking at the jack pads also. Given the jacking points on the 2010 GT500 would it be better to get the flat jacking pad or the side lift jack pad? Flat Side life jack pad On my 97 Cobra I'd use the Side Life Jack Pad Link to comment Share on other sites More sharing options...
ItalianStallion Posted February 3, 2010 Report Share Posted February 3, 2010 I'm looking at the jack pads also. Given the jacking points on the 2010 GT500 would it be better to get the flat jacking pad or the side lift jack pad? Flat Side life jack pad On my 97 Cobra I'd use the Side Life Jack Pad Yea, this is ideal stuff. Pro Tech has it figured out. Link to comment Share on other sites More sharing options...
Still Intense Posted February 3, 2010 Report Share Posted February 3, 2010 One thing that I've done for years that works well is to simply cut a strip of low pile carpet and zip tie it to the jackstands (and the jack pad for that matter). Works very well and use it on my Shelby all the time. Usually lasts a year or two, and it's free..... Link to comment Share on other sites More sharing options...
