strong_j Posted August 29, 2010 Author Report Share Posted August 29, 2010 Ok finally the motor is in the car!! It took forever to try to find a 8 bolt flywheel to match up to my existing ram twin disk clutch!! But now i just need to put the supercharger, plug all the sensors up and bolt the drive shaft in and than she's off to HPP to get tuned!! heres some pics!! I had to do some cutting of the K-member for the oil pan to drop in and with those headers its a very tight squeeze!! i have no clue how im going to torque the passenger side motor mount the header is sitting right on top of it!! lol Link to comment Share on other sites More sharing options...
strong_j Posted September 1, 2010 Author Report Share Posted September 1, 2010 Transmission is bolted up!! Holy cow who ever does trannys for a living my hat come off to you!! It's a pain and alot of aligning. I guess it doesn't help that I'm also doing it on the ground and I have to suck in to fit under my car!! Lmao. First weight reduction mod is a treadmill!! Lol. Link to comment Share on other sites More sharing options...
blkGT500nCA Posted September 2, 2010 Report Share Posted September 2, 2010 I've been following your thread for a while now. I hope you get her up and running soon! Link to comment Share on other sites More sharing options...
strong_j Posted September 2, 2010 Author Report Share Posted September 2, 2010 I've been following your thread for a while now. I hope you get her up and running soon! thx bro!! I'll tell you i would of never got this thing done without the help of the members of this forum!! When I'm done I think ill have to send yall all a fruit basket or somthing to show you my appreciation!! lmao Link to comment Share on other sites More sharing options...
strong_j Posted September 4, 2010 Author Report Share Posted September 4, 2010 Okay guys she is Almost on her way!! Me and a friend stayed up will 4:00 this morning trying to get as much done as possible!! The only thing I'm waiting on is injectors and drive shaft adapter!! Also figure out where two connections go. But after that she's off to HPP to get tuned, nitrous installed, 3.73 gears, and locking diff. Hopefully it shouldn't take too long. I'll post pics later tonight. The steeda drive system is a piece of cake to install and makes the whipple look like a king!! Lol. Link to comment Share on other sites More sharing options...
strong_j Posted September 5, 2010 Author Report Share Posted September 5, 2010 Link to comment Share on other sites More sharing options...
GT500-07 Posted September 5, 2010 Report Share Posted September 5, 2010 is it running yet? Link to comment Share on other sites More sharing options...
strong_j Posted September 6, 2010 Author Report Share Posted September 6, 2010 Not yet. Waitin to get injectors and driveshaft adapter. Question I have though. I have to get this thing tuned before I start it right?? Link to comment Share on other sites More sharing options...
GT500-07 Posted September 6, 2010 Report Share Posted September 6, 2010 Not yet. Waitin to get injectors and driveshaft adapter. Question I have though. I have to get this thing tuned before I start it right?? didn't you get a tune with the HO kit? Link to comment Share on other sites More sharing options...
strong_j Posted September 6, 2010 Author Report Share Posted September 6, 2010 didn't you get a tune with the HO kit? yes, but that tune is for the stock motor, stock boost, 12lbs of boost. now it has a bigger motor, way bigger cams, alot more boost, and alot more injector... but i was thinking does all that matter at idle?? i was hoping maybe i could just start it and make sure there are no leaks before i ship it to my tuner.. Link to comment Share on other sites More sharing options...
GT500-07 Posted September 7, 2010 Report Share Posted September 7, 2010 yes, but that tune is for the stock motor, stock boost, 12lbs of boost. now it has a bigger motor, way bigger cams, alot more boost, and alot more injector... but i was thinking does all that matter at idle?? i was hoping maybe i could just start it and make sure there are no leaks before i ship it to my tuner.. you should be fine for start up, confirm with your tuner Link to comment Share on other sites More sharing options...
strong_j Posted September 20, 2010 Author Report Share Posted September 20, 2010 Okay the fuel system is done (fuel rails, injectors, sensors, etc) I'm waiting on my BMR swaybar delete and i ordered the wrong spark plugs aparently MMR sent me the redesigned head that uses different threaded spark plugs, so i'm exchanging my brisk plugs for the ford racing HT0's. thats the only good plug i have found for the new head!! also my 3.73 gears came in and now that i think about it with how wild my cams are i prolly should of went with 4.10's so might be exchanging them too.. Hopefully car will be shipped off to HPP in acouple of weeks!! Link to comment Share on other sites More sharing options...
kahmann Posted September 20, 2010 Report Share Posted September 20, 2010 ^I'd stick with the 3.73's no matter how wild your cams are, only because of that big old Whipple sitting on top of your motor. I've got 4.10's and am running a Paxton and it's still way too much gear. I intend on swapping to a 3.90 before long. The build looks great man, keep us posted on how she runs. Link to comment Share on other sites More sharing options...
strong_j Posted September 23, 2010 Author Report Share Posted September 23, 2010 Ok the driveshaft is bolted up and also just got done with the bmr sway bar delete!! Heres basically what it deletes and i can tell how much lighter this thing is compared to the stock one!! Link to comment Share on other sites More sharing options...
strong_j Posted September 26, 2010 Author Report Share Posted September 26, 2010 Ok guys Im pretty much wrapping up this build!! I got 99% of the sensors back in only one left is the TPS sensor that i have to solder back together. and I have the covers, fan, overflow tank and intercooler tank on. Only problem i hit so far is i broke the fuel presser sensor screw off into the fuel rail so monday im going to drill that sucker out and helicoil it. after that ill put on the intake and ship her to HPP for the final parts (guages installed, 3.73 installed, detroit locker installed) and to get dyno'ed. Ill be done with her by wednesdsay by the latest so hopefully ill be about to post numbers in acouple of weeks!! Here's some pics i took tonight!! Link to comment Share on other sites More sharing options...
GT500-07 Posted September 26, 2010 Report Share Posted September 26, 2010 you forgot this, http://www.summitracing.com/parts/MOR-63491 Link to comment Share on other sites More sharing options...
strong_j Posted September 26, 2010 Author Report Share Posted September 26, 2010 you forgot this, http://www.summitracing.com/parts/MOR-63491 dammit!! lol. Link to comment Share on other sites More sharing options...
strong_j Posted September 28, 2010 Author Report Share Posted September 28, 2010 Ok guys just got back from gearheads and decided i am going with them for the tuning and install. I was talking to travis and he really impressed me with his knowledge of our cars and his 2010 twin turbo e85 mustang he was building. He talked me into doing a return style fuel system with triple pumps and not to do the tru trac locking diff and just put some carbon clutches on the stock diff and it should hold just fine!! So she is going to be shipped to gear heads in prolly 3 days!!! Link to comment Share on other sites More sharing options...
strong_j Posted September 29, 2010 Author Report Share Posted September 29, 2010 Ok pretty much everything is done!! The tow truck is coming thursday.. Link to comment Share on other sites More sharing options...
strong_j Posted October 1, 2010 Author Report Share Posted October 1, 2010 Ok the car is at the shop!! i should have the numbers by acouple of weeks!! Link to comment Share on other sites More sharing options...
GT500-07 Posted November 13, 2010 Report Share Posted November 13, 2010 Ok the car is at the shop!! i should have the numbers by acouple of weeks!! [/quote any updates? Link to comment Share on other sites More sharing options...
kahmann Posted December 6, 2010 Report Share Posted December 6, 2010 How'd your dyno tune turn out? Link to comment Share on other sites More sharing options...
GT500-07 Posted December 6, 2010 Report Share Posted December 6, 2010 How'd your dyno tune turn out? Ken, he's been MIA Link to comment Share on other sites More sharing options...
