cbr1000 Posted January 29, 2010 Report Share Posted January 29, 2010 Over the past couple years I've seen many posts related to the weight of a GT500. Some posts are on Ford forums, others from people that don't like Ford products. They typically have the same general statements...it can go fast straight, but it can't turn, solid axle, it's too heavy, if they only went to a aluminum engine... and so on. Anybody else see the irony in the GT500 finally going to a Ai block which I'm guessing shaves off a 100lbs, but then some people are adding glass roofs? Whats the weight difference between 2010 and 2011 engine? Anybody know how much a glass roof weighs? Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted January 31, 2010 Report Share Posted January 31, 2010 Whats the weight difference between 2010 and 2011 engine? MMR sells both iron and aluminium 5.4L shortblocks. Their ad says the Al. shaves 100lbs off of the iron block offering. So the '90-100lb' statements you've seen here on TS sound pretty accurate. I can't comment on the glass roof vs. steel roof as I have no idea. HTh, Phill Link to comment Share on other sites More sharing options...
2nd2none Posted January 31, 2010 Report Share Posted January 31, 2010 read some where yesterday the glass roof is actually lighter. will try to find it again. nm. maybe I was wrong. found another article today talking about weight and they were just comparing the glass top to the convertible and the glass option is lighter. also says its not sure how much weight the glass adds but it "should not be significant enough to cause a reduction in performance." Link to comment Share on other sites More sharing options...
Dig-It Posted January 31, 2010 Report Share Posted January 31, 2010 When the glass roof was first offered in the Mustang GT, folks were measuring the difference at about 24 - 28 lbs heavier than with the steel roof. Link to comment Share on other sites More sharing options...
cbr1000 Posted January 31, 2010 Author Report Share Posted January 31, 2010 When the glass roof was first offered in the Mustang GT, folks were measuring the difference at about 24 - 28 lbs heavier than with the steel roof. I finally found a posted weight of 24lbs additional. That seems too low? I can imagine it would be scary getting hit and having the roof pop off or in on top of you... Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted February 1, 2010 Report Share Posted February 1, 2010 I finally found a posted weight of 24lbs additional. That seems too low? I can imagine it would be scary getting hit and having the roof pop off or in on top of you... I figured it would be more than 24lbs too. I thought that way, because like a 'vert, (I thought) they'd have to beef up the belly pan of the car since there is no top to add cross/triangle bracing to the pan. I don't imagine the glass roof adds all that much strength by itself but maybe so. And weight, would a sheet of glass weight much more than a sheet of steel? That's why I are not a engineer, Phill Link to comment Share on other sites More sharing options...
jsarkis Posted February 4, 2010 Report Share Posted February 4, 2010 Over the past couple years I've seen many posts related to the weight of a GT500. Some posts are on Ford forums, others from people that don't like Ford products. They typically have the same general statements...it can go fast straight, but it can't turn, solid axle, it's too heavy, if they only went to a aluminum engine... and so on. Anybody else see the irony in the GT500 finally going to a Ai block which I'm guessing shaves off a 100lbs, but then some people are adding glass roofs? Whats the weight difference between 2010 and 2011 engine? Anybody know how much a glass roof weighs? I went to the car show this last weekend and saw the 2011 GT-R premium v, it weighs basically the same as the 2010 GT500. It has the exact front - rear weight ratio as the 2010. It cost 84k and has about 488hp. Funny noone ever talks about the GT-R's weight and front - rear ratio, even though it is basically identical. This complaint is similar to the "is it a real Shelby" argument. Some people are always looking to get under other's skin or be negative. If they drove a 2010 and said it can't handle, then their a professional road coarse racer. It handles nearly as well as my Vet, & 300z. Plus you don't have to baby it driving on the street bc it's soo low, at the stock height. Link to comment Share on other sites More sharing options...
cbr1000 Posted February 6, 2010 Author Report Share Posted February 6, 2010 I agree, overall I'm happy with the stock ride related to the way it handles. I wish it was about a half inch lower for appearance. Link to comment Share on other sites More sharing options...
mullens Posted February 8, 2010 Report Share Posted February 8, 2010 I figured it would be more than 24lbs too. I thought that way, because like a 'vert, (I thought) they'd have to beef up the belly pan of the car since there is no top to add cross/triangle bracing to the pan. I don't imagine the glass roof adds all that much strength by itself but maybe so. And weight, would a sheet of glass weight much more than a sheet of steel? That's why I are not a engineer, Phill Yes sir when the steel is .080 and the glass is 1/4". Link to comment Share on other sites More sharing options...
