Revan Racing Posted January 3, 2010 Report Share Posted January 3, 2010 Just trying to determine where Ford relocated the relay that activates the heat exchanger water pump so that those of you who have purchased the Shelby Heat Exchanger can also by-pass the ECU and trigger the heat exchanger and water pump at key on. Please take a pic and post. Thanks Van Link to comment Share on other sites More sharing options...
Rag Top Day Posted January 4, 2010 Report Share Posted January 4, 2010 Just trying to determine where Ford relocated the relay that activates the heat exchanger water pump so that those of you who have purchased the Shelby Heat Exchanger can also by-pass the ECU and trigger the heat exchanger and water pump at key on. Please take a pic and post. Thanks Van Ok I'm not sure how this will work but here goes Here is the Battery Junction Block Relay is second one down on left Charge air cooler pump relay And here is the corisponding wire schematic with the pins Pin 1 Wh-Bu Hot in start or run Pin 2 Gn-Bn Powertrain Control Module Pin 3 Wh-Rd Hot at all times Pin 4 Wh-Gn Charge air cooler pump Hope this helps you. Link to comment Share on other sites More sharing options...
Bish Posted January 4, 2010 Report Share Posted January 4, 2010 Just trying to determine where Ford relocated the relay that activates the heat exchanger water pump so that those of you who have purchased the Shelby Heat Exchanger can also by-pass the ECU and trigger the heat exchanger and water pump at key on. Please take a pic and post. Thanks Van Van, Let me know what you find out regarding this, as you know I'm getting ready to do the wiring for your HE. Also looking forward to receiving the upgrade you've recommended for my 10 as well, the mod bug had bitten me hard! Thanks, Bish Link to comment Share on other sites More sharing options...
jared@lethal Posted January 4, 2010 Report Share Posted January 4, 2010 Just trying to determine where Ford relocated the relay that activates the heat exchanger water pump so that those of you who have purchased the Shelby Heat Exchanger can also by-pass the ECU and trigger the heat exchanger and water pump at key on. Please take a pic and post. Thanks Van Stop by the office if you're in the area and I'll show you which one it is and what pins to use. Jared Link to comment Share on other sites More sharing options...
