justindewoody Posted December 29, 2009 Report Share Posted December 29, 2009 Hey everyone, I got a little issue. About 3 days ago, I filled up at the gas station and I put 93 Octane in it. I got driving down the freeway and when I'm in 5th or 6th gear and really hit the gas, I hear a noise that sounds like coins rattling around in a can. Kinda scared me, so I quit pushin' her. My dad has informed me that it sounds like pre-ignition/detonation to him. He says that sometimes you pay for 93 Octane gas, but the stupid gas station puts cheap gas in the tank. So, he thinks I got shitty gas and now I'm experiencing detonation from low octane gas that cannot provide the power that my car demands under a high load/high torque situation. DOES THE SITUATION SOUND LIKE DETONATION TO YOU? I'm currently trying to run the tank empty and then I will fill her up with 93 octane from a TRUSTED gas station. But I want to know what you guys think until I can do that. Thanks. Link to comment Share on other sites More sharing options...
Torched10 Posted December 29, 2009 Report Share Posted December 29, 2009 Hey everyone, I got a little issue. About 3 days ago, I filled up at the gas station and I put 93 Octane in it. I got driving down the freeway and when I'm in 5th or 6th gear and really hit the gas, I hear a noise that sounds like coins rattling around in a can. Kinda scared me, so I quit pushin' her. My dad has informed me that it sounds like pre-ignition/detonation to him. He says that sometimes you pay for 93 Octane gas, but the stupid gas station puts cheap gas in the tank. So, he thinks I got shitty gas and now I'm experiencing detonation from low octane gas that cannot provide the power that my car demands under a high load/high torque situation. DOES THE SITUATION SOUND LIKE DETONATION TO YOU? I'm currently trying to run the tank empty and then I will fill her up with 93 octane from a TRUSTED gas station. But I want to know what you guys think until I can do that. Thanks. Sure soiunds like that to me--it can hurt your engine if it happens to often. Ill defer to experts here,but i add octane booster to my 65GTO which has 12:1 compresion to prevent this.BP sells racing gas at pumps--you might call them and see if anyone has any where you live.Finally, you could go but 5 gallons of racing gas at a speed shop and just put in in your tank.Your sure no-one screwed with you and out water on your gas tank, or worse sugar right?? Link to comment Share on other sites More sharing options...
ingram4868 Posted December 29, 2009 Report Share Posted December 29, 2009 If this is the only time you have experienced it since you've added all the performance mods then low octane fuel might be it. If it continues in the future I would talk with Fred. If it were me and because of all your Cobra Jet parts plus the pulley I would seek out a dyno facility. Have them weld in o2 bungs in each exhaust pipe. They can check your A/F ratio and provide another tune if needed. Link to comment Share on other sites More sharing options...
Light66 Posted December 29, 2009 Report Share Posted December 29, 2009 Hey everyone, I got a little issue. About 3 days ago, I filled up at the gas station and I put 93 Octane in it. I got driving down the freeway and when I'm in 5th or 6th gear and really hit the gas, I hear a noise that sounds like coins rattling around in a can. Kinda scared me, so I quit pushin' her. My dad has informed me that it sounds like pre-ignition/detonation to him. He says that sometimes you pay for 93 Octane gas, but the stupid gas station puts cheap gas in the tank. So, he thinks I got shitty gas and now I'm experiencing detonation from low octane gas that cannot provide the power that my car demands under a high load/high torque situation. DOES THE SITUATION SOUND LIKE DETONATION TO YOU? I'm currently trying to run the tank empty and then I will fill her up with 93 octane from a TRUSTED gas station. But I want to know what you guys think until I can do that. Thanks. Interesting that your knock sensor did not prevent your problem. As you may or may not know, those of us with 07-09 GT500's don't have knock sensors. Is there anyone out there that can add supporting information behind the 2010 knock sensor limitations? Link to comment Share on other sites More sharing options...
500-VERT Posted December 29, 2009 Report Share Posted December 29, 2009 Hey everyone, I got a little issue. About 3 days ago, I filled up at the gas station and I put 93 Octane in it. I got driving down the freeway and when I'm in 5th or 6th gear and really hit the gas, I hear a noise that sounds like coins rattling around in a can. Kinda scared me, so I quit pushin' her. My dad has informed me that it sounds like pre-ignition/detonation to him. He says that sometimes you pay for 93 Octane gas, but the stupid gas station puts cheap gas in the tank. So, he thinks I got shitty gas and now I'm experiencing detonation from low octane gas that cannot provide the power that my car demands under a high load/high torque situation. DOES THE SITUATION SOUND LIKE DETONATION TO YOU? I'm currently trying to run the tank empty and then I will fill her up with 93 octane from a TRUSTED gas station. But I want to know what you guys think until I can do that. Thanks. Mine did the same thing and it was because a boost line hane come loose. It caused me to detinate 3 plugs...very scary...didn't want to loose a cylinder at the same time. I would pull the plugs and give them a look as well. Link to comment Share on other sites More sharing options...
cbr1000 Posted December 30, 2009 Report Share Posted December 30, 2009 I don't know what's causing your problem, but if you think it's the gas I had an experience with bad gas once. I added "trusted" gas to the tank instead of trying to run out all the bad gas then filling with new. It worked for me... Link to comment Share on other sites More sharing options...
Fontech Posted December 30, 2009 Report Share Posted December 30, 2009 Link to comment Share on other sites More sharing options...
ChrisSD Posted December 30, 2009 Report Share Posted December 30, 2009 I've been concerned that tuners are being lazy and just shutoff the knock sensors since they don't know how to deal with them. Link to comment Share on other sites More sharing options...
shel-b001 Posted December 30, 2009 Report Share Posted December 30, 2009 Keep us posted after you add new gas.Could be that simple. Link to comment Share on other sites More sharing options...
Still Intense Posted December 30, 2009 Report Share Posted December 30, 2009 I would agree that it is probably bad gas (low octane). I once accidentally put in 87 octane in my Terminator that was running 17 lbs of boost. It was making all kinds of darn noise when I hammered it. I simply drove it easy until I used most of the gas and then put 93 back in and all was well. As mentioned above, I'd also check all my connections on the engine. Interesting though that the knock sensors didn't do something with it...... Link to comment Share on other sites More sharing options...
Tucker Posted December 30, 2009 Report Share Posted December 30, 2009 hitting the gas hard in 5th and 6th is not good. The car is under a huge load and the gearing is low. Boost, low RPMs and "maybe" bad gas doesn't mix. Always be in a higher RPM when you need to pass or get into boost. Jay Link to comment Share on other sites More sharing options...
OneTrickPony Posted December 30, 2009 Report Share Posted December 30, 2009 Hey everyone, I got a little issue. About 3 days ago, I filled up at the gas station and I put 93 Octane in it. I got driving down the freeway and when I'm in 5th or 6th gear and really hit the gas, I hear a noise that sounds like coins rattling around in a can. Kinda scared me, so I quit pushin' her. My dad has informed me that it sounds like pre-ignition/detonation to him. He says that sometimes you pay for 93 Octane gas, but the stupid gas station puts cheap gas in the tank. So, he thinks I got shitty gas and now I'm experiencing detonation from low octane gas that cannot provide the power that my car demands under a high load/high torque situation. DOES THE SITUATION SOUND LIKE DETONATION TO YOU? I'm currently trying to run the tank empty and then I will fill her up with 93 octane from a TRUSTED gas station. But I want to know what you guys think until I can do that. Thanks. Did you buy some cheap gas to save a few $$. If you did that could be your problem if it wasn't there before. I always run Chevron and zero problems. Link to comment Share on other sites More sharing options...
BEEKAY GT500 Posted December 31, 2009 Report Share Posted December 31, 2009 Hey everyone, I got a little issue. About 3 days ago, I filled up at the gas station and I put 93 Octane in it. I got driving down the freeway and when I'm in 5th or 6th gear and really hit the gas, I hear a noise that sounds like coins rattling around in a can. Kinda scared me, so I quit pushin' her. My dad has informed me that it sounds like pre-ignition/detonation to him. He says that sometimes you pay for 93 Octane gas, but the stupid gas station puts cheap gas in the tank. So, he thinks I got shitty gas and now I'm experiencing detonation from low octane gas that cannot provide the power that my car demands under a high load/high torque situation. DOES THE SITUATION SOUND LIKE DETONATION TO YOU? I'm currently trying to run the tank empty and then I will fill her up with 93 octane from a TRUSTED gas station. But I want to know what you guys think until I can do that. Thanks. sounds like pinging/detonation that i had using california 91. i tried different stations and still had it. Link to comment Share on other sites More sharing options...
blkGT500nCA Posted December 31, 2009 Report Share Posted December 31, 2009 sounds like pinging/detonation that i had using california 91. i tried different stations and still had it. and you fixed it, how? Link to comment Share on other sites More sharing options...
SVT NAJA Posted December 31, 2009 Report Share Posted December 31, 2009 I always run Chevron and zero problems. +1 here in California @ 91 octane. Link to comment Share on other sites More sharing options...
Carbd86GT Posted December 31, 2009 Report Share Posted December 31, 2009 hitting the gas hard in 5th and 6th is not good. The car is under a huge load and the gearing is low. Boost, low RPMs and "maybe" bad gas doesn't mix. Always be in a higher RPM when you need to pass or get into boost. Jay +1 Don't nail it in 5th or 6th gear when you're at cruising RPM, it's just waaayyyyy too much load, especially when the car has a roots or twin screw since they make instant boost. Run it empty, put in trusted 93, and don't nail it in 5th or 6th anymore. Link to comment Share on other sites More sharing options...
justindewoody Posted December 31, 2009 Author Report Share Posted December 31, 2009 I ran the tank dry and filled up again with some trusted 93 octane. Everything seems fine now, so it was obviously bad gas. Thanks everyone! Link to comment Share on other sites More sharing options...
ingram4868 Posted December 31, 2009 Report Share Posted December 31, 2009 Glad to hear that your pinging is gone. Keep an ear open for it to return when the temps get warmer. If it does return ask that the timing be reduced in the tune. Link to comment Share on other sites More sharing options...
