07SGT4957 Posted December 28, 2009 Report Share Posted December 28, 2009 Has anyone who has put 4.10 ring and pinion gears in their rear axel had to re-calibrate the speedometer or change the tune in their car at all? I am just trying to cover my bases and understand what needs to happen before I pull the trigger on this mod. Link to comment Share on other sites More sharing options...
kahmann Posted December 28, 2009 Report Share Posted December 28, 2009 Yes you need a tuner or a trip to the dealer to make the change. It's very simple to do with an SCT. Ken Link to comment Share on other sites More sharing options...
azmartin Posted December 28, 2009 Report Share Posted December 28, 2009 Has anyone who has put 4.10 ring and pinion gears in their rear axel had to re-calibrate the speedometer or change the tune in their car at all? I am just trying to cover my bases and understand what needs to happen before I pull the trigger on this mod. Yes you will have to recalibrate the speedometer. Not hard to do if you or a friend has a programmer. You don't have to change the engine tune, but it can help a little more if you haven't done it yet. There is quite a bit of info here already on the site. Search for 4.10 gear swap or gear swap. You will find a bunch of information. 4.10's will make a fairly big performance difference over what you now have with the the 3.55's. Link to comment Share on other sites More sharing options...
07SGT4957 Posted December 28, 2009 Author Report Share Posted December 28, 2009 Thank you for the info. Have a Happy and Safe New Year. Link to comment Share on other sites More sharing options...
