03 DSG Snake Posted December 24, 2009 Report Share Posted December 24, 2009 Just looking for a point of reference when using the 20" Alcoas. Thank you! Link to comment Share on other sites More sharing options...
bchorney Posted December 24, 2009 Report Share Posted December 24, 2009 Just looking for a point of reference when using the 20" Alcoas. Thank you! I was told to run 38 to 42 PSI. I run 40 psi. Merry Christmas!! Brett Link to comment Share on other sites More sharing options...
knownukes Posted December 25, 2009 Report Share Posted December 25, 2009 I was told to run 38 to 42 PSI. I run 40 psi. Merry Christmas!! Brett Who tald u that? That sounds really hi. BJ Link to comment Share on other sites More sharing options...
ingram4868 Posted December 25, 2009 Report Share Posted December 25, 2009 Did the Super Snakes come with a supplemental owners manual from Shelby? Link to comment Share on other sites More sharing options...
08 ORANGE SS-725HP Posted December 26, 2009 Report Share Posted December 26, 2009 38 psi cold front and 36 psi cold rear seems to work real well. Link to comment Share on other sites More sharing options...
08 Mustang Posted December 27, 2009 Report Share Posted December 27, 2009 I am now running 35 psi at all 4 corners and it seems to be right on the money Link to comment Share on other sites More sharing options...
08SS0109 Posted December 27, 2009 Report Share Posted December 27, 2009 When I called, I was told 35 all around. Link to comment Share on other sites More sharing options...
MY500SS Posted December 27, 2009 Report Share Posted December 27, 2009 I am now running 35 psi at all 4 corners and it seems to be right on the money +1 Link to comment Share on other sites More sharing options...
bchorney Posted December 27, 2009 Report Share Posted December 27, 2009 Who tald u that? That sounds really hi. BJ I was told that by Roger and Kameron at SAI when I was picking up my SS. I am sure this will be in the manual when it comes out. Cheers Brett Link to comment Share on other sites More sharing options...
blkGT500nCA Posted December 27, 2009 Report Share Posted December 27, 2009 36 psi Link to comment Share on other sites More sharing options...
Robert OHara Posted December 27, 2009 Report Share Posted December 27, 2009 My left rear tire is currently at 0. Just discovered a little frigging nail in it. Link to comment Share on other sites More sharing options...
Dale Jerome Posted December 27, 2009 Report Share Posted December 27, 2009 I was told by Kameron at SAI to run somewhere between 37 to 40 PSI Link to comment Share on other sites More sharing options...
Lee N. Posted December 28, 2009 Report Share Posted December 28, 2009 I was told by Kameron at SAI to run somewhere between 37 to 40 PSI Ford states 35 psi front and rear for the GT500. Its listed on the door plate. Link to comment Share on other sites More sharing options...
08 ORANGE SS-725HP Posted December 28, 2009 Report Share Posted December 28, 2009 Ford states 35 psi front and rear for the GT500. Its listed on the door plate. That's for the stock 18" wheels and cooresponding tires. The question is what pressure are you running in the 20" tires that come on the Super Snake. Link to comment Share on other sites More sharing options...
Lee N. Posted December 28, 2009 Report Share Posted December 28, 2009 That's for the stock 18" wheels and cooresponding tires. The question is what pressure are you running in the 20" tires that come on the Super Snake. The manufacturer sets the tire pressure based on vehicle weight, not rim size. Recommended pressure should stay at 35# for a SS since the weight of the car is unchanged. Link to comment Share on other sites More sharing options...
08 ORANGE SS-725HP Posted December 28, 2009 Report Share Posted December 28, 2009 Lee: So tire width, sidewall height/stiffness, and circumference have nothing to do with cooresponding air pressure for any tire/wheel combo??? I know the weight of the vehicle is important but all the other aspects of the tire should weigh on the proper air pressure needed too. Correct me if I'm wrong. Link to comment Share on other sites More sharing options...
Lee N. Posted December 28, 2009 Report Share Posted December 28, 2009 Lee: So tire width, sidewall height/stiffness, and circumference have nothing to do with cooresponding air pressure for any tire/wheel combo??? I know the weight of the vehicle is important but all the other aspects of the tire should weigh on the proper air pressure needed too. Correct me if I'm wrong. I am not a tire guru, but I was always told that the vehicle weight was the factor that was used for tire pressure determination. Tire height will make a difference in needed presure, but you will normally only see this if you are going to a MUCH larger tire on a truck or SUV. Load rating can come into effect, but that normally is only the case for trucks with large sidewalls as well. Many vehicles from the factory have different size wheel options, but the manufacturers recommended pressures always stay the same. For example you can buy a Ford truck with 17", 18" or 20" rims and the door stickers are all the same, but all the tires they equipt the car with on these different wheel sizes will have the same load rating. Our tires do not have a load rating, but each tire does have a maximumn load weight listed, but they are going to be very close with the choices we are talking about and I do not think that will change the recommended inflation pressure of the tire for that car. Of coarse this is for street tires on the street. Racing applications and racing tires all this goes out the window as well as when you are driving at accessive speed (160 plus) With that said, changing pressure for different tires, different pavements and different temperatures will have preformance advantages, but I still think the baseline will be the manufacturers rating for both the SS tires on 20's and the GT500 tires on 18's. Link to comment Share on other sites More sharing options...
Torched10 Posted December 30, 2009 Report Share Posted December 30, 2009 With the cold weather,and the tires not holding as well, Ive been running 32psi for better tracion,seems to help Link to comment Share on other sites More sharing options...
