zeindog Posted December 15, 2009 Report Share Posted December 15, 2009 Just finished up installing a homelink transmitter into the overhead map light console. I got the transmitter off ebay for $25 and installed it in under and hour. The install took a little modifying and removal of some of the plastic inside the pocket and cutting out a hole for the buttons, obviously. Once put back into the car it looks like it came from the factory that way, the black plastic is almost a perfect match. Link to comment Share on other sites More sharing options...
lawdude Posted December 15, 2009 Report Share Posted December 15, 2009 What kind of range does it have? Link to comment Share on other sites More sharing options...
Bish Posted December 16, 2009 Report Share Posted December 16, 2009 Sweet! Link to comment Share on other sites More sharing options...
Torched10 Posted December 16, 2009 Report Share Posted December 16, 2009 where did you get the power connection Link to comment Share on other sites More sharing options...
07-2937 Posted December 16, 2009 Report Share Posted December 16, 2009 awesome I did one myself but chose the mirror my range is about 500 feet or so Link to comment Share on other sites More sharing options...
Baby Gorilla Posted December 16, 2009 Report Share Posted December 16, 2009 Awesome! Thanks. I think I'm going to have to do the same. Link to comment Share on other sites More sharing options...
zeindog Posted December 16, 2009 Author Report Share Posted December 16, 2009 Im havnt tested the range yet, my car is in thr garage for the winter and I am redoing my driveway so I can get it out now. The power is in the pocket, there is a black/yellow for ground, and a yellow/green for constant. Link to comment Share on other sites More sharing options...
check6 Posted December 16, 2009 Report Share Posted December 16, 2009 Very cool! A useful, inexpensive upgrade. Link to comment Share on other sites More sharing options...
cbr1000 Posted December 16, 2009 Report Share Posted December 16, 2009 nice job Link to comment Share on other sites More sharing options...
wnenn Posted December 17, 2009 Report Share Posted December 17, 2009 Just finished up installing a homelink transmitter into the overhead map light console. I got the transmitter off ebay for $25 and installed it in under and hour. The install took a little modifying and removal of some of the plastic inside the pocket and cutting out a hole for the buttons, obviously. Once put back into the car it looks like it came from the factory that way, the black plastic is almost a perfect match. Does your car have NAV? I bought the transmiter and have wondered if it will ift into the overhead console that has the mike for Sync the alarm sensors. Thenks, Wnenn Link to comment Share on other sites More sharing options...
ruiner Posted December 17, 2009 Report Share Posted December 17, 2009 Does your car have NAV? I bought the transmiter and have wondered if it will ift into the overhead console that has the mike for Sync the alarm sensors. Thenks, Wnenn i was wondering the same thing....i took my console down a couple days ago to see if it would fit and it is very cramped. Link to comment Share on other sites More sharing options...
zeindog Posted December 17, 2009 Author Report Share Posted December 17, 2009 i was wondering the same thing....i took my console down a couple days ago to see if it would fit and it is very cramped. Yes I do have the nav package, the sensors in the console I believe are the motion sensors for the alarm. It is very cramped and I did have to make some modifications to get it in there but it does fit. The main problem was the air bag light, which I had to shave a little off the corner and modify the light bulb holder. I can try to get some better pics but it is all crammed in there and you might not be able to tell what I did. Once you get into it you will see what needs to be cut out, mainly its the pastic tabs that are sticking up. Link to comment Share on other sites More sharing options...
ruiner Posted December 17, 2009 Report Share Posted December 17, 2009 Yes I do have the nav package, the sensors in the console I believe are the motion sensors for the alarm. It is very cramped and I did have to make some modifications to get it in there but it does fit. The main problem was the air bag light, which I had to shave a little off the corner and modify the light bulb holder. I can try to get some better pics but it is all crammed in there and you might not be able to tell what I did. Once you get into it you will see what needs to be cut out, mainly its the pastic tabs that are sticking up. did you have to extend the buttons at all to still make contact through the plastic? what did you use to bond the controls to the the overhead console? i see you used silicone on the inside Link to comment Share on other sites More sharing options...
zeindog Posted December 17, 2009 Author Report Share Posted December 17, 2009 did you have to extend the buttons at all to still make contact through the plastic? what did you use to bond the controls to the the overhead console? i see you used silicone on the inside I used hot glue to hold everything in, thats what you see not silicone. To have the buttons make better contact I used a pencil eraser and cut it into three equal slices and put them inside the transmitter holes to take up the difference. When you do it you cut out a oval just a little smaller than the button plate you see. The plate seperates from the transmitter and to hold it back in I just used a dab of hot glue. Link to comment Share on other sites More sharing options...
DubbsFaris Posted December 17, 2009 Report Share Posted December 17, 2009 I upgraded my mirror to the homelink autodimmer with temp sensor...I like having that information at a glance...also keeps the cop lights from blinding me when I get pulled over... Link to comment Share on other sites More sharing options...
ruiner Posted December 17, 2009 Report Share Posted December 17, 2009 I used hot glue to hold everything in, thats what you see not silicone. To have the buttons make better contact I used a pencil eraser and cut it into three equal slices and put them inside the transmitter holes to take up the difference. When you do it you cut out a oval just a little smaller than the button plate you see. The plate seperates from the transmitter and to hold it back in I just used a dab of hot glue. yeah right after i posted i figured it was hot glue and not silicone. i have seen others use erasers also. Link to comment Share on other sites More sharing options...
ruiner Posted December 17, 2009 Report Share Posted December 17, 2009 I upgraded my mirror to the homelink autodimmer with temp sensor...I like having that information at a glance...also keeps the cop lights from blinding me when I get pulled over... the 2010 mirror has is and auto dimming with a mic in it or i would do that as well. Link to comment Share on other sites More sharing options...
