Grabber Posted December 12, 2009 Report Share Posted December 12, 2009 Here are the installation instructions that Ford uses to Install Front and rear brakes. Installing new Front Brake Pads - GT500.pdfRear Brake Caliper removal & Install.pdfRemoving & replacing rear brake pads.pdf Hope this helps. Installing new Front Brake Pads - GT500.pdf Rear Brake Caliper removal & Install.pdf Removing & replacing rear brake pads.pdf Quote Link to comment Share on other sites More sharing options...
Grabber Posted November 3, 2010 Author Report Share Posted November 3, 2010 Bump for the garage mech. This thread got burried. Quote Link to comment Share on other sites More sharing options...
Grabber Posted December 8, 2011 Author Report Share Posted December 8, 2011 Just made this one a sticky for a friend. Quote Link to comment Share on other sites More sharing options...
32V-SVT Posted December 10, 2011 Report Share Posted December 10, 2011 Hi Grabber, is this material off of an electronic shop manual??? Where can this be sourced? Thanks! Quote Link to comment Share on other sites More sharing options...
Grabber Posted December 11, 2011 Author Report Share Posted December 11, 2011 Hi Grabber, is this material off of an electronic shop manual??? Where can this be sourced? Thanks! Here ya go: http://www.teamshelby.com/forums/index.php?/topic/36616-free-on-line-ford-service-manual/page__fromsearch__1 Quote Link to comment Share on other sites More sharing options...
32V-SVT Posted December 12, 2011 Report Share Posted December 12, 2011 Awesome!!! You rock!!! Thanks! Quote Link to comment Share on other sites More sharing options...
Snoopy49 Posted June 15, 2012 Report Share Posted June 15, 2012 Is there any reason you can't use a c-clamp to compress the piston in the rear caliper? Quote Link to comment Share on other sites More sharing options...
Afdharley Posted July 23, 2012 Report Share Posted July 23, 2012 Is there any reason you can't use a c-clamp to compress the piston in the rear caliper? I've used this method before. Not on a Shelby, but as long as you're careful I'm sure it would work. Quote Link to comment Share on other sites More sharing options...
6-Speed Posted September 7, 2013 Report Share Posted September 7, 2013 (edited) Is there any reason you can't use a c-clamp to compress the piston in the rear caliper? I've used this method before. Not on a Shelby, but as long as you're careful I'm sure it would work. You cannot use just a C-clamp to reset the rear caliper pistons. The pistons must be turned in a clockwise direction while appling pressure to push them back into the caliper; this generally applies to rear brakes that combine the parking brake mechanism into the caliper. I use a caliper tool kit that's available from Harbor Freight. It allows me to turn the piston while applying forward pressure against a backing plate that's braced to the opposite side of the caliper. Edited September 7, 2013 by 6-Speed Quote Link to comment Share on other sites More sharing options...
gp1200x Posted May 22, 2018 Report Share Posted May 22, 2018 Here are the Big Brake kit installation instructions going from standard GT500 (standard, Brembo 4 piston) to the later 6 Piston Brembos and larger rear rotors with the axle flange replacement (axles pulled to install). Gives the brake bleeding process. Separated into 2 parts - space limitations big-brake-kit1.pdf Quote Link to comment Share on other sites More sharing options...
gp1200x Posted May 22, 2018 Report Share Posted May 22, 2018 2nd page of big-brake-kit installation big-brake-kit2.pdf Quote Link to comment Share on other sites More sharing options...
