pottydr Posted December 7, 2009 Report Share Posted December 7, 2009 This is the new gauge I installed, I still have the gauge pod, Install time was around 15 minutes, Had to order a Roush a/c vent gauge install bucket, air still works thur the vent and this is what it will do http://www.aeroforcetech.com RPM, MPH, Intake Air Temperature (post Intercooler) Ambient Air Temperature (pre Intercooler) Engine Coolant Temperature Exhaust Gas Temperature (PCM Calculated) Transmission Temp. (auto trans) Manifold Pressure (vacuum/boost) displayed in PSIFuel Temperature, Battery Voltage, Battery Temp Injector Pulse Width in msec. Injector Duty Cycle (%) Air Flow Rate into engine Long Term Fuel Trim Short Term Fuel Trim O2 Sensor Voltage Barometric Pressure Ignition Advance Base Spark PCM Spark Adjust Fuel Status (open/closed loop) Wastegate Solenoid Duty Cycle (%) Knock Retard Knock Sensor Raw Voltage Throttle Position Percentage Throttle Position Sensor Raw Volts Calculated Net Horsepower Engine Load Transmission Slip Current Transmission Gear Torque Delivered to Transmission Torque Converter lockup status Brake pressure Brake Booster Travel Steering Angle Non-driven Wheel Speed Lateral G's Yaw Fuel economy (instantaneous and average) P-ratio - pressure ratio MAP/Barometer 2 user configurable analog inputs** Link to comment Share on other sites More sharing options...
MMcGuirk Posted December 7, 2009 Report Share Posted December 7, 2009 Where did you get it? Link to comment Share on other sites More sharing options...
clark17357 Posted December 7, 2009 Report Share Posted December 7, 2009 Rick, I did not see where you have the read out for properly arming the car to car missiles or the read out for switching from missiles to guns. Did I miss that? :D Jim Link to comment Share on other sites More sharing options...
pottydr Posted December 7, 2009 Author Report Share Posted December 7, 2009 Yea there was 4 things I wanted to know, A/F ratio, trans temp, air temp to the s/c and voltage to the TB. I always wanted to know these things while I was at the track,, I forgot one important thing, When there is a blue car anywhere near me, it will alert me, Rick Rick, I did not see where you have the read out for properly arming the car to car missiles or the read out for switching from missiles to guns. Did I miss that? :D Jim Link to comment Share on other sites More sharing options...
SGT-C0056 Posted December 8, 2009 Report Share Posted December 8, 2009 Very nice...I guess Im retarted, but what is a KNOCK RETARD Link to comment Share on other sites More sharing options...
