hitman007 Posted December 3, 2009 Report Share Posted December 3, 2009 I had my SYNC system partially crash. The bluetooth functions stopped working, my phone disappeared from the menu and it would not let generate s SYNC code to repair the phone. Also my USB input went dead. After some troubleshooting I found a 5A fuse labeled SYNC. I pulled the fuse and it was fine. However pulling the fuse caused the SYNC system to reboot. (Disconnection the Batt would do the same but the fuse was easy.) After putting the fuse back in, bluetooth came on and my phone once again appeared and everything worked perfectly. Anyone else who may have this issue will find this post useful. Link to comment Share on other sites More sharing options...
DaFreak Posted December 3, 2009 Report Share Posted December 3, 2009 I had my SYNC system partially crash. The bluetooth functions stopped working, my phone disappeared from the menu and it would not let generate s SYNC code to repair the phone. Also my USB input went dead. After some troubleshooting I found a 5A fuse labeled SYNC. I pulled the fuse and it was fine. However pulling the fuse caused the SYNC system to reboot. (Disconnection the Batt would do the same but the fuse was easy.) After putting the fuse back in, bluetooth came on and my phone once again appeared and everything worked perfectly. Anyone else who may have this issue will find this post useful. Hi Hitman, I remember a few others had a similar issue and discovered there was a patch (from MS) that corrected it. Log/Setup your Sync account and it should guide you on the process. Cheers, DaFreak Link to comment Share on other sites More sharing options...
hitman007 Posted December 7, 2009 Author Report Share Posted December 7, 2009 Hi Hitman, I remember a few others had a similar issue and discovered there was a patch (from MS) that corrected it. Log/Setup your Sync account and it should guide you on the process. Cheers, DaFreak I had the new patch when this happened. Link to comment Share on other sites More sharing options...
DaFreak Posted December 7, 2009 Report Share Posted December 7, 2009 I had the new patch when this happened. Bullocks! Call MS support and put em to work. Let's see how good they really are.... DeFreak Link to comment Share on other sites More sharing options...
F150 Duke Posted December 8, 2009 Report Share Posted December 8, 2009 Bullocks! Call MS support and put em to work. Let's see how good they really are.... DeFreak LMAO, so you don't want it fixed then? Link to comment Share on other sites More sharing options...
DaFreak Posted December 9, 2009 Report Share Posted December 9, 2009 All, There is another patch released by MS. AR3T-14D544-AE Version SYNC V3.1 that reads "Also contained in this release are improvements to USB and Bluetooth features and phone and media device support." I'd give it a try. DaFreak Link to comment Share on other sites More sharing options...
66DNA Posted December 10, 2009 Report Share Posted December 10, 2009 All, There is another patch released by MS. AR3T-14D544-AE Version SYNC V3.1 that reads "Also contained in this release are improvements to USB and Bluetooth features and phone and media device support." I'd give it a try. DaFreak Not tech-savvy - - does anyone know if I can connect my iPhone via the SYNC system? Link to comment Share on other sites More sharing options...
blown65 Posted December 10, 2009 Report Share Posted December 10, 2009 Not tech-savvy - - does anyone know if I can connect my iPhone via the SYNC system? yup. I have mine done via Bluetooth and also done via the USB cable. Just go thru the sync process for the iPhone. Link to comment Share on other sites More sharing options...
