kahmann Posted November 21, 2009 Report Share Posted November 21, 2009 Here is the SB Ken is referring to - M-6009-A463SC* * Fits 2005-2009 Mustang GT * Forged steel 8-bolt crankshaft * Forged steel H-beam connecting rods * Forged aluminum 16cc dish 3 valve pistons * New oil pump * Uses M-6010-A46NA block, knock sensors are not removed from the block * Approximately 8.7:1 compression ratio when used with 50.3cc 3 valve heads * Lower compression for supercharged applications * Built with all NEW PARTS * Will accept 3V cylinder heads * Will not work with 2V or 4V cylinder heads * 8-bolt flywheel required (not included) Looks like a direct fit to me. MM Thanks Mike Link to comment Share on other sites More sharing options...
GT500-07 Posted November 21, 2009 Report Share Posted November 21, 2009 Great shot...What is that crank balancer/pulley? was that specific to your SC? I have seen alot of different balancer's but no t that one. GNB yes, specific to the Techco Link to comment Share on other sites More sharing options...
kahmann Posted November 21, 2009 Report Share Posted November 21, 2009 yes, specific to the Techco The Techco setup looks absolutely killer! I can't wait to see your new #'s. Ken Link to comment Share on other sites More sharing options...
strong_j Posted November 22, 2009 Author Report Share Posted November 22, 2009 wow that motor looks beast!!! what problem did you run into with the 8.5 cr?? and another question since im doing this myself and this is my first mustang engine i get to take out and rebuild is there any manuals, dvd's or tips yall can think of?? all my friends drive imports so thats all i have worked on, and the extra 4 cyclinders are alittle intimidating. lol. and what kind of 8 bolt flywheels are yall running?? thx for all y'alls help and opinions the short block should be coming in acouple of weeks so ill post pics of the build. Link to comment Share on other sites More sharing options...
GT500-07 Posted November 22, 2009 Report Share Posted November 22, 2009 Had a problem with the whole Techco engine, it was junk. Ripped it apart and went with all new forged internals and stage II heads and cams and uped the CR. The reason behind the upping the CR is, if the Techco blower gives me any more problems its coming off and TT's will be going on. Need to give the folks at SAI some more ideas since they liked our Turbonetics build so much (September 2008) Link to comment Share on other sites More sharing options...
