GT500WDE Posted November 13, 2009 Report Share Posted November 13, 2009 Ordered these valve and coil covers today. They are supposed to fit the 2010s. Thoughts? http://www.fordracingpartsdirect.com/Shelb..._p/m-6582-c.htm http://www.fordracingpartsdirect.com/Ford_..._p/m-6067-a.htm Thanks... WDE Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted November 13, 2009 Report Share Posted November 13, 2009 Ordered these valve and coil covers today. They are supposed to fit the 2010s. Thoughts? http://www.fordracingpartsdirect.com/Shelb..._p/m-6582-c.htm http://www.fordracingpartsdirect.com/Ford_..._p/m-6067-a.htm Thanks... WDE I have the same combo in mind for my 20-10. The only problem I have is, how to get the build plate/sticker off of the OEM covers and onto the FRP covers. Phill Pollard - Co. Springs, CO 2010 Kona Blue/White GT500 Link to comment Share on other sites More sharing options...
GT500WDE Posted November 13, 2009 Author Report Share Posted November 13, 2009 I have the same combo in mind for my 20-10. The only problem I have is, how to get the build plate/sticker off of the OEM covers and onto the FRP covers. Phill Pollard - Co. Springs, CO 2010 Kona Blue/White GT500 Dang. I didn't think about that. Will have to look into that. Link to comment Share on other sites More sharing options...
shel-b001 Posted November 13, 2009 Report Share Posted November 13, 2009 Try thin momofilment line & go slow should work. Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted November 13, 2009 Report Share Posted November 13, 2009 Try thin momofilment line & go slow should work. It's a really thin aluminium sticker. I use a similar method to tag motors I build. I take a roll of aluminium tape and punch "P&S Racing" into a piece then stick it on the block. It's pretty much impossible to get off without distorting the sticker, and I do that for a reason. (so someone can't transfer it to another motor). I've had success removing sticker goo using WD-40. I was thinking about spraying WD on the edges of the GT build sticker and letting it soak around the edges into the goo, then GENTLY pulling the sticker off, re-gooing and putting it on the new covers. I just wanted to wait until somene else found success before I screwed MINE up! LOL I"m still waiting..... Phill Pollard 2010 Kona Blue/White GT500 Link to comment Share on other sites More sharing options...
