SHELBYGT698 Posted November 6, 2009 Report Share Posted November 6, 2009 As most of you know my Shelby was involved in an accident? (deer) I've noticed and just thought about it now. I left my car running to see if it overheats because the radiator was been hit slightly and driving home from the accident sight I thought I smelt coolant burning. (could've just been deer cooking) After doing so, it wasn't overheating so I started to rev the engine a bit. Upon doing so, My speedo gauge starting jumping up and down but only over certain RPM. I also notice what sounded like the seltbelt chime when I went over a certain RPM. I thought this was strange. Can anyone relate to this or know if this would be normal. Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted November 6, 2009 Report Share Posted November 6, 2009 This is exactly the reason I don't wear speedos anymore! Link to comment Share on other sites More sharing options...
07SGT4578 Posted November 6, 2009 Report Share Posted November 6, 2009 This is exactly the reason I don't wear speedos anymore! Link to comment Share on other sites More sharing options...
SHELBYGT698 Posted November 6, 2009 Author Report Share Posted November 6, 2009 Thanks. I really need that. ( I really do mean that in a good way) I'm ready to break down and cry. Yeah Yeah, I know it's only a car blah blah blah....everyone has been telling me all day. Anyways, anybody experience the same thing? Or better yet, can anyone check on theirs. Cars in neutral with e-brakes. All you have to do is rev the engine. Don't have to redline. Link to comment Share on other sites More sharing options...
SHELBYBRO Posted November 6, 2009 Report Share Posted November 6, 2009 Well I ran out in the garage right quick and revved her up but the speedo stayed at 0. You may have a wiring issue now from the hit. A short is very easy to get after an accident. Link to comment Share on other sites More sharing options...
azmartin Posted November 7, 2009 Report Share Posted November 7, 2009 Ditto, any short, or ground connection knocked loose will do this. I would make sure they REPLACE the ENTIRE front harness. Wiring that is spliced or bothced together will haunt you forever. Good luck Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted November 7, 2009 Report Share Posted November 7, 2009 IF YOU RAN OVER THE DEER YOU MAY HAVE DAMAGE THE SPEEDO CABLE WHERE IN GOES INTO THE TRANS. SCOTTY Link to comment Share on other sites More sharing options...
SHELBYGT698 Posted November 7, 2009 Author Report Share Posted November 7, 2009 IF YOU RAN OVER THE DEER YOU MAY HAVE DAMAGE THE SPEEDO CABLE WHERE IN GOES INTO THE TRANS. SCOTTY If all is true, how about the seat belt chime? That doesn't make any sense for it to chime at all. Especially only 1 note. Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted November 8, 2009 Report Share Posted November 8, 2009 If all is true, how about the seat belt chime? That doesn't make any sense for it to chime at all. Especially only 1 note. YOU HAVE AN ACTIVE SEAT BELT RESTRAINT SYSTEM AND YOUR CHIME ISSUE MUST BE RELATED TO THE ACTIVE RESTRAINT SYSTEM AND YOU WILL PROBABLY HAVE TO RESET THE COMPUTER AND CLEAR THE SYSTEM. AS FOR THE SPEEDO DIFFERENT PROBLEM SAME DEER. SCOTTY Link to comment Share on other sites More sharing options...
1965coupe Posted November 10, 2009 Report Share Posted November 10, 2009 Any chance you can post pics of the damage? This definitely sounds like some major wiring damage, or perhaps a sensor. Link to comment Share on other sites More sharing options...
