Grabber Posted October 2, 2009 Report Share Posted October 2, 2009 Revised 9/28/09 Axel Whine TSB 09-20-4 tsb_09_20_04_Axel_Whine.pdf PS The revision is to update the model years to include the current one. tsb_09_20_04_Axel_Whine.pdf Quote Link to comment Share on other sites More sharing options...
ingram4868 Posted October 2, 2009 Report Share Posted October 2, 2009 And the list grows Quote Link to comment Share on other sites More sharing options...
Light66 Posted October 2, 2009 Report Share Posted October 2, 2009 Revised 9/28/09 Axel Whine TSB 09-20-4 tsb_09_20_04_Axel_Whine.pdf PS The revision is to update the model years to include the current one. Hi Grabber, Is this related to the ring and pinion gear whine? Quote Link to comment Share on other sites More sharing options...
wagsblueshirts Posted October 2, 2009 Report Share Posted October 2, 2009 Revised 9/28/09 Axel Whine TSB 09-20-4 tsb_09_20_04_Axel_Whine.pdf PS The revision is to update the model years to include the current one. So if the holes are already pre-drilled there, it seems like they just "forgot" to install the dampers? Wow! Thanks, Grabber. Wags Quote Link to comment Share on other sites More sharing options...
03 DSG Snake Posted October 2, 2009 Report Share Posted October 2, 2009 Interesting. Looks like a new version of the old 'Moose Balls'. Don't recall seeing those under mine, looks like more weight to me. Pedal on the right will take care of the whine Quote Link to comment Share on other sites More sharing options...
6-Speed Posted October 2, 2009 Report Share Posted October 2, 2009 Interesting. Looks like a new version of the old 'Moose Balls'. Don't recall seeing those under mine, looks like more weight to me. Pedal on the right will take care of the whine They were installed on my car - the pair adds 10 lbs. Quote Link to comment Share on other sites More sharing options...
canuck Posted October 2, 2009 Report Share Posted October 2, 2009 They were installed on my car - the pair adds 10 lbs. Just took mine off do not need the extra weight! Quote Link to comment Share on other sites More sharing options...
Grabber Posted October 3, 2009 Author Report Share Posted October 3, 2009 Just took mine off do not need the extra weight! They are there for a reason. Here's mine. Quote Link to comment Share on other sites More sharing options...
LuckySnake Posted October 3, 2009 Report Share Posted October 3, 2009 They are there for a reason. Here's mine. They are installed to absorb "noise" and serve no other mechanical purpose. I can't hear any difference with them off. They are 10 lbs of useless dead weight, IMO. Mine are now stashed away for some purist to reinstall many years from now. Quote Link to comment Share on other sites More sharing options...
GT500_ROCKS Posted October 3, 2009 Report Share Posted October 3, 2009 Just took mine off do not need the extra weight! ACTUALLY WEIGHT THERE IS exactly WHAT YOU NEED Quote Link to comment Share on other sites More sharing options...
Tob Posted October 3, 2009 Report Share Posted October 3, 2009 They are there for a reason. This is true. They are there as a band-aid NVH fix. They are calibrated (by weight and location) specifically for the assembly as it left the assembly line. Once you change the axle ratio they (the OE 3.31 assembly ones) are worthless. At that point, by all means, round file them. Tob Quote Link to comment Share on other sites More sharing options...
03 DSG Snake Posted October 3, 2009 Report Share Posted October 3, 2009 This is true. They are there as a band-aid NVH fix. They are calibrated (by weight and location) specifically for the assembly as it left the assembly line. Once you change the axle ratio they (the OE 3.31 assembly ones) are worthless. At that point, by all means, round file them. Tob Just like the Moose Balls on the other cars. Once the gears are swapped they are extra worthless. Quote Link to comment Share on other sites More sharing options...
Grabber Posted October 3, 2009 Author Report Share Posted October 3, 2009 They are installed to absorb "noise" and serve no other mechanical purpose. I can't hear any difference with them off. They are 10 lbs of useless dead weight, IMO. Mine are now stashed away for some purist to reinstall many years from now. Yes that is why they are there. Thank you. Thank you very much. Sincerely, Mr Grabber Quote Link to comment Share on other sites More sharing options...
GT500Tow Posted October 5, 2009 Report Share Posted October 5, 2009 Hey Grabber, You think a pair of these would help also ? Quote Link to comment Share on other sites More sharing options...
ZXMustang Posted October 6, 2009 Report Share Posted October 6, 2009 I was wondering why the hell I was hearing a weird whine at low speeds. Quote Link to comment Share on other sites More sharing options...
me32 Posted October 9, 2009 Report Share Posted October 9, 2009 i took mine off now that i have 373's gears. didnt make any difference in NVH. but everyone experience will differ Quote Link to comment Share on other sites More sharing options...
