DrKSGT Posted September 26, 2009 Report Share Posted September 26, 2009 I got my KR Trunk liner and did some basic checks before I start drilling holes. Appears that one of the push pins has no function because there is no metal to drill into. Liner is nice and really fits the contours of the trunk lid. Very little option on where it goes when placed against the trunk. It also seems to be an exact fit to the trunk seal as I set it there and it was net to the inner edge of the seal. Trunk seemed to closer a bit harder. I tooke a pencil to mark all spots in liner requiring a push pin so I would have idea on what would be behind each hole. Every thing was good except for one left of the trunk lock hardware where trunk lid goes from horizontal to vertical. Right side picture I am adding shows relative close condition for hole. I confirmed the left side wants the hole to be drilled in the rectangular hole of the inner reinforcement panel. Depression in the liner can easily be made to touch the metal surface. Anyone have a similar condition adding this to their SGT? Or do I just put the push pin in the liner for looks and not worry about it? Reference looking into trunk Left side liner detail Left Side Tunk lid - no pencil mark Right side trunk lid for same liner detail with pencil mark Tom Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted September 26, 2009 Report Share Posted September 26, 2009 I brought mine to my fav body shop and they installed it for $45. I don't trust myself not to F it up. :-) All the push pins are there so I can't help you other than to say that all are inserted so there must be something there. See pic: Link to comment Share on other sites More sharing options...
dupuyf Posted September 26, 2009 Report Share Posted September 26, 2009 i just order one how long did it take to get it and what is it made of thanks fd Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted September 26, 2009 Report Share Posted September 26, 2009 i just order one how long did it take to get it and what is it made of thanks fd About a week or so...not long. It's made out of the same material, or type of material, that the factory trunk bed cover is made of so it looks like it's factory installed. REALLY cleans it up. I noticed the 2010 GT's come with these installed. At least the two I saw away. Link to comment Share on other sites More sharing options...
WildAzCat Posted September 26, 2009 Report Share Posted September 26, 2009 I got my KR Trunk liner and did some basic checks before I start drilling holes. Appears that one of the push pins has no function because there is no metal to drill into. Liner is nice and really fits the contours of the trunk lid. Very little option on where it goes when placed against the trunk. It also seems to be an exact fit to the trunk seal as I set it there and it was net to the inner edge of the seal. Trunk seemed to closer a bit harder. I tooke a pencil to mark all spots in liner requiring a push pin so I would have idea on what would be behind each hole. Every thing was good except for one left of the trunk lock hardware where trunk lid goes from horizontal to vertical. Right side picture I am adding shows relative close condition for hole. I confirmed the left side wants the hole to be drilled in the rectangular hole of the inner reinforcement panel. Depression in the liner can easily be made to touch the metal surface. Anyone have a similar condition adding this to their SGT? Or do I just put the push pin in the liner for looks and not worry about it? Tom I guess I didn't give it as much thought as you did. I simply lined it up and masked it to the deck lid and started drilling. I pushed the pins as I went along and each one took. I guess I got lucky. My liner came with in a week. Impressive shipping... Link to comment Share on other sites More sharing options...
kronus01 Posted September 27, 2009 Report Share Posted September 27, 2009 I just got done with my trunk liner install and let me tell you I took my time but that didn't take away from the fact that I was sweating like a #%$#$%#!!! I think its a great touch and after I relax a bit I will add some pics I did come across the same problem as DrkSGT but on both sides instead of just one. After a little moving around I got it to work out just fine, outside of one close call that I had it went smoothly and I love how this simple touch made the trunk look so much better Link to comment Share on other sites More sharing options...
