03 DSG Snake Posted September 4, 2009 Report Share Posted September 4, 2009 Whenever I get on the car, shifting usually around 6k rpm, I notice it has a tendency to allow the Revs to continue to climb a bit, even when I let off the gas between shifts. Is this just a by-product of the Fly By Wire? I still can't get used to it coming from years of cable actuated Mustang throttle bodies. Quote Link to comment Share on other sites More sharing options...
cluscher Posted September 4, 2009 Report Share Posted September 4, 2009 Whenever I get on the car, shifting usually around 6k rpm, I notice it has a tendency to allow the Revs to continue to climb a bit, even when I let off the gas between shifts. Is this just a by-product of the Fly By Wire? I still can't get used to it coming from years of cable actuated Mustang throttle bodies. It's a tune issue. If you have an aftermarket tune check with your tuner. If not, bring it in to the dealership. I had the same problem with my aftermarket tune and got it resolved lickedy split. Simple fix. Quote Link to comment Share on other sites More sharing options...
03 DSG Snake Posted September 4, 2009 Author Report Share Posted September 4, 2009 It's a tune issue. If you have an aftermarket tune check with your tuner. If not, bring it in to the dealership. I had the same problem with my aftermarket tune and got it resolved lickedy split. Simple fix. Did it for me even when stock. I think my driving doesn't mesh with the car. Any idea what Parameters were changed in your tune to fix it? Quote Link to comment Share on other sites More sharing options...
silver08elly Posted September 4, 2009 Report Share Posted September 4, 2009 Mine does it too but at any rpm. No matter when i shift its almost like the moto gp motorcycle racers who have to blip the throttle when they shift. Seems like its what the car does. Maybe this is causing more heat onthe fly wheels......prolly not Quote Link to comment Share on other sites More sharing options...
cluscher Posted September 4, 2009 Report Share Posted September 4, 2009 Did it for me even when stock. I think my driving doesn't mesh with the car. Any idea what Parameters were changed in your tune to fix it? No idea. My tune is from Lund. I emailed him about it and he confirmed it was a quirk in the tune. He sent me a new file and it was gone. I know this issue has been posted a couple of times and people got it fixed with a tune revision. Quote Link to comment Share on other sites More sharing options...
chuckstang Posted September 7, 2009 Report Share Posted September 7, 2009 Not sure if this is the same issue but at a car show, some folks wanted me to rev me motor while idling and I bounced it off the red line but after taking my foot off the gas, it took a couple seconds for the rpms to come down, they dropped very slowly, sorta scared me since at redline is not exactly a place you want your rpms to stick or hang ???? I have the FRPP tune with CAI Quote Link to comment Share on other sites More sharing options...
silver08elly Posted September 7, 2009 Report Share Posted September 7, 2009 Not sure if this is the same issue but at a car show, some folks wanted me to rev me motor while idling and I bounced it off the red line but after taking my foot off the gas, it took a couple seconds for the rpms to come down, they dropped very slowly, sorta scared me since at redline is not exactly a place you want your rpms to stick or hang ???? I have the FRPP tune with CAI Thats all in the tune. Mine used to do it too but then the tuner adjusted it. No more problem like that. Quote Link to comment Share on other sites More sharing options...
