ARMORINE Posted August 26, 2009 Report Share Posted August 26, 2009 September 19th im facing off against a roush 427r, its a grudge match in my club, he pulled a 438 rwhp on the dyno but suffers from MASSIVE tire spin issues. his last run at the drags was a 13.8! currently im running at 306 rwhp (the tune i have i feel is crappy) as of the last dyno(3 weeks ago). i just put on a UDP kit yesterday and will be installing 3.73 gears in 2 weeks. i was going to put hot rod cams on unfortunately i will not have time to do so. with the gt500 throttle body i should hit at least 320rwhp with a revised race tune. i have a set of 285/40zr/18's for my new wheels coming tomorrow. they will be mounted and balanced before the mods vs rods shootout. mods as follows CMDP's steeda inlet elbow steeda crome moly rear control arms with poly bushings steed rear race pan hard bar and brace jba long tube headers 7/8 primarys into 3 inch collectors jba 3 inch h-pipe shelby jba highflow mufflers steeda under drive pulley kit gt500 throttle body kahman what do you think i should be making with this set up? if i have the money im going to have our local dyno master(greg giliam) build a new custom race tune for me. oh and i'll be switching to a set of drag slicks for the face off after the first few runs. roush boy will be using stockers. im a better driver then he is and i shift far faster. so do i have a chance? discuss P.S. i'll be taping this one for sure! im looking for a 12.whatever Link to comment Share on other sites More sharing options...
shelbytexan Posted August 26, 2009 Report Share Posted August 26, 2009 If you are going to race the quarter mile then you might want to go 410 gears. You will definately feel the difference. The 373's are really to close to stock to get a big improvement. If you were going to s/c then 373's would be fine but still pretty close to what you have. With 410's ,longtubes, lower pulleys and agressive tune you should run in the mid 12's which should be enough to take the Roush in the quarter. The 410's could be the difference between winning and losing. Good-Luck. Link to comment Share on other sites More sharing options...
HORSBYT Posted August 26, 2009 Report Share Posted August 26, 2009 If you are going to race the quarter mile then you might want to go 410 gears. You will definately feel the difference. The 373's are really to close to stock to get a big improvement. If you were going to s/c then 373's would be fine but still pretty close to what you have. With 410's ,longtubes, lower pulleys and agressive tune you should run in the mid 12's which should be enough to take the Roush in the quarter. The 410's could be the difference between winning and losing. Good-Luck. +1 on the 4:10's, don't even bother with the 3:73's. Link to comment Share on other sites More sharing options...
ARMORINE Posted August 26, 2009 Author Report Share Posted August 26, 2009 +1 on the 4:10's, don't even bother with the 3:73's. the problem is im a track guy...i like to run hallet ALOT. would 4:10's be too steep for circuit racing or would i be able to continue curcuit racing after i eat this roush? Link to comment Share on other sites More sharing options...
gbstang Posted August 26, 2009 Report Share Posted August 26, 2009 Shoot, For the price of a set of gears and an install (assuming your having it done) you could buy a complete used rear with 4:10's online (ebay, parts classifieds etc.). doesn't take that long to change it out, so you could still drag (when necessary) and do the road course.. Just a thought.. GNB Link to comment Share on other sites More sharing options...
