navyboy12807 Posted August 25, 2009 Report Share Posted August 25, 2009 im in the process of purchasing a 07 shelby gt500 heavily motified puts 711rwhp and 695rwtq still needs to be tuned again, but my question is can i run a 315, 325,or 335 rear tire on a 20x10.5 or 11 inch wheel? can i do it on a 18inch wheels it has the frpp suspension package. please give me some guidance? any help would be greatfull!! the guy at true forged didnt know and didnt seem very knowledgable. thanks jon Link to comment Share on other sites More sharing options...
JeffJ Posted August 25, 2009 Report Share Posted August 25, 2009 You can do a little searching in the GT500 Modifications and Tech forum below. There are many discussions on this topic there. Here's one from today: Link Link to comment Share on other sites More sharing options...
shelbymotorsports Posted August 25, 2009 Report Share Posted August 25, 2009 Ok who's our big tire expert here that can help new member Jon out? Steve Link to comment Share on other sites More sharing options...
navyboy12807 Posted August 25, 2009 Author Report Share Posted August 25, 2009 You can do a little searching in the GT500 Modifications and Tech forum below. There are many discussions on this topic there. Here's one from today:Link thanks i did try and search couldnt really find what i was after, i wanted to know and see a pick of someone running a 315 or wider. i searched a combo of 315 rear tire and didnt really find what i was wanting to know. im in the process of purchasing the car and would like to buy wheels so i can put them on asap as the rear breaks lose easy 1-4 in boost. Link to comment Share on other sites More sharing options...
navyboy12807 Posted August 25, 2009 Author Report Share Posted August 25, 2009 Ok who's our big tire expert here that can help new member Jon out? Steve i think im really going to like this site just because of people like you. you dont find to many people like you in life that go that extra step!!! ps hope i made your day! Link to comment Share on other sites More sharing options...
kahmann Posted August 25, 2009 Report Share Posted August 25, 2009 315's won't clear factory geometry suspension. If you have a Griggs rear suspension setup, you can add their '315 kit' shock brackets, allowing you to run 315's in the rear. http://www.grigg ing.com/product_info.p...products_id=598 Ken Link to comment Share on other sites More sharing options...
navyboy12807 Posted August 25, 2009 Author Report Share Posted August 25, 2009 315's won't clear factory geometry suspension.If you have a Griggs rear suspension setup, you can add their '315 kit' shock brackets, allowing you to run 315's in the rear. http://www.grigg ing.com/product_info.p...products_id=598 Ken im running the frpp suspension kit and the Fays2 Watts Link would i still need this kit? and would i be able to run the 20s or 18s? oh i forgot thanks for the info. Link to comment Share on other sites More sharing options...
kahmann Posted August 25, 2009 Report Share Posted August 25, 2009 im running the frpp suspension kit and the Fays2 Watts Link would i still need this kit? and would i be able to run the 20s or 18s?oh i forgot thanks for the info. 315's won't clear FRPP suspension, as far as I know. The Griggs kit only works because the coilover mount brackets are reversed, allowing for the additional clearance. I don't know of a similar solution with traditional dampers. Wheel diameter shouldn't make a difference, as long as the tire sidewall is sized properly to compensate. Good luck. Ken Link to comment Share on other sites More sharing options...
navyboy12807 Posted August 25, 2009 Author Report Share Posted August 25, 2009 315's won't clear FRPP suspension, as far as I know. The Griggs kit only works because the coilover mount brackets are reversed, allowing for the additional clearance. I don't know of a similar solution with traditional dampers. Wheel diameter shouldn't make a difference, as long as the tire sidewall is sized properly to compensate.Good luck. Ken i guess the svt department didnt think this part throw to much very fustrating and time consuming as i wish i could say hey i want those wheels with a 315, 325, or 335 rear tire and be done with it! Link to comment Share on other sites More sharing options...
navyboy12807 Posted August 25, 2009 Author Report Share Posted August 25, 2009 i guess the svt department didnt think this part throw to much very fustrating and time consuming as i wish i could say hey i want those wheels with a 315, 325, or 335 rear tire and be done with it! any one on here running a 315 or fatter tire on there gt500? if so could you chime in and let me how what you had to do to get them to work if anything? thanks jon Link to comment Share on other sites More sharing options...
RACERX009 Posted August 26, 2009 Report Share Posted August 26, 2009 im in the process of purchasing a 07 shelby gt500 heavily motified puts 711rwhp and 695rwtq still needs to be tuned again, but my question is can i run a 315, 325,or 335 rear tire on a 20x10.5 or 11 inch wheel? can i do it on a 18inch wheels it has the frpp suspension package. please give me some guidance? any help would be greatfull!! the guy at true forged didnt know and didnt seem very knowledgable. thanks jon You can go 20x11 with 315 steeda sells the rims and awhile ago, I read a write up on GT500 with those rear setup. I was going that way but steeda rims dont make me want switch. I tried to get my rims widen with no luck. Link to comment Share on other sites More sharing options...
navyboy12807 Posted August 26, 2009 Author Report Share Posted August 26, 2009 You can go 20x11 with 315 steeda sells the rims and awhile ago, I read a write up on GT500 with those rear setup. I was going that way but steeda rims dont make me want switch. I tried to get my rims widen with no luck. greatly appreciated i will give steeda wheels a shot. do you have a link to the write or know where i could search? thanks jon Link to comment Share on other sites More sharing options...
1sweetazzgt500 Posted August 26, 2009 Report Share Posted August 26, 2009 I have H&R SS Suspension (Springs/Shock's/Sway Bars) with 18in Shelby Type S1 Wheels, Rears widened to 11in and Toyo Proxes 315-35-18 will fit with this set-up. Seems several guys on here are running 335's with 11in Rears w no Problem. http://www.teamshelby.com/forums/index.php?showtopic=42662 Check this Thread out. Link to comment Share on other sites More sharing options...
RACERX009 Posted August 27, 2009 Report Share Posted August 27, 2009 greatly appreciated i will give steeda wheels a shot. do you have a link to the write or know where i could search? thanks jon Steeda.com Link to comment Share on other sites More sharing options...
GT500-07 Posted August 27, 2009 Report Share Posted August 27, 2009 Check out Gordy's ride http://www.teamshelby.com/forums/index.php...c=35466&hl= Link to comment Share on other sites More sharing options...
