Jody Posted August 19, 2009 Report Share Posted August 19, 2009 I think the Super Snake hood pins look dull to me. Did anyone change theirs and which type did you use? I am told that some of the other hood pins that Shelby Performance Parts sells do not work. Quote Link to comment Share on other sites More sharing options...
Robert M Posted August 19, 2009 Report Share Posted August 19, 2009 I think the Super Snake hood pins look dull to me. Did anyone change theirs and which type did you use? I am told that some of the other hood pins that Shelby Performance Parts sells do not work. I like these..................... R Quote Link to comment Share on other sites More sharing options...
Jody Posted August 19, 2009 Author Report Share Posted August 19, 2009 (edited) Thanks, are those the GT500 hood pins sold by Shelby Performance Parts? I enlarged the picture, I see they are. I am ordering them now! Edited August 19, 2009 by Jody Quote Link to comment Share on other sites More sharing options...
Robert M Posted August 19, 2009 Report Share Posted August 19, 2009 (edited) Thanks, are those the GT500 hood pins sold by Shelby Performance Parts? I enlarged the picture, I see they are. I am ordering them now! Here is a closer picture........... There is more to the story. These pins were installed at one of the "authorized" Shelby Super Snake conversion centers, but I do not remember which one. I have seen these hood pins installed on other Super Snake hoods and the latch pin does not fit correctly in the aluminum plate. The main pin that attaches to the car has to be bent in such a way that it properly comes through the hole in the hood, but also allows the latch pin to properly fit it the aluminum plate. R Edited August 19, 2009 by Robert M Quote Link to comment Share on other sites More sharing options...
Whammer Posted June 30, 2011 Report Share Posted June 30, 2011 (edited) I was at Sean Hyland's today getting my Super Snake STB installed (thanks again Robert) and saw the GT500 hoods pins pictured above. I thought they looked great and Sean had a set in stock. Well needless to say they are now on my car! Just a side note...the old screw holes did not match up with this set so new holes needed to be drilled. Edited June 30, 2011 by Whammer Quote Link to comment Share on other sites More sharing options...
VaporDude Posted June 30, 2011 Report Share Posted June 30, 2011 I was at Sean Hyland's today getting my Super Snake STB installed (thanks again Robert) and say the GT500 hoods pins pictured above. I thought they looked great and Sean had a set in stock. Well needless to say they are now on my car! Just a side note...the old screw holes did not match up with this set so new holes needed to be drilled. Those are the ones that I am looking for and SPP is out of stock and has been for some time. Quote Link to comment Share on other sites More sharing options...
Whammer Posted June 30, 2011 Report Share Posted June 30, 2011 Those are the ones that I am looking for and SPP is out of stock and has been for some time. I think Shelby has gone to a new supplier for many of their parts, thus the long wait for out of stock parts. Quote Link to comment Share on other sites More sharing options...
Robert M Posted June 30, 2011 Report Share Posted June 30, 2011 I was at Sean Hyland's today getting my Super Snake STB installed (thanks again Robert) and saw the GT500 hoods pins pictured above. I thought they looked great and Sean had a set in stock. Well needless to say they are now on my car! Just a side note...the old screw holes did not match up with this set so new holes needed to be drilled. You're welcome!! I used the same four holes with mine. I changed the original phillips screws for stainless steel torx bit, just for a little more detail................ R Quote Link to comment Share on other sites More sharing options...
VaporDude Posted June 30, 2011 Report Share Posted June 30, 2011 Can someone post a picture where the pins are mounted on the radiator support? Quote Link to comment Share on other sites More sharing options...
Robert M Posted June 30, 2011 Report Share Posted June 30, 2011 (edited) Can someone post a picture where the pins are mounted on the radiator support? I am currently at the beach for this week and will not be back home until Monday. I also have a a radiator cover on mine, so the actual radiator support is covered except for a hole in the hood pin area. Whammer may be able to get a picture of his hood pin mounting in this area? Here, check out this thread. Post #2, picture #2 is of my car showing a picture before I installed my radiator cover. Sorry the picture is not more clear............ http://www.teamshelby.com/forums/index.php?/topic/68279-anyone-have-a-rad-cover-for-their-ss/ R Edited June 30, 2011 by Robert M Quote Link to comment Share on other sites More sharing options...
Whammer Posted July 1, 2011 Report Share Posted July 1, 2011 You're welcome!! I used the same four holes with mine. I changed the original phillips screws for stainless steel torx bit, just for a little more detail................ R Where did you get Super Snake hood pins??? Don't tell me I need to buy a different set??? LOL Quote Link to comment Share on other sites More sharing options...
Max Cruise Posted July 1, 2011 Report Share Posted July 1, 2011 Where did you get Super Snake hood pins??? Don't tell me I need to buy a different set??? LOL Damn it! You stole my words.I was about to post the same,when I saw your post.Otherwise,it'd have been a double post,anyway... Quote Link to comment Share on other sites More sharing options...
dbackg Posted July 1, 2011 Report Share Posted July 1, 2011 I have the black anodized set that just says "SHELBY" however, I have not installed them. Quote Link to comment Share on other sites More sharing options...
Robert M Posted July 1, 2011 Report Share Posted July 1, 2011 Where did you get Super Snake hood pins??? Don't tell me I need to buy a different set??? LOL I bought a plain (not engraved) set of the Shelby billet hoods pins and had a friend of mine engrave them. I have a lot of $$$ in them, about $100 including shipping for the pins, then the artwork, set-up and engraving of the plates on a CNC machine........lots of $$$. R Quote Link to comment Share on other sites More sharing options...
Whammer Posted July 1, 2011 Report Share Posted July 1, 2011 Can someone post a picture where the pins are mounted on the radiator support? I'm at work today (24hrs) but I'll try and post up a pic on Sat. Quote Link to comment Share on other sites More sharing options...
