Dennis Brown Posted August 16, 2009 Report Share Posted August 16, 2009 I just bought a 2008 KR and I have noticed a rattling nose that sounds like the throw out bearing. It only does it when it is at a idlethe cluth is out and in netural the noise quites when you push in the clutch. I took it to the Ford Dealer and there not sure what is it does any one have this problem Link to comment Share on other sites More sharing options...
Grabber Posted August 16, 2009 Report Share Posted August 16, 2009 I just bought a 2008 KR and I have noticed a rattling nose that sounds like the throw out bearing. It only does it when it is at a idlethe cluth is out and in netural the noise quites when you push in the clutch. I took it to the Ford Dealer and there not sure what is it does any one have this problem It's normal. They all do it. http://www.teamshelby.com/forums/index.php...ic=37150&hl= Link to comment Share on other sites More sharing options...
6-Speed Posted August 16, 2009 Report Share Posted August 16, 2009 Turn on the AC if you really want to hear it. It's normal. Link to comment Share on other sites More sharing options...
SicShelby Posted August 16, 2009 Report Share Posted August 16, 2009 It's kind of weird to hear the gear rollover when you are creeping, or first starting off. Makes it sound like it has a tranny from the 60's, or something... Normal it is! Link to comment Share on other sites More sharing options...
FormerGmc Posted August 17, 2009 Report Share Posted August 17, 2009 Yep! It's normal. Link to comment Share on other sites More sharing options...
Dennis Brown Posted August 18, 2009 Author Report Share Posted August 18, 2009 It's normal. They all do it. http://www.teamshelby.com/forums/index.php...ic=37150&hl= This link states it makes the noise when your are in 1st or 2nd Gear mine only makes it when I'm in netural it will stop if I turn the AC off though. Link to comment Share on other sites More sharing options...
Light66 Posted August 18, 2009 Report Share Posted August 18, 2009 This link states it makes the noise when your are in 1st or 2nd Gear mine only makes it when I'm in netural it will stop if I turn the AC off though. My GT500 does it at a stop, in neutral with the clutch not engaged with or without AC. Try pushing the clutch when at a stop. The noise will go away. YES, this is normal for all GT500's. Link to comment Share on other sites More sharing options...
Dennis Brown Posted August 18, 2009 Author Report Share Posted August 18, 2009 My GT500 does it at a stop, in neutral with the clutch not engaged with or without AC. Try pushing the clutch when at a stop. The noise will go away. YES, this is normal for all GT500's. Thank you it does stop when you push in the clutch. Link to comment Share on other sites More sharing options...
