QuickSilverShelby Posted August 3, 2009 Report Share Posted August 3, 2009 Any one know how to remove the sill plate on a 2007 Shelby. I need to remove the palstic piece together with the SVT aluminum insert as one piece. Also, is the sill from a convertible (the palstic piece together with the aluminum piece) interchangeable with a coupe? Thanks QSS Link to comment Share on other sites More sharing options...
kannady Posted August 3, 2009 Report Share Posted August 3, 2009 Any one know how to remove the sill plate on a 2007 Shelby. I need to remove the palstic piece together with the SVT aluminum insert as one piece. Also, is the sill from a convertible (the palstic piece together with the aluminum piece) interchangeable with a coupe? Thanks QSS It just clips in where it meets the carpet and has double sided tape underthe flat portion. You just have to grab and slowly pull. Link to comment Share on other sites More sharing options...
sharabi Posted August 3, 2009 Report Share Posted August 3, 2009 Hair dryer then fishing line slide it underneath so you do not bend it, same way to remove the lettering from the deck lid. Link to comment Share on other sites More sharing options...
kahmann Posted August 3, 2009 Report Share Posted August 3, 2009 Hair dryer then fishing line slide it underneath so you do not bend it, same way to remove the lettering from the deck lid. That's if you want to remove the insert. If you want to remove the entire assembly, just grab on and slowly pull it till the clips come out of their holes in the door frame. Link to comment Share on other sites More sharing options...
hotrodrock Posted August 3, 2009 Report Share Posted August 3, 2009 I need to replace mine. Read here quite awhile back that the thing to do is to order the plastic part for a V6 Mustang. Apparently the same piece but lots cheaper for some reason??? Any feedback about that? Link to comment Share on other sites More sharing options...
Grabber Posted August 3, 2009 Report Share Posted August 3, 2009 Just grab the edge and pull. Comes right off. Link to comment Share on other sites More sharing options...
OCD Posted August 3, 2009 Report Share Posted August 3, 2009 Ouch... Mine sills still have the plastic on them... No way could I rip them off like that... Any other options? Link to comment Share on other sites More sharing options...
shel-b001 Posted August 3, 2009 Report Share Posted August 3, 2009 You can use fish line heat them with a hair dryer & pull the fish line through & they will come off un damaged . I guess Grabber didn`t want to save his. Link to comment Share on other sites More sharing options...
Grabber Posted August 4, 2009 Report Share Posted August 4, 2009 You can use fish line heat them with a hair dryer & pull the fish line through & they will come off un damaged . I guess Grabber didn`t want to save his. I used both of mine in a special place. Outside mailbox (look right below the mailbox). Show mailbox (look inside). Link to comment Share on other sites More sharing options...
shel-b001 Posted August 4, 2009 Report Share Posted August 4, 2009 Ah nice .I knew you would put them to good use somewhere. Link to comment Share on other sites More sharing options...
OCD Posted August 4, 2009 Report Share Posted August 4, 2009 That's a pretty fancy mailbox!! The one withthe siggy is even better... What's in that mailbox? Link to comment Share on other sites More sharing options...
Grabber Posted August 4, 2009 Report Share Posted August 4, 2009 What's in that mailbox? One of my wifes thongs. Link to comment Share on other sites More sharing options...
OCD Posted August 4, 2009 Report Share Posted August 4, 2009 Atta boy, living up to your name!! Link to comment Share on other sites More sharing options...
Grabber Posted August 4, 2009 Report Share Posted August 4, 2009 Atta boy, living up to your name!! Link to comment Share on other sites More sharing options...
