odgreen001 Posted July 22, 2009 Report Share Posted July 22, 2009 Why does the Shelby GT 500 weigh so much more then a regular Mustang GT? Where is all the extra weight coming from? Link to comment Share on other sites More sharing options...
fastfords Posted July 22, 2009 Report Share Posted July 22, 2009 Allright, I will get it started and others can chime in. 5.4 over 4.6 Supercharger and related necessities larger brakes 6 speed (I assume heavier than a 5 speed) Link to comment Share on other sites More sharing options...
Slabo Posted July 22, 2009 Report Share Posted July 22, 2009 Is the radiator heavier? I know the wheels and tires are not the lightest. Link to comment Share on other sites More sharing options...
Secondo Posted July 22, 2009 Report Share Posted July 22, 2009 Mustang GT is about 3400lbs, GT500- 3900lbs. The 4.6 is all aluminum, the 5.4 has an iron block. The complete 5.4 engine weighs over 800lbs. The GT500 transmission is larger, the wheels/tires are larger, larger brakes, etc. which all adds up to 500lbs. Link to comment Share on other sites More sharing options...
thewheelman Posted July 22, 2009 Report Share Posted July 22, 2009 Isn't there also some additional bracing for the 5.4 and increased body stiffness? Link to comment Share on other sites More sharing options...
kahmann Posted July 22, 2009 Report Share Posted July 22, 2009 Isn't there also some additional bracing for the 5.4 and increased body stiffness? Nope. The majority of the difference is in the engine bay. The iron block makes up about 70-80 lbs. The GT500 DOHC heads are also heavier than the MGT's SOHC heads. The SVT rims weigh in around 30 lbs a piece, whereas the MGT rims weigh around 25 lbs. Ken Link to comment Share on other sites More sharing options...
MMcGuirk Posted July 22, 2009 Report Share Posted July 22, 2009 Isn't there also some additional bracing for the 5.4 and increased body stiffness? No bracing except strut tower brace. All 07 and up S197s got unibody welds 9" on center as opposed to 14" to stiffen things up in preparation for the GT500 package. Link to comment Share on other sites More sharing options...
SicShelby Posted July 22, 2009 Report Share Posted July 22, 2009 Intercooler... haven't seen that yet (of course, "supporting mod" to the s/c). Link to comment Share on other sites More sharing options...
FiaCobra Posted July 25, 2009 Report Share Posted July 25, 2009 GT-500 vs Mustang GT Iron 5.4L over Aluminum 4.6L Supercharger (GT-500) Intercooler (GT-500) Larger brakes (Brembo) (GT-500) Tremec TR6060 6spd vs TR3650 5 spd Strut tower brace (GT-500) ........not sure about the driveshaft. The GT-500 has a 2 piece steel drive shaft that weighs a ton. Not sure what the Mustang GT has. Link to comment Share on other sites More sharing options...
kahmann Posted July 25, 2009 Report Share Posted July 25, 2009 GT-500 vs Mustang GT Iron 5.4L over Aluminum 4.6L Supercharger (GT-500) Intercooler (GT-500) Larger brakes (Brembo) (GT-500) Tremec TR6060 6spd vs TR3650 5 spd Strut tower brace (GT-500) ........not sure about the driveshaft. The GT-500 has a 2 piece steel drive shaft that weighs a ton. Not sure what the Mustang GT has. The MGT also has a 2 piece shaft that weighs a ton. Link to comment Share on other sites More sharing options...
msbmustang Posted July 26, 2009 Report Share Posted July 26, 2009 The MGT also has a 2 piece shaft that weighs a ton. Hi kahmann, The GT500 and the regular Mustang GT both use the same 2 piece driveshaft. I know because I have a 1pc AL drive shaft in my storage area waiting for my Clutch TSB warranty to expire in 1k so I can install it. Along with the Ford racing short shifter they would not install during the Clutch TSB. Also with regards to weight I took out the Shaker 1000 Subwoofer and the associated BTL (Bridge Tied Load i.e. differential drive) power amplifiers that weighed in at about 90lbs total. It freeded up a ton of trunk space and I don't miss the Boomy sound at all (my profession is high end audio / home theater) BUT I think the extra weight over one rear wheel might not have been a bad thing? I.e. keeping the rear wheels planted. Mark / MSB Mustang Link to comment Share on other sites More sharing options...
shelbypt Posted July 26, 2009 Report Share Posted July 26, 2009 Oh, and don't forget about the Led foot in the Shelby!! That weighs a ton... Link to comment Share on other sites More sharing options...
