andrewnagle1964 Posted July 19, 2009 Report Share Posted July 19, 2009 I bought the Shelby in February 2008 and have spent the last 18 months having it modded and I am finally ready to drive this baby......like I stole it ! AFCO Pro Series Dual Pass Intercooler Heat Exchanger Agent 47 Side Mirrors Agent 47 Brake Cooling Kit and Lower Grille Inserts Agent 47 Upper Honeycomb Grille with OEM Fog Lights Alsa Killer Chromed Power Steering Pump AmericanRacing 1 5/8" Long Tube Headers with H pipe FRRP Bolts ATE Super Blue DOT 4 Racing Brake Fluid AutoMeter Cobalt Gauges (Full Sweep Electric) Boost, Oil & Fuel Pressure Baer DecelaRotors Drilled and Slotted BMR Prothane Bullet Motor Mount BMR Driveshaft Loop Chip Beck Fiberglass Hood Scoop and Painted on Stripes (whole car) FRRP Push Button Start FRRP Ford GT 38lb/hr fuel injectors FRRP 0 degree Ford Racing spark plugs FRRP Shelby GT500 Duel fuel pump FRRP Rear Axle Girdle with Chrome Bolts FRPP Axle Back Mufflers KR500 FRPP 62mm Dual Bore Throttle Body FRPP 4.10 Gears Goodridge Stainless Steel Brake Lines H3R Halo Fire Extinguisher Chrome with Bracket Hawk HPS Brake Pads Hurst Short Throw Shifter Hurst Line Lock with Shifter Knob Button Hurst Hurst Equipped Retro Emblem Innovators West Harmonized Balancer – aluminum J&M Adjustable UCA and LCA J&M LCA Relocation Bracket Koni Yellow Adjustable Sport Shocks and Struts Leonard Racing SpyderShaft1 piece Aluminum drive shaft MM Products Adjustable Caster Camber Plates McGard Lug Nuts and Locking Nut Meziere Electric Water Pump Midwest Auto Radiator Cover with Side Extenders MoleSkin Window Felt Moroso Coolant Expansion Tank (Aluminum) Moroso Power Steering Fluid Tank (Aluminum) Moroso Supercharger Coolant Tank (Aluminum) Moroso Oil/Air Separator Tank (Aluminum) Moroso Modular Oil Pan (Aluminum) Moroso Fuse Box Cover (Aluminum) Moroso Brake Reservoir Cover (Aluminum) Odyssey Deep Cycle Battery Oil Mobil 1 5w-20 POR15 Rust treated and Painted Rear End Raptor Shifter Light (Blue) Speed of Sound Triple A-Pillar Gauge Cluster Shelby Billet Engine Caps Shelby Billet Under Hood Hardware Shelby Billet Hood Pins 2008 Shelby Billet Pedal Covers Shelby Berg Snake Faux Gas Cap Shelby Snake Logo Center Wheel Caps Shelby Satin Chrome Tail Light Trim Shelby Satin Chrome Quarter Light Trim SHR Quarter Window Louvers Painted Black SHR Billet Fuel Door Black Anodized Spec Stage 3+ Clutch Spec Steel Fly wheel StangMods Clear Rear Side Marker Lenses w/red LED bulbs StangMods Clear Turn Signal Lens w/stealth bulbs Steeda Battery Relocation Box Steeda Bumpsteer kit Steeda X5 Ball Joints Steeda Front Street End Link Kit ThumpRRR 76mm idler tension pulley UMI Double Adjustable ChroMoly Panhard Bar (Rod Ends) UPR Shorty Antenna Vogtland Lowering Springs Web Electric Sequential Tail Lights Whipple HO Intercooled Supercharger Take Care Andrew Link to comment Share on other sites More sharing options...
kahmann Posted July 19, 2009 Report Share Posted July 19, 2009 Great mod list Andrew. Do you have any pics of the water pump install? Or any pics of the the pump at all? Thanks man Link to comment Share on other sites More sharing options...
Matts Posted July 19, 2009 Report Share Posted July 19, 2009 Did you take a breath? Very impressive mod list! Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted July 19, 2009 Author Report Share Posted July 19, 2009 Great mod list Andrew. Do you have any pics of the water pump install? Or any pics of the the pump at all? Thanks man Ken, Unfortunately, unlike you I don't do my own mods, so I go not pics of the install but will see what I can snap tomorrow of the finish job Take care and thanks Andrew Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted July 19, 2009 Author Report Share Posted July 19, 2009 Did you take a breath? Very impressive mod list! I barely did it seemed like it was constantly in the shop, I only have 2,600 miles on it. Thanks and take care Andrew Link to comment Share on other sites More sharing options...
kahmann Posted July 19, 2009 Report Share Posted July 19, 2009 Ken, Unfortunately, unlike you I don't do my own mods, so I go not pics of the install but will see what I can snap tomorrow of the finish job Take care and thanks Andrew Cool man, no sweat. Anything would be great. Link to comment Share on other sites More sharing options...
