chuckstang Posted July 18, 2009 Report Share Posted July 18, 2009 Of course searching never finds me anything on here. But I could have sworn I have seen a write up on how to remove and reinstall the stock plastic front splitter? It appears that it goes quite aways under the front of the car and perhaps needs to be jacked up to remove? All I see are the screws on the side near the tires. Right now just looking to remove to clean all the gunk and sand that has built up between it the front bumper. Also I know I will some day need to replace one, as I rubbed it for the first time the other day, call me anal, but I don't even like seeing chew marks on the underside! :D thanks Link to comment Share on other sites More sharing options...
txcobra Posted July 18, 2009 Report Share Posted July 18, 2009 Subscribing because I need to do the same! Link to comment Share on other sites More sharing options...
tekheavy Posted July 18, 2009 Report Share Posted July 18, 2009 This may help! S8B1J003.pdf S8B1J003.pdf Link to comment Share on other sites More sharing options...
mrfarmdog Posted July 18, 2009 Report Share Posted July 18, 2009 There are 4 or 5 phillips head screws in each wheel well, several 10MM bolts under the front edge all the way around. There is a splash guard that connects to the chin spoiler and the K member with some small hex bolts. If all you want to do is drop it down and clean it you do not have to loosen these. If you want to completely take it off then you will need to remove the two bolts that connect to the chin spoiler as well. I phillips head screwdriver and a 1/4 wratchet set are all the tools that are needed. Link to comment Share on other sites More sharing options...
Michael Morris Posted July 18, 2009 Report Share Posted July 18, 2009 You shouldnt have to jack up the car to do it! I took the CF off the SS and put it back on and never lifted the car MM Link to comment Share on other sites More sharing options...
XLR8 Posted July 19, 2009 Report Share Posted July 19, 2009 This may help! S8B1J003.pdf I don't know about the PDF file that you posted, but your Avatar sure does help! Link to comment Share on other sites More sharing options...
