AlloyDropTop Posted July 6, 2009 Report Share Posted July 6, 2009 I just reviewed the 2010 Shelby Owners supplement and saw one thing I don't recall in the 2008 manual. It recommends spark plug maintenance at 45K miles. I would assume that means we should probably do the same with our '08's as I can't imagine anything is different? Link to comment Share on other sites More sharing options...
Grabber Posted July 6, 2009 Report Share Posted July 6, 2009 I have the Stage II set up and my NGK plugs need to be changed after 5-10K miles of use depending on your driving habits. Link to comment Share on other sites More sharing options...
blkGT500nCA Posted July 6, 2009 Report Share Posted July 6, 2009 I'm going to do it every other oil change now. I just pulled my NGK's after about a year (8k miles) and noticed that the gaps had increased form .032 to about .036. Tightly gapped plugs are cheap insurance to elude detonation. Link to comment Share on other sites More sharing options...
AlloyDropTop Posted July 6, 2009 Author Report Share Posted July 6, 2009 I'm going to do it every other oil change now. I just pulled my NGK's after about a year (8k miles) and noticed that the gaps had increased form .032 to about .036. Tightly gapped plugs are cheap insurance to elude detonation. How easy is the plug change on these things? Link to comment Share on other sites More sharing options...
SicShelby Posted July 6, 2009 Report Share Posted July 6, 2009 Hm should be fairly simple considering DOHC yah? Link to comment Share on other sites More sharing options...
jcthorne Posted July 6, 2009 Report Share Posted July 6, 2009 Guess I better get a set and change mine....My NGK TR-6s have about 16,000 miles on them......and a lot more boost than a stage II. Link to comment Share on other sites More sharing options...
blkGT500nCA Posted July 7, 2009 Report Share Posted July 7, 2009 How easy is the plug change on these things? The ones against the firewall are a little tough to get to but it's really not that bad at all. Just remove the Cold Air Intake. And you need a 10mm deep well and a #30 torx bit, and then the spark plug socket. A couple 3/8ths inch extensions (a 6 and a 3") and I also used a swivel. Torque the plugs down to apx 14 ft/lbs. Guess I better get a set and change mine....My NGK TR-6s have about 16,000 miles on them......and a lot more boost than a stage II. Yep, I'd get it done sooner than later. I bet their gapped up to apx .040 by now. Link to comment Share on other sites More sharing options...
jcthorne Posted July 7, 2009 Report Share Posted July 7, 2009 Yep, I'd get it done sooner than later. I bet their gapped up to apx .040 by now. Yep, picked them up at Advance last night and will put them in this weekend. They only take about an hour to change....including a beer. Almost not worth cooling down the garage for. Link to comment Share on other sites More sharing options...
