RACERX009 Posted June 22, 2009 Report Share Posted June 22, 2009 The back fire is from bad gas my buddy also filled up at the same time as me and his car was bogging Link to comment Share on other sites More sharing options...
RACERX009 Posted June 22, 2009 Author Report Share Posted June 22, 2009 Thats with my cell phone will try with video camera Link to comment Share on other sites More sharing options...
stump_breaker Posted June 22, 2009 Report Share Posted June 22, 2009 The back fire is from bad gas my buddy also filled up at the same time as me and his car was bogging Bad gas? You sure it just wasn't cold? Our always does that when we first crank it. Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted June 22, 2009 Report Share Posted June 22, 2009 Awesosme, screw expensive mufflers these sound as good now as they did 20 years ago....cool mod sounds great Racer!! Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted June 22, 2009 Report Share Posted June 22, 2009 I forgot these will sound killer with you new cams. :happy feet: The car will backfire if you got rid of the crossover pipe, unless these new engines are different than the 60's v-8's. Cool. Link to comment Share on other sites More sharing options...
nojoke4true Posted June 22, 2009 Report Share Posted June 22, 2009 Hmm, will wait for video camera version before I past judgement Link to comment Share on other sites More sharing options...
Frank S Posted June 23, 2009 Report Share Posted June 23, 2009 Are Cherry Bombs the same as back in history? Fiberglass-packed bullet-shaped items? Yes they sound good. Even in the mid-1970s exhaust gas temperatures were high enough that they burned out the 'glass and in my case they had to be replaced every 45 days or so, when they became too loud (I had a 23-degree departure-angle megaphone to complicate matters). Unless the technology is significantly advanced from then, you might as well put on straight pipes or simple resonators, because (in my experience) that's what you'll have in a very short time. Backfire is the result of unburned fuel igniting in the exhaust system, if I'm not mistaken. Lots of reasons for unburned fuel there. A common one (history again) other than cold starting conditions (pooling in intake passages) and butterfly valves that don't close completely, is valves that don't close completely or on time. Unburned fuel can contaminate catalytic material in the system; backfire can break up the catalytic configuration, possibly leading to plugging of the flow and excessive emissions. "In this universe there are things that just don't yield to thinking —plain or fancy—Dude". —J. Spicoli, PolyPartyPerson Link to comment Share on other sites More sharing options...
RACERX009 Posted June 23, 2009 Author Report Share Posted June 23, 2009 Are Cherry Bombs the same as back in history? Fiberglass-packed bullet-shaped items? Yes they sound good. Even in the mid-1970s exhaust gas temperatures were high enough that they burned out the 'glass and in my case they had to be replaced every 45 days or so, when they became too loud (I had a 23-degree departure-angle megaphone to complicate matters). Unless the technology is significantly advanced from then, you might as well put on straight pipes or simple resonators, because (in my experience) that's what you'll have in a very short time. Backfire is the result of unburned fuel igniting in the exhaust system, if I'm not mistaken. Lots of reasons for unburned fuel there. A common one (history again) other than cold starting conditions (pooling in intake passages) and butterfly valves that don't close completely, is valves that don't close completely or on time. Unburned fuel can contaminate catalytic material in the system; backfire can break up the catalytic configuration, possibly leading to plugging of the flow and excessive emissions. "In this universe there are things that just don't yield to thinking —plain or fancy—Dude". —J. Spicoli, PolyPartyPerson They are not the glass packs from the 70's but they do still sell those mufflers!!! My mufflers are the Vortex made by cherry bomb and a life time warranty. That video was a cold start but since I refulled my tank and put gas dry in it hasn't happened again. Link to comment Share on other sites More sharing options...
Reino Posted June 23, 2009 Report Share Posted June 23, 2009 I like that sound, sound good. How much these set you back if you dont mind? Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted June 23, 2009 Report Share Posted June 23, 2009 Are Cherry Bombs the same as back in history? Fiberglass-packed bullet-shaped items? Yes they sound good. Even in the mid-1970s exhaust gas temperatures were high enough that they burned out the 'glass and in my case they had to be replaced every 45 days or so, when they became too loud (I had a 23-degree departure-angle megaphone to complicate matters). Unless the technology is significantly advanced from then, you might as well put on straight pipes or simple resonators, because (in my experience) that's what you'll have in a very short time. Backfire is the result of unburned fuel igniting in the exhaust system, if I'm not mistaken. Lots of reasons for unburned fuel there. A common one (history again) other than cold starting conditions (pooling in intake passages) and butterfly valves that don't close completely, is valves that don't close completely or on time. Unburned fuel can contaminate catalytic material in the system; backfire can break up the catalytic configuration, possibly leading to plugging of the flow and excessive emissions. "In this universe there are things that just don't yield to thinking —plain or fancy—Dude". —J. Spicoli, PolyPartyPerson Yeah but for some reason old cherry bombs with no crossover left a backfiring burble on the older V-8's. Link to comment Share on other sites More sharing options...
RACERX009 Posted June 25, 2009 Author Report Share Posted June 25, 2009 I like that sound, sound good. How much these set you back if you dont mind? It cost me 400.00 because, I wanted the original tips on the new mufflers and had to bend new pipes. The cost was worth it !! Totally a different sound from the rest, My car is still at the dealer and it will be ready tomorrow and will post the video of the new cams. Anthony Link to comment Share on other sites More sharing options...
