Grabber Posted June 17, 2009 Report Share Posted June 17, 2009 Here's Ford's Jacking instructions for the 2010. 2010_Jacking_Instructions.pdf 2010_Jacking_Instructions.pdf Link to comment Share on other sites More sharing options...
Cobra010 Posted June 17, 2009 Report Share Posted June 17, 2009 Here's Ford's Jacking instructions for the 2010.2010_Jacking_Instructions.pdf That's cool thanks Grabber, I will make a copy for my show book. Cobra09 Link to comment Share on other sites More sharing options...
SmellSoGood Posted June 17, 2009 Report Share Posted June 17, 2009 Thanks Grabs, but why would I need this if there's no spare and hence, no jack? j/k Link to comment Share on other sites More sharing options...
chuckstang Posted June 18, 2009 Report Share Posted June 18, 2009 Here's Ford's Jacking instructions for the 2010.2010_Jacking_Instructions.pdf Grabber, cant remember if I asked you this. But any idea if it is ok with these cars to jack up just one corner at a time? This would be easier then jacking the entire front or rear of the car. I am thinking just if you want to remove one wheel at a time. thanks! Link to comment Share on other sites More sharing options...
Grabber Posted June 18, 2009 Author Report Share Posted June 18, 2009 Grabber, cant remember if I asked you this. But any idea if it is ok with these cars to jack up just one corner at a time? This would be easier then jacking the entire front or rear of the car. I am thinking just if you want to remove one wheel at a time. thanks! IMO....As long as you only jack it up enough to get the tire off, say 1 inch off the ground.....It will be fine. Link to comment Share on other sites More sharing options...
Torched10 Posted June 18, 2009 Report Share Posted June 18, 2009 Here's Ford's Jacking instructions for the 2010.2010_Jacking_Instructions.pdf Grabber thanks ill use it to paint my rear end,and the one on my new car too Link to comment Share on other sites More sharing options...
chuckstang Posted June 20, 2009 Report Share Posted June 20, 2009 IMO....As long as you only jack it up enough to get the tire off, say 1 inch off the ground.....It will be fine. How can you tell how high is needed to lift the car to remove the wheel/tire? I assume you are saying keep jacking until tired is 1" off the ground ? thanks Link to comment Share on other sites More sharing options...
Grabber Posted June 21, 2009 Author Report Share Posted June 21, 2009 How can you tell how high is needed to lift the car to remove the wheel/tire? I assume you are saying keep jacking until tired is 1" off the ground ? thanks Yes. Link to comment Share on other sites More sharing options...
