nexxone_05 Posted June 5, 2009 Report Share Posted June 5, 2009 Any tips on how to do a good burn out Link to comment Share on other sites More sharing options...
08BlueCoupe Posted June 5, 2009 Report Share Posted June 5, 2009 Any tips on how to do a good burn out Rev 'er up, dump the clutch, give it alot of gas, give it even more brake, and there you go. Link to comment Share on other sites More sharing options...
NordicShelby Posted June 5, 2009 Report Share Posted June 5, 2009 Turn the traction control off and floor it. Link to comment Share on other sites More sharing options...
stump_breaker Posted June 6, 2009 Report Share Posted June 6, 2009 Any tips on how to do a good burn out You're having trouble doing a burn out in a 500 HP car? Are you sure it's cranked and running? Rev it up and pop the clutch.... Link to comment Share on other sites More sharing options...
ingram4868 Posted June 6, 2009 Report Share Posted June 6, 2009 Any tips on how to do a good burn out What make and model car are you driving? Seriously. It is not in your signature line. Link to comment Share on other sites More sharing options...
AlloyDropTop Posted June 6, 2009 Report Share Posted June 6, 2009 Any tips on how to do a good burn out Depends on what you drive. If it is a wrong wheel drive import, set the parking brake, rev to 8K, dump the clutch. If it is a AWD sport untility, fugetaboutit..... If it is GT500, just give it gas, nothing else really matters. If it won't break traction in first and second gear without trying, return to the dealer as something must be wrong with it. Link to comment Share on other sites More sharing options...
portside Posted June 7, 2009 Report Share Posted June 7, 2009 Any tips on how to do a good burn out A line lock really helps lessen wear and tear on your clutch and brakes. Plus, it allows large smoky burnouts while staying in one place (like drag racers), as opposed to burnouts that go streaking across the parking lot or down the street. You can always release the lock if you want to get moving. The old foot on the gas and one on the brakes technique is very hard on the moving parts, and is a contributing cause of a lot of damaged clutches, transmissions, rear brakes, etc. Depending on your setup, 2nd gear may be a better gear than 1st. Link to comment Share on other sites More sharing options...
07-2937 Posted June 7, 2009 Report Share Posted June 7, 2009 if its a gt500 turn off traction control then hammer it Link to comment Share on other sites More sharing options...
