uno Posted June 3, 2009 Report Share Posted June 3, 2009 Manufacturer: Shelby Performance Parts Part No: 5S3Z-6316892-K and i don't know which car they were meant to go on. They just look a LITTLE nicer then the stock pins, but im wondering if i small raised part in the middle of the base effects anything adversly. For the price amount it would enhance the appearance, i would like to do little to no work installing them vs the stock hoodpins that constantly break and lose. edit: they look like they sit a little higher off away from the paint on my hood. I hate when someone else is taking out my hood pins, so frightning they are gonna scratch the hood paint. Link to comment Share on other sites More sharing options...
clark17357 Posted June 3, 2009 Report Share Posted June 3, 2009 The ones you cite are like those on the 2008 cars (except the GO ones, for some reason). They are as good as you think they are. What I have heard, however, is that it is not just a straight swap but, instead, something that requires some additional drilling and alignment. I suspect someone has replaced them and could weigh in here. Good luck. Jim Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted June 3, 2009 Report Share Posted June 3, 2009 Check out the information found here: http://www.teamshelby.com/forums/index.php?showtopic=34372 They come on the 08 cars and fit, sometimes with some minor modifications information for which you will find in that thread or in previous threads. Do a search for "hood pins". Link to comment Share on other sites More sharing options...
tekheavy Posted June 3, 2009 Report Share Posted June 3, 2009 I have them on my car. Definitely not a direct replacement. I needed to widen the holes in the hood and a few other modifications. And then open and close the hood a hundred or so times to get it aligned just right. Link to comment Share on other sites More sharing options...
SGT-C0056 Posted June 3, 2009 Report Share Posted June 3, 2009 I have them on my car. Definitely not a direct replacement. I needed to widenn the holes in the hood and a few other modifications. And then open and close the hood a hundred or so times to get it aligned just right. I agree!! took me sometime to get them right, but they are better and will prevent the hood paint from scratching. The 08 GO SGT did not come with these, but I replaced them and are nice. Go for it. Link to comment Share on other sites More sharing options...
blueshawk Posted June 4, 2009 Report Share Posted June 4, 2009 I agree!! took me sometime to get them right, but they are better and will prevent the hood paint from scratching. The 08 GO SGT did not come with these, but I replaced them and are nice. Go for it. +1 Much better hood pins and they look better. Did take alot of adjusting and using a Dremel to elongate the holes in the hood. But you'll be glad you did it. Much better hood pins! Link to comment Share on other sites More sharing options...
SGT2666 Posted June 4, 2009 Report Share Posted June 4, 2009 They are better quality all around, but as has been said not as easy to install as you might think. I'm seeing a little rust at the swivels under the plastic, which is disappointing Link to comment Share on other sites More sharing options...
stormeaston Posted June 4, 2009 Report Share Posted June 4, 2009 Ohhhhhhhhhhhh..................................I must have been the lucky one here, mine went on with zero problems, as easy as changing your valve stem caps. Link to comment Share on other sites More sharing options...
Reino Posted June 4, 2009 Report Share Posted June 4, 2009 Ohhhhhhhhhhhh..................................I must have been the lucky one here, mine went on with zero problems, as easy as changing your valve stem caps. +1. No problems here with the exception of having to open and close hood to get the pins to line up through the hold on the top plate. I did use the old pins though. Didnt see any reason to change them as I was replacing a good item with another good item and it was the same thing too. Link to comment Share on other sites More sharing options...
SGT2666 Posted June 4, 2009 Report Share Posted June 4, 2009 +1.No problems here with the exception of having to open and close hood to get the pins to line up through the hold on the top plate. I did use the old pins though. Didnt see any reason to change them as I was replacing a good item with another good item and it was the same thing too. The new ones are billet the old ones rust... Link to comment Share on other sites More sharing options...
SGT-C0056 Posted June 4, 2009 Report Share Posted June 4, 2009 The new ones are billet the old ones rust... The only thing i had to drill was the new screw holes, about 1/8" up, but the main hole went directly in the same area. whole job less than an hour for me Link to comment Share on other sites More sharing options...
Reino Posted June 5, 2009 Report Share Posted June 5, 2009 The new ones are billet the old ones rust... Then when they rust Ill change them. So far so good. Link to comment Share on other sites More sharing options...
69dejavue Posted June 5, 2009 Report Share Posted June 5, 2009 What is the rust warranty on our SGTs? Link to comment Share on other sites More sharing options...
stormeaston Posted June 5, 2009 Report Share Posted June 5, 2009 What is the rust warranty on our SGTs? Steel wool! Link to comment Share on other sites More sharing options...
