agvs24 Posted May 22, 2009 Report Share Posted May 22, 2009 I noticed on my CSX shifter that it says "PUSH" under the "R" for reverse... This car has the A-555 manual which you PULL up on the ring under the knob to engage reverse. Is this the wrong knob for the car?? Maybe from an older L-body shifter where you had to push down for reverse? Or did all the knobs say "PUSH"?? Link to comment Share on other sites More sharing options...
shelbymotorsports Posted May 22, 2009 Report Share Posted May 22, 2009 I noticed on my CSX shifter that it says "PUSH" under the "R" for reverse... This car has the A-555 manual which you PULL up on the ring under the knob to engage reverse. Is this the wrong knob for the car?? Maybe from an older L-body shifter where you had to push down for reverse? Or did all the knobs say "PUSH"?? You have the A555 transmission with the lift up ring for reverse in your CSX. Sounds like someone replaced the correct shift pattern knob insert with one from another car. Chrysler no longer carries the correct A555 shift knob insert so you'll need to find a used one or someone that has a NOS one stashed away. Steve Link to comment Share on other sites More sharing options...
dgrun Posted May 23, 2009 Report Share Posted May 23, 2009 I think the knob on your car is from an 87 or 88 CSX. I recently bought an NOS CSX shift knob on ebay for my 89 and it is like yours. It says push instead of pull. Guess I'll put it back on ebay and identify the correct year for the knob so no one else makes the same mistake. Dennis Link to comment Share on other sites More sharing options...
agvs24 Posted May 24, 2009 Author Report Share Posted May 24, 2009 I think the knob on your car is from an 87 or 88 CSX. I recently bought an NOS CSX shift knob on ebayfor my 89 and it is like yours. It says push instead of pull. Guess I'll put it back on ebay and identify the correct year for the knob so no one else makes the same mistake. Dennis I saw that knob on ebay and didnt notice the "PUSH" either. I located one close to me in pretty good shape luckily.. may need some "white out" to fix the lettering LOL. Link to comment Share on other sites More sharing options...
