bung Posted May 21, 2009 Report Share Posted May 21, 2009 Ok, here's a weird one... It's rained here in Florida for 3 day straight. Our son opened the trunk today and the beach chair, towel, and atlas my wife keeps in there were soaking wet but the carpet is completely dry. There is no water under the carpet, I couldn't feel any drips around the lip. I'm baffled right now. Has anyone else has a similar experience. Link to comment Share on other sites More sharing options...
09shlb Posted May 22, 2009 Report Share Posted May 22, 2009 Ok, here's a weird one... It's rained here in Florida for 3 day straight. Our son opened the trunk today and the beach chair, towel, and atlas my wife keeps in there were soaking wet but the carpet is completely dry. There is no water under the carpet, I couldn't feel any drips around the lip. I'm baffled right now. Has anyone else has a similar experience. It's raining in your conditioned garage Check the spoiler bolts are tight. I had a GT that let water in around the spoiler connections and got stuff wet in the middle of the trunk, when being washed Link to comment Share on other sites More sharing options...
David Hawkins Posted May 22, 2009 Report Share Posted May 22, 2009 PLUS........if you have Satalite Radio with the Antana mounted on the Trunk......Check that to. Link to comment Share on other sites More sharing options...
ingram4868 Posted May 22, 2009 Report Share Posted May 22, 2009 The taillight assembly also has bolts that go into the trunk. You can access those nuts behind the grey fabric material. Or my preference, take it to the dealer to figure out. Link to comment Share on other sites More sharing options...
motorjock205 Posted May 22, 2009 Report Share Posted May 22, 2009 PLUS........if you have Satalite Radio with the Antana mounted on the Trunk......Check that to. +1000 This would be the first place to look if everything was in the middle of the trunk...Mine was leaking a little when I first bought the car...antenna was most definately loose... Link to comment Share on other sites More sharing options...
bung Posted May 22, 2009 Author Report Share Posted May 22, 2009 Thanks folks, don't have a spoiler, but I'll check the Sirius antenna tomorrow. Link to comment Share on other sites More sharing options...
ilmor Posted May 22, 2009 Report Share Posted May 22, 2009 Sounds like the Sirius antenna leaked directly onto your stuff and the towel absorbed it! Speaking of which, have you guys seen this? "Coming Soon". Raceskinz is one of Team Shelby's new advertisers. http://www.raceskinz.us.com/product_info.p...;products_id=79 Link to comment Share on other sites More sharing options...
bung Posted May 22, 2009 Author Report Share Posted May 22, 2009 Yep, it's the Sirius antenna. It's totally loose and doesn't look like it's ever been sealed. I don't know why did didn't have leaks before. I wonder if it's supposed to have a gasket or some kind of seal under it. I think I might run a bead of silicon around it. Thanks everyone. Link to comment Share on other sites More sharing options...
ingram4868 Posted May 22, 2009 Report Share Posted May 22, 2009 The existing gasket should work fine once tightened up again. A simple test would be to put a brown paper bag in the trunk and after running the hose on the antenna check to see if the bag is wet. Ask around if the silicone is safe on the clearcoat. You don't want to start some type of reaction that would bleed to a visible area. Link to comment Share on other sites More sharing options...
bung Posted May 24, 2009 Author Report Share Posted May 24, 2009 The existing gasket should work fine once tightened up again. A simple test would be to put a brown paper bag in the trunk and after running the hose on the antenna check to see if the bag is wet. Ask around if the silicone is safe on the clearcoat. You don't want to start some type of reaction that would bleed to a visible area. Thanks for the heads up. That's a good point. Link to comment Share on other sites More sharing options...
