COBRA SCOTTY Posted May 15, 2009 Report Share Posted May 15, 2009 I HAVE BEEN LOOKING AT CAR HAULERS FOR MY 2 SHELBY'S AND AFTER DOING SOME RESEARCH. I REALIZED THAT IT IS VERY IMPORTANT TO KNOW THE COMBINE WEIGHTS OF THE CAR AND TRAILER IN REAGRDS TO YOUR VEHICLES TOWING CAPACITY ; ESPECIALY WHEN YOU ARE AT THE UPPER LIMITS OF YOUR TOW VEHICLES CAPACITY. THAT BEING SAID, I HAD MY SHELBY GT/SC WEIGHED AND MUCH TO MY AMAZEMENT THE CAR ONLY WEIGHED IN AT 3,420 LBS. A FAR CRY FROM THE GROSS VEHICLE WEIGHT OF 4480 LBS AS POSTED ON THE DRIVERS SIDE DOOR JAM. THAT WEIGHT INCLUDES A SHAKER 1,000 SYSTEM , THE WHIPPLE 550 , GT500 WHEELS , BRAKES AND A REAR WING. NOT BAD AT ALL. :happy feet: HOPE THIS HELPS OTHERS THAT MIGHT BE DOING THE SAME RESEARCH. SCOTTY Link to comment Share on other sites More sharing options...
tekheavy Posted May 15, 2009 Report Share Posted May 15, 2009 I HAVE BEEN LOOKING AT CAR HAULERS FOR MY 2 SHELBY'S AND AFTER DOING SOME RESEARCH. I REALIZED THAT IT IS VERY IMPORTANT TO KNOW THE COMBINE WEIGHTS OF THE CAR AND TRAILER IN REAGRDS TO YOUR VEHICLES TOWING CAPACITY ; ESPECIALY WHEN YOU ARE AT THE UPPER LIMITS OF YOUR TOW VEHICLES CAPACITY. THAT BEING SAID, I HAD MY SHELBY GT/SC WEIGHED AND MUCH TO MY AMAZEMENT THE CAR ONLY WEIGHED IN AT 3,420 LBS. A FAR CRY FROM THE GROSS VEHICLE WEIGHT OF 4480 LBS AS POSTED ON THE DRIVERS SIDE DOOR JAM. THAT WEIGHT INCLUDES A SHAKER 1,000 SYSTEM , THE WHIPPLE 550 , GT500 WHEELS , BRAKES AND A REAR WING. NOT BAD AT ALL. :happy feet: HOPE THIS HELPS OTHERS THAT MIGHT BE DOING THE SAME RESEARCH. SCOTTY That 4480 lbs on the door jam is the GVWR (Gross Vehicle Weight Rating). That's the maximum allowable weight of the vehicle INCLUDING all passengers, fuel and cargo. Link to comment Share on other sites More sharing options...
ilmor Posted May 15, 2009 Report Share Posted May 15, 2009 The official CURB weight of a Mustang GT as I understand it is 3495 lbs. This is with all fluids, including fuel. Gas weighs 6.26 lbs per gallon. So the question is, how much fuel was in your tank when you weighed it? Link to comment Share on other sites More sharing options...
Hardluck33 Posted May 15, 2009 Report Share Posted May 15, 2009 The official CURB weight of a Mustang GT as I understand it is 3495 lbs. This is with all fluids, including fuel. Gas weighs 6.26 lbs per gallon. So the question is, how much fuel was in your tank when you weighed it? I bet 11.98 gallons short of full--- but still good info. Link to comment Share on other sites More sharing options...
STLShelby Posted May 16, 2009 Report Share Posted May 16, 2009 I weighed mine right before i retired on our certified truck scale, which is kept calibrated on a regular basis. No huffer, 1000 Shaker system, active anti theft etc. The only thing i ordered was the premium package with IUP. It weighed 3500 even with 3/4 of a tank of gas. Link to comment Share on other sites More sharing options...
scottmadwi Posted May 31, 2009 Report Share Posted May 31, 2009 My Certificate of Origin for the GT-C list 3398 as the shipping weight from Ford. It sounds like the Shelby transformation did not change that by much. Link to comment Share on other sites More sharing options...
Reino Posted May 31, 2009 Report Share Posted May 31, 2009 My Certificate of Origin for the GT-C list 3398 as the shipping weight from Ford. It sounds like the Shelby transformation did not change that by much. How you get your hands on the certificate of origin? Link to comment Share on other sites More sharing options...
SHANE-O-MAN Posted May 31, 2009 Report Share Posted May 31, 2009 Really; how do you get a Certificate of Origin? Link to comment Share on other sites More sharing options...
StrayShadow Posted June 1, 2009 Report Share Posted June 1, 2009 I also got the the certificate of origin or MSO, when I purchased my SGT. I wrote a check for my car and took the paperwork and got the tag/title work done myself. Thats how I got the certificate/MSO. I also made color copies of it before I sent it to the Hwy Dept. I added it to my book of SGT documents. Kevin 07SGT2591 Link to comment Share on other sites More sharing options...
scottmadwi Posted June 1, 2009 Report Share Posted June 1, 2009 I had the car shipped to WI, so they had to give me the certificate to register the car. Before we registered the car, we scanned the certificate. I thought it would be a good document to have. Link to comment Share on other sites More sharing options...
gth0007 Posted June 1, 2009 Report Share Posted June 1, 2009 I HAVE BEEN LOOKING AT CAR HAULERS FOR MY 2 SHELBY'S AND AFTER DOING SOME RESEARCH. I REALIZED THAT IT IS VERY IMPORTANT TO KNOW THE COMBINE WEIGHTS OF THE CAR AND TRAILER IN REAGRDS TO YOUR VEHICLES TOWING CAPACITY ; ESPECIALY WHEN YOU ARE AT THE UPPER LIMITS OF YOUR TOW VEHICLES CAPACITY. THAT BEING SAID, I HAD MY SHELBY GT/SC WEIGHED AND MUCH TO MY AMAZEMENT THE CAR ONLY WEIGHED IN AT 3,420 LBS. A FAR CRY FROM THE GROSS VEHICLE WEIGHT OF 4480 LBS AS POSTED ON THE DRIVERS SIDE DOOR JAM. THAT WEIGHT INCLUDES A SHAKER 1,000 SYSTEM , THE WHIPPLE 550 , GT500 WHEELS , BRAKES AND A REAR WING. NOT BAD AT ALL. :happy feet: HOPE THIS HELPS OTHERS THAT MIGHT BE DOING THE SAME RESEARCH. SCOTTY The Gross Vehicle Weight rating (GVWR)on the door jamb sticker is NOT the weight of the car. My 07 SGT has a Gross Vehicle Weight of 4,450 pounds. This weight refers to the weight of the car PLUS the maximum weight of passengers and cargo you can safely haul. Page 154 of your owner's manual explains this in detail. A SGT should weigh in at around 3,400-3,500 pounds or so. Hope this helps. Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted June 2, 2009 Author Report Share Posted June 2, 2009 The Gross Vehicle Weight rating (GVWR)on the door jamb sticker is NOT the weight of the car. My 07 SGT has a Gross Vehicle Weight of 4,450 pounds. This weight refers to the weight of the car PLUS the maximum weight of passengers and cargo you can safely haul. Page 154 of your owner's manual explains this in detail. A SGT should weigh in at around 3,400-3,500 pounds or so. Hope this helps. THANKS GTH0007, I KNEW THAT ABOUT THE GVWR . HOWEVER THE POINT I GUESS I WAS GETTING AT IS THAT FORD IS SAYING THAT BASED ON 4 PEOPLE BEING IN THE CAR THEY WOULD AVERAGE 250 LBS. FOR WE ALL KNOW THAT THERE IS REALLY NO TRUNK SPACE OR ROOM FOR WEIGHT IN THERE. HOW MANY TIMES ARE YOU GOING TO HAVE 4 FRIENDS THAT AVG. 250 LBS. IT WAS NEVER A REALISTIC GVWR. SCOTTY Link to comment Share on other sites More sharing options...
ilmor Posted June 2, 2009 Report Share Posted June 2, 2009 THANKS GTH0007, I KNEW THAT ABOUT THE GVWR . HOWEVER THE POINT I GUESS I WAS GETTING AT IS THAT FORD IS SAYING THAT BASED ON 4 PEOPLE BEING IN THE CAR THEY WOULD AVERAGE 250 LBS. FOR WE ALL KNOW THAT THERE IS REALLY NO TRUNK SPACE OR ROOM FOR WEIGHT IN THERE. HOW MANY TIMES ARE YOU GOING TO HAVE 4 FRIENDS THAT AVG. 250 LBS. IT WAS NEVER A REALISTIC GVWR. SCOTTY Notwithstanding how many 250 lb. friends you might have, even if you did can you imagine getting 4 250 lb. guys in a Mustang??? Link to comment Share on other sites More sharing options...
judgeman6970 Posted June 14, 2009 Report Share Posted June 14, 2009 with all the huge, overweight, so-called "ponycars" out there, I like the fact that the very awesome "Shelby GT" comes in under 3,500lbs!!! :D Link to comment Share on other sites More sharing options...
