dupuyf Posted April 11, 2009 Report Share Posted April 11, 2009 does anybody have the right oil filter wrench for the 2008 musctang shelby gt 500 fd Link to comment Share on other sites More sharing options...
SicShelby Posted April 11, 2009 Report Share Posted April 11, 2009 Honestly I got a cheap one with a strap from AutoZone... did the job! Link to comment Share on other sites More sharing options...
Slabo Posted April 11, 2009 Report Share Posted April 11, 2009 Honestly I got a cheap one with a strap from AutoZone... did the job! +1 just measure the filter and get the right size. I did have to use a channel lock grip type the first time to get the factory filter off. Man do they put that one on tight. Link to comment Share on other sites More sharing options...
MikeCMM Posted April 11, 2009 Report Share Posted April 11, 2009 I haven't changed mine yet but you should be able to use the same kind of wrench that is used on the FL1-A filter if you already have one. I believe the 820-S is the same diameter. I use the same wrench for all my other vehicles. Link to comment Share on other sites More sharing options...
6-Speed Posted April 11, 2009 Report Share Posted April 11, 2009 If you're doing your first oil change, be advised that the Romeo folks crank down the oil filter really tight. I had to use the plier type filter wrench to get the grip needed to remove it. The filter case was crushed in a few spot after I finally got it loosened. You can get one of these at Harbor Freight Tools for less than $5 on sale. Link to comment Share on other sites More sharing options...
sbornitz Posted April 12, 2009 Report Share Posted April 12, 2009 The strap wrenches work also. Link to comment Share on other sites More sharing options...
SicShelby Posted April 12, 2009 Report Share Posted April 12, 2009 Man I thought it was me - they do put that thing on tight!! I didn't have time yesterday but what you can do is head into AutoZone or something, take one out of the box so you have it when you are looking for the right wrench. Sorry, I didn't do this, as I said was able to get it off with the strap, although it was a little more cumbersome. If you can get those pliers they would be a better bet, imo. Link to comment Share on other sites More sharing options...
FiaCobra Posted April 13, 2009 Report Share Posted April 13, 2009 SicShelby, can you shorten your sig pic? I can't read any text without having to scroll across the screen due to your picture being so long. Link to comment Share on other sites More sharing options...
SicShelby Posted April 13, 2009 Report Share Posted April 13, 2009 Sure. I have a big computer screen, thanks for letting me know! Link to comment Share on other sites More sharing options...
Afterburner Posted April 14, 2009 Report Share Posted April 14, 2009 I tried the strap type wrench which I had laying around the garage and it just broke. That factory installed filter is ridculously tight. I don't think they put any oil on the gasket. Anyway, a trip to Autozone and the pliers type wrench got it off. Link to comment Share on other sites More sharing options...
tekheavy Posted April 14, 2009 Report Share Posted April 14, 2009 If you're doing your first oil change, be advised that the Romeo folks crank down the oil filter really tight. I had to use the plier type filter wrench to get the grip needed to remove it. The filter case was crushed in a few spot after I finally got it loosened. You can get one of these at Harbor Freight Tools for less than $5 on sale. Thats exactly what I use. Works great. Also works to take the top off a pickle jar. :happy feet: Link to comment Share on other sites More sharing options...
SicShelby Posted April 15, 2009 Report Share Posted April 15, 2009 Huh. I used a paperclip and some bubble gum. I guess there is ALWAYS an easier way to do things... Link to comment Share on other sites More sharing options...
