stevetruncale Posted April 5, 2009 Report Share Posted April 5, 2009 My electric fan stopped working,.... on a 87 GLHS... any ideas on a replacement? Are they available... Can they be rebuilt? Thanks, Steve Link to comment Share on other sites More sharing options...
shelbymotorsports Posted April 7, 2009 Report Share Posted April 7, 2009 My electric fan stopped working,.... on a 87 GLHS... any ideas on a replacement? Are they available...Can they be rebuilt? Thanks, Steve Steve My memory is a little fuzzy on the GLHS fans but IIRC the 1986 GLHS used a Hayden fan motor and the 1987 GLHS used a Chrysler sourced fan motor. I would take your bad motor to the j/yard and start comparing it to other Chrysler FWD fan motors. Perhaps you can find one that will bolt right in. The 1987 GLHS is probably the most parted out Whittier car so you can always keep your eyes open for a used one for sale. Steve PS- Are you sure the fan motor is bad and not the relay? I've replaced many relays but never a fan motor on the S cars. Link to comment Share on other sites More sharing options...
stevetruncale Posted April 8, 2009 Author Report Share Posted April 8, 2009 I tried to bench test the fan in the car,.. and it did not work, but after I took it out today, and was able to test it out of the car it did work, I will change the relay, as well as the temp. sensor by the thermostat, as well as check the wires for a bad connection. Thanks, Steve Link to comment Share on other sites More sharing options...
