Mustangjem1 Posted March 18, 2009 Report Share Posted March 18, 2009 Grabber Help!! I took mine in today and the dealer said it's normal for it not to shift into reverse or for the gears to grind between shifts. I had 1,613 when I took it in and when I picked it up it showed 1,614.5. I really doubt that they even put the effort into checking it out. They also were trying to tell me that all the issues did not effect my car because it was built later in 2007. I went over all the points that you have listed and he would like me to bring it back to talk with the service manager. My vin is 1ZVHT88S475352488 and I show a build date of 5/3/2007, is that right? I do know the owner of this dealer, should I just call him or try to deal with the service manager? Link to comment Share on other sites More sharing options...
DDT Posted March 18, 2009 Report Share Posted March 18, 2009 They said it's "NORMAL" not to go into reverse and grinding gears?????????? They are "USELESS"..........Find a real Dealership........... Link to comment Share on other sites More sharing options...
6-Speed Posted March 18, 2009 Report Share Posted March 18, 2009 I suggest that you get educated on the TSB before you bring it in again and bring a print out with you to show your service advisor. You're at the mercy of the dealer if you don't take it upon yourself to know more than they do. There's plenty of information on this forum. The Tranny TSB affects 2007, 2008 and some 2009 models. Link to comment Share on other sites More sharing options...
Mustangjem1 Posted March 18, 2009 Author Report Share Posted March 18, 2009 I suggest that you get educated on the TSB before you bring it in again and bring a print out with you to show your service advisor. You're at the mercy of the dealer if you don't take it upon yourself to know more than they do. There's plenty of information on this forum. The Tranny TSB affects 2007, 2008 and some 2009 models. I had printed all the info out and I took it with me and discussed each part and why it needs to be corrected. It appeared as if most of the employees wanted to get out to celebrate St. Patrick's day! I am not finished until they fix it! Link to comment Share on other sites More sharing options...
CobraCrazy Posted March 18, 2009 Report Share Posted March 18, 2009 I agree with DDT--find another Ford dealer in your area to work with! If they are willing to feed you this BS and treat you this badly, just think how they are going to treat your car. CC Link to comment Share on other sites More sharing options...
Imatk Posted March 18, 2009 Report Share Posted March 18, 2009 Love dealerships Call the owner or find a different dealership man... these guys are clueless. Link to comment Share on other sites More sharing options...
shel-b001 Posted March 18, 2009 Report Share Posted March 18, 2009 I would find another dealer try one that has already done the TSB if that is at all possible. Don`t give up. Good Luck. Link to comment Share on other sites More sharing options...
Grabber Posted March 18, 2009 Report Share Posted March 18, 2009 It does not matter what your build date is. You have a 2007. Everything I know about the problem has been posted in my Clutch threads. Not sure what else I can do. Link to comment Share on other sites More sharing options...
