jfried Posted April 8, 2011 Report Share Posted April 8, 2011 First of all, Welcome. But seriously, but did you happen to read this thread at all? Not meaning to be a dick, but do you really want to be THAT guy that used his 1st post to ask a question in a thread full of answers? The good news is, you found the right thread and the answers do lie within. Cheers and again, welcome. Thanks for the welcoming. I realized that all the people here were attaching them with velcro, that doesn't neccessarily mean that on the factory installs it's done the same way. If it is infact done with Velcro, any recomendations to removing the velcro squares from the dash so I'm not stuck with glue/stickyness? Link to comment Share on other sites More sharing options...
07SGT5687 Posted April 8, 2011 Report Share Posted April 8, 2011 Thanks for the welcoming. I realized that all the people here were attaching them with velcro, that doesn't neccessarily mean that on the factory installs it's done the same way. If it is infact done with Velcro, any recomendations to removing the velcro squares from the dash so I'm not stuck with glue/stickyness? Fair enough, but my understanding is that it's either velcro or double sided 3M tape. Would think some patience and some Goo Gone might do the trick. Link to comment Share on other sites More sharing options...
Ponyv8 Posted April 12, 2011 Report Share Posted April 12, 2011 I bought and installed it 1 year ago, very easy to fit, but the velcro tape is ridiculous, I had to stick it with silicone. Looks great, with the carbon shelby signed gauges Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted April 12, 2011 Report Share Posted April 12, 2011 Velcro or 3m tape is the only method I would reccomend, anything more permanent and you're probably going to have bigger problems if a gauge bulb burns out or something fails! Sam Link to comment Share on other sites More sharing options...
SGT3477 Posted April 27, 2011 Report Share Posted April 27, 2011 i went with 'shelby setup' $$ yes but keeps a uniform look in the car IMO. i did the install my self. took about 3 hours. primarily because when i started i was rushing and inadvertently cut a wire under the dash when i was stripping back the tape to get at that striped wire. had to climb out, bust out the soldering iron and solder in a new 2 inch length of wire as the original was pulled so tight there was no was to reconnect it to itself. the only other challenge i has was with the O-ring sent with the aluminum fuel block.. it was to big and i had alot of fuel leakage at first. no matter what i tried..i finally went out an bout an O-ring assortment and found the next size down and its been fine ever since ( was tripping "check fuel cap" error ) one the side is a small plug screw. that also would not seal. small bit ot tape and that sealed up. i was able to pull the wires down far enough that no colored wires are visible on the dash. just the little black pigtail. end result looks good but im not getting good reading on oil temp.. need to reassess those connections. over all not bad driveway project the intructions are good and threads like this with real pics will steer you straight. Link to comment Share on other sites More sharing options...
